Question about Tag Heuer cj1110.ba0576 Wristwatch
TCM Digital Watch
Hi there, I was given a black digital watch with the letters TCM on the back as a second hand gift. There is no model number other than 222908 written on the back. I don't have the instructions as they were lost. It's got a barometer, digital compass, stopwatch and 2 alarm function as well as a rotating bezel with compass points thereon. It has 4 buttons 2 on the left and 2 on the right side of the watch face. The lower button on the right is orange in colour. I am looking for instructions on how to set the digital compass as this would help in my daily work capacity. I know it's a long shot but any assistance would be greatly appreciated as I've had no joy on the internet.
Thanks, Bluenose2
  • chris1trell Aug 29, 2008
    I have had the same problem. I was given a digital watch with TCM as the brand. Same buttons and controls as the previous watch owner. I can't find ANYTHING on the internet regarding a manual as to how to work this. As far as I have seen, it's made in Italy and evidently they don't use the web for much of anything. Any help would be greatly appreciated.
  • SmokeyK Jan 28, 2009
    I have the same watch but can not get the temperature to be shown in celsius, can any one please help it's driving me insane?
V:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Cmpass (COM)
The integrated compass tells you the direction (e.g.SSW for south­southwest) as well as the number of degrees. To determine a direc­tion,hold the watch horizontally with the 12 o'clock position poin­ting in thedirection you want to know.
General information about the compass
The compass always points to the magnetic north pole.Maps are always drawn in alignment with the geographic north pole (verticallyupwards at 90 ). The declination angle denotes the deviation between themagnetic north pole and the geographic north pole. This deviation depends onwhere you are located. To obtain exact results, the declination angle must beentered into the compass.Remember to change the angle when travelling abroad.Within the UKthere is no need to change the angle because deviati­ons are only slight.Overleaf you will find a table showing the declination angles for a number ofcities around the world.A fault has occurred if the display shows"ERR" while taking a direction or calibrating the compass. Thecompass must be re-calibrated (refer to section after next) .
Table of declination angles
Amsterdam 01 W Little Rock 03 E San Francisco 15E Atlanta 04 W Livingston, MT 14 E Seattle 19E Bombay 01 W Munich01 E Shanghai 05W Boston 16 W NewYork City 14 W Toronto 11W Calgary 18 W Orlando 05 W Vancouver 20W Chicago 03 W Oslo 02 W Warsaw 04E Denver 10 E Paris 02 W Washington DC 10W Jerusalem 03 E Prague 02 E London 03 W Rio de Janeiro 21 W
Posted on Oct 18, 2008
  • bill_gates Oct 18, 2008
    next page, pls
    Calibrating the compass
    The compass must be calibrated before using it for the
    first time, after resetting it or changing the battery and whenever you travel
    abroad. The compass is a highly sensitive instrument. When
    taking a . bearing and calibrating the compass, keep away from magnetic and
    electrical fields. Fields of this type will corrupt the reading. The best
    results are generally obtained out of doors.
    1.
    Repeatedly press S3 until the display shows COMPo The watch changes to the
    compass function.
    2.
    Press S4 for approx. four seconds until the display shows CAL.
    3.
    Hold the watch
    horizontally and slowly rotate the watch twice about itself. Each rotation must
    take at least 15 seconds .
    4.
    Press 54.The first digit on the display will
    flash if calibration was successful. Continue at step 5. If the display shows
    ERR, a problem was encountered during calibration. Check your surroundings for
    potential sources of interference and, if necessary, move away from them.
    Repeat steps 2 to 4.
    5.
    Refer to the table
    to look up the declination angle for your location. Perform the following
    settings one after the other: First digit of the degree number - Second digit
    of the degree number - E!W (east or west)
    6.
    Press 51/52
    to set the first digit and confirm
    your entry by pressing 53. The
    second digit flashes.
    7.
    Press 51/52
    to set the second digit and confirm
    direction E flashes.
    8.
    Press 51/52
    to set the direction E or W.
    9.
    Press 54 to quit the setting mode. The display briefly shows END CAL
    and then the current reading.
    Pressing any
    button during calibration will abort the function, and the compass will not
    indicate any clear direction.
SmokeyK asked about setting the temp to celsius. To do this go into barometer mode then the stop key alternates between the two temp scales. Hold the stop key for a few seconds to change it.
Posted on Mar 16, 2010
TCM items are available through Tchibo so maybe you could ask how to obtain instruction manuals etc through one of their shops
Posted on Nov 11, 2008
Http://www.terracielomare.it/
Posted on Mar 24, 2008
Here are instructions for finding out your geographic specific declination angle.
If you dont know your latitude and longitude, go to Google Earth to find out.
Then go to
http://www.ngdc.noaa.gov/geomagmodels/Declination.jsp
and input your your latitude and longitude.
This will give you the correct declination angle for your location.
Posted on Nov 29, 2008
Tip
How to submit questions about watches
To submit correct question about any watch here on FixYa you have to give as much details of particular watch as possible. There are hundreds of people asking for help, but it makes no sense if the question, for example, is: How can I adjust my Citizen stainless steel watch? Citizen, as any other watch manufacturer produces thousands of watch models and every year few hundreds of new models are added. This makes impossible to recognize any watch by the brand name given only.
So, to make sure that you will receive proper help with your watch, please always submit:
1. Brand name;
2. Model name;
3.Type of display ( Analog or digital or both);
4.Type of movement (Mechanical, quartz, kinetic, solar e.t.c.);
5.Number of the watch (Usually written on watch's case back);
6.All the writings you can find on watch's case back.
If you are not sure what type of movement your watch has, here is a tip how to find it out: Observe watch's seconds hand. If it is moving in jumping action second after second - your watch has a quartz movement which is battery driven. If the seconds hand is moving in sweeping action - most likely your watch has mechanical movement which is driven by spring.
The more information you will submit, the better.
on Jan 08, 2010 | Watches
I have a Coleman digital watch. Four button. I replaced the battery and need to reset the time and date.
Click on your watch model number to open the instruction sheet below.
Your model number is located on the caseback of your watch
go here> http://www.gsi-usa.com/instructions/
Aug 16, 2014 | Coleman Mens Digital Dual Time Sport Watch...
How to set time for Casio Baby-G BGA-130
Look up the model on Casio.com and download the manual.
You'll need the four-digit (or three-digit) module number marked on the back cover of your watch.
Jan 05, 2014 | Casio bga-130-1b baby-g bga-130-1ber
I have a black and dark grey digital watch marked TCM on the back with 4 buttons saying "bearing", "start/spl", "mode/select", "stp/light/set" around a circular digital face. On the back it says that it...
  1. Hold and press upper left. (backlight turns up and cipher (to adjust) start blinking)
  2. Switch between the positions by pressing bottom left
  3. Set the cypher you want by pressing bottom left
  4. Repeat step 2 and 3 each time you need
  5. Press upper left to end of adjusting
To use the compass - upper right. To callibrate and set the declination, please search it. I just post that answer to another TCM 217362 watch owner.
Oct 21, 2010 | Watches
I accidentaly reset time & date on my square arnette watch and i need help to set it
Thank you for contacting FixYa.
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 | Watches
I have a Aerospace model watch and am having difficulty in adjusting the digital time to be equal to the minute and hour hand time.
Its best to change on the hour.Stop your watch so that the second hand is pointing to 12.
Move the hands to the time i.e 10am then advance the minute hand 5 mins past the hour, then turn it back to 10am, when the time comes push set and your hands are set.
I think you might have not moved the minute hand forward 5 mins and back.
You can now set your digital time from your hands setting.
Oct 22, 2009 | Breitling Aerospace Avantage E7936210/G606...
Ancient Seiko digital watch
you need to give the movement number. at seiko watches you will find a number which has 8 letters and/or digits devide by -
Mar 05, 2008 | Watches
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Tag Heuer cj1110.ba0576 Wristwatch Logo
8,644 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
