Question about Refrigerators
Iced up Samsung RS21 JGNS Help!!
Hi,I wonder if you can help me? I have a Samsung RS21 JGNS fridge/freezer just over 2 1/2 years old. I have had problems with it for a couple of months, The fridge side seems to ice up around the fan gradually over the week,it will stop cooling as the fan cant turn. After taking apart de-icing the fan and evaporator and making the drain hole by the fan a little larger .The same thing happens again after around 8 days I have replaced the defrost sensor as thought this may be the problem, but the same thing still happens,On looking online this seems to be quite a common problem, hope you can give me some advice to what tthe fault maybe?
  • tank0412 Aug 09, 2008
    I have the same problem with the defrost circuit. Please could you advice whether there is a tolerance on the resistance values :-
    Main Heater = 480Ω
    Drain Heater = 2KΩ
    I have a reading of 391Ω on the main heater and have replaced the derost sensor.
Contact Samsung as they have extended the warranty to a limited 5 years to cover this fault.
Will send out an engineer to fit an upgrade,eg defrost heaters,sensors and evap cover.
gw
Posted on Sep 03, 2008
This is an issue with the evaporatore cover on these units watch watcdog on monday night
Posted on Apr 05, 2008
  • 236 Answers
Defrost the unit and after defrosting, with the unit unplug rotate the fan blade manually using your finger. The fan should rotate freely, the blade should not touch the fan frame. Slow rotation of fan motor can cause icing. Worn out bearing, misalign fan blade, partially burn fan motor can slow the rotation of blower motor.But if the blower operate normally, then the unit may be under charge of refrigerant. Qualified technician is needed with this problem.
Posted on Mar 05, 2008
Samsung rs21 fridge temp keeps flashing
It's a defrost sensors issue. You need to replace the evaporator assembly it will come with all the sensors you need.
Jul 24, 2013 | Refrigerators
My samsung will run fine for about 4 hours and then will get too cold. if i unplug it and then plug it back in it will then work fine for another 4 hours. please advise thank you
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Feb 14, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung fridge/freezer model SRS73DTA doesnt freeze.
Hi I have the same problem,
did you get an answer to your question..?
Jan 19, 2009 | Freezers
I have a samsung RS21DGRS and it keeps makung a wurring noise from inside rear of the fridge compartment and now the water dispenser has stopped working .
very common issue on samsung rs21 models ,
repair kits have been available for a few years now
this video may help
how to dismantle samsung rs21
Sep 05, 2008 | Refrigerators
Samsung refrigerator sr-l628ev ,refrigerator not working ,air mixing flow system notworking ,but freezer is working
I don't have a solution, but I have the same problem. Or rather I did until today when the freezer started defrosting itself too.
It sounds very similar to the RS21 problem that is on the watchdog website, but as my fridge/freezer is 8 years old I don't think they are going to give two hoots about repairing it foc.
Jul 27, 2008 | Samsung Refrigerators
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
RS21 DCNS FRIDGE COOLING FAULT
There is a fan behind the plastic. This distributes the cold air throughout the fridge. What happens is this fan stops turning due to freezing up. A temp solution is to unplug the samsung for 6-12 hours to allow the ice to melt from around the fan. This is a known design fault. It is easy to dismantle the plastic cover and defrost the frozen fan with a hair dryer, this way the fridge will only be off for about an hour
Aug 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
838 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
