Question about Edirol R-09 Digital Voice Recorder
Formatting SD card
I'm trying to format an SD card in the Edirol r-09, but it just keeps saying now processing...
It seems like it will continue saying this forever unless I turn it off. How long is formatting supposed to take? Any other suggestions or ideas? The SD card inside right now is an Edirol SD card, so it should be fine right?
Thanks,
-Jeff
  • postrading Nov 21, 2008
    i have the same problem with a 4 GB sd card. ive tried turning the power off turnign it back, on factory reset, putting the chip in, formatting and is till doesent work.
    what now?
I had this problem too. Some SD cards won't properly format. My trick was I formatted the card in a different device first (canon Powershot A-630) then put the card in the R-09 and formatted it again. it took about 8 seconds for a 2 gig SD card to format.
Posted on Sep 11, 2008
I resolved this problem with the following steps:
  • Take note of all your settings
  • Power off device
  • Remove SD Card
  • Power on device
  • Perform Factory Reset
  • Insert SD Card
  • Format SD Card (should only take a couple seconds)
  • Refer to your notes to reset your preferred settings
Posted on Oct 30, 2008
Why is my camera going round and round in circle when trying to format my memory card?
I'm suspecting that you are trying to use a new 4GB or larger SDHC card with your older model camera. Please note that your model camera can only use 2GB or less standard SD cards (and NOT SDHC). 2GB SD cards are inexpensive, and still available on Amazon.com if your local store no longer carries them.
Nov 10, 2011 | Kodak EasyShare DX7590 Digital Camera
8GB SD card says: MEMORY CARD REQUIRES FORMATTING After selecting continue SD card says: FORMATTING WILL DELETE EVERYTHING ON MEMORY CARD after selecting continue it says: FORMATTING... but then returns...
i guess you are using it thru a USB, try a differnt USB port if you have more than one USB port on your PC....else
try it on a different PC
or
a longer solution is to get a low level format software like "killdisk".....this is also a DOS based application....install it and use the in Win or thru a boot diks DOS application
revert back
Jan 06, 2011 | PNY 2GB microSD Memory Card
My memory card for my phone says it has an unrecognized format
have you tried formatting it in your phone and in the computer
Jan 14, 2010 | SanDisk 4GB microSDHC Memory Card
Kodak EasyShare DX4530 Digital Camera Digital Camera Cannot format memory card After I inserted new card, it says that memory card required formatting....I hit Continue...it warn me that formatting will...
If your using more than 2GB of SD card or if yous using the SDHC card it will not format the Memory card.
Try to used the recommended Memory card 2GB or 1GB SD card It will reformat your card. Too Much or too High SD card is not compatible on DX camera series
Nov 08, 2009 | Kodak EasyShare DX4530 Digital Camera
Can't get sd card to format
The camera will only take up to 2gb.TED10
Apr 13, 2009 | Kodak EasyShare C330 Digital Camera
Memory card needs formatting.
take a look at your memory card to make sure it is not locked, then try formatting you memory card
Dec 26, 2008 | Kodak EasyShare C713 Digital Camera
LEXAR 4GB SD MEMORY CARD FORMAT??
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Nov 29, 2008 | Kodak EasyShare CX7300 Digital Camera
R-09 broken, don't know where I can repair one fast in UK
Hi Igor,
You have probably long since either had your Edirol repaired or found a replacement. If the latter situation is the case, and you have your R-09 sitting around collecting dust, I might be able to help. The buttons likely did not fall off, but were pushed back into the unit. Try opening it up by unscrewing it from the bottom (First open the battery cap) and carefully opening it up. You'll lkely find the buttons pushed back into it.
I learned this after a friend dropped mine at my wedding. Determined, I set out to fix it.
Good luck to you or anyone else reading this post,
Peter II
Nov 16, 2008 | Edirol R-09 Digital Voice Recorder
Sd card formatting
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
Oct 22, 2007 | HP Photosmart R707 Digital Camera
Edirol R-09 Digital Voice Recorder Logo
1,251 people viewed this question
Top Edirol Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Edirol Audio Player and Recorder Expert? Answer questions, earn points and help others
