The suds sign on your Bosch Exxcel Vario 7 Speed Perfect washing machine indicates that there is too much foam in the wash. This can be caused by using too much detergent or using the wrong type of detergent. Here are some steps you can take to try to resolve the issue:
Reduce the amount of detergent: Check the detergent packaging for the recommended amount of detergent to use and reduce the amount if necessary. Overloading the machine with detergent can cause too much foam to be produced.
Use the right detergent: Make sure you are using a detergent that is designed for use in front-loading washing machines. Using the wrong type of detergent can cause excess foaming.
Run a rinse cycle: Run a rinse cycle without adding any detergent to help clear out any excess suds.
Check the detergent dispenser: Make sure the detergent dispenser is clean and free from any residue or build-up that could cause excess suds.
If the problem persists, it is possible that there is a problem with the pressure switch or the control module of the machine. In this case, it is recommended to contact a qualified technician to diagnose and repair the issue.
Check if the inlet pipe has not twisted,if ok unplug machine remove top and (if confident enough) get a multi meter to check if the coil is not open circuit (broken),if so replace it eric992
Bosch maxx 5 washing machine will not drain
This video will show you how to change the pump washing
machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
Bosch Logixx 8 Vario problem is that the conditioner is still in the drawer after the wash is finished
This video will show you how to keep your soap draw clear
and how to service the parts
question.
facebook
