Sounds like the filter on the hot water inlet is blocked. Is this a new shower or one that has been in use for some time ? Also , what make?
Ok, sounds like the filter in the hot water supply is blocked. You need to isolate the water supplies, remove the shower valve ,turn on the hot water to see if you have full flow going into the shower valve. If the flow is ok then you need to remove the cartrige in the shower valve and check the internal filters. If they are clear you need to purchase a replacement cartridge from Gainsboro. Hope this helps. Derek.
Its a gainsborough energy 2000x
