Question about Venturer 3.6" Portable DVD Player
Venturer PVS 1262 won't play
I have a Venturer PVS 1262 that won't play movies at all. I can put a DVD in and it sounds like it trying to start....starts spinning, but then nothing- it's gives me a read error of no disc. So I tried to "clean" it with a DVD cleaning disc but it still doesn't work. Anyone got any ideas or suggestions? Or is it just dead?
  • 2 more comments
  • bigcat777 Mar 28, 2008
    same problem, disk spins and eventually says "no valid disk". I also tried the disk cleaner to no avail.
  • fixmyprob77 May 20, 2008
    Same problem. It started after only about 2 hours of total use with this DVD Player. Cleaning does not help.
  • Anonymous Jun 02, 2008
    yo tambien tengo el mismo problema, y este equipo no tiene mucho tiempo max 1 año y solo lo uso en los viajes, hay alguna manera de calibrar el lente o reemplazarlo? hay lentes compatibles para este equipo?
    si tiene alguna idea por favor enviarlo a este correo : antonio_stcr@hotmail.com, gracias.
    saludos
  • Anonymous Apr 26, 2009
    my disk wont even spin it just says no valid disk.HELP PLEASE!
The problem you have seems similar to mine. I found the ribbon cable came off on the under side of the motor. This involves disassembling the player. You will see one side goes into the track laser and the other goes into the motor. Be careful with the ribbon cable it is very thin. I found it easier if you remove the cable from the under cover. It is held on with two way tape. The cable will slide back in with no problem, just make sure the lock tabs are open. They are rectangle in shape. hope this helps you
Posted on Jan 03, 2009
I had the same problem with my dvd player and there is a small button near the latch that holds the door down if you find a way to get that down further that might fix your problem it did for mine
Posted on Sep 11, 2008
    Problem Solver:
  • 6 Answers
I had the same problem so i took the bottom off and found that the strap wire from the optic eye to the board was undone they use a quick connect that should help you out
Posted on Nov 16, 2009
    Problem Solver:
  • 6 Answers
I found with my machine (same as above model) that my kid had loosened the main wheel that the dvd attaches to. during figuring it out being 6 yrs old he moved the eye mechanism back to far so that when a dvd was put in it would not spin. I took apart the case seeing the little switch that the mechanism hits when closest to the wheel. Realizing how this worked, I slid tightly forward the mechanism hearing a few teeth slip till it bottomed forwards making contact to start the motor assy spin up routine. NOW there are some tiny washers underneath this wheel also.. SO, the height of the dvd to the eye is mechanism is severly critical... humm what to do without washers? Dr. Pepper 20oz soda with a small 3/32 drill along with a hole punch ;) worked like a charm now leaving me with 4 washers plastic and one factory steel washer.... I placed washers in to get the height set correct inserting washers one by one while testing a dvd, till the dvd played. Then taking super glue to lock the wheel back into place. ...hope this works for some other people just be realigning the eye mechanism to spin up the dvd in the first place. Kids do odd things at times, and I hate to toss away my money if you catch my drift! ;) ~ BlkSmth
Posted on Aug 04, 2009
I found the motor not working due to one of the leads to the motor was broken just where it inters the motor case. I disassembled the motor and replaced the wire and it is now working. IT IS NOT A FIX FOR THE CONSUMER.
Posted on Oct 25, 2008
Yes I do know what wrong with your Portable dvd player. The motor is dead. I'm trying to find out where I can buy a new motor.
Posted on Oct 11, 2008
Is it possible to plug in my playstation 2 into my pvs 1262 dvd player and use the screen to play video games
it could be possible but you need to modifir a cable to get a connection betweed the two devices cause such a cable doesn t exist
Aug 04, 2011 | Venturer PVS177W Portable DVD Player
I have a Venturer PVS 7287 dual player. The player we use most will play the sound but the screen is a blank white. We've tried different DVD'S with the same results.
Venturer PVS7287 Twin Mobile DVD Player 8" LDC Screens - I was getting a blue screen with the DVD not loading. I could see the ribbon cable was just slightly off from the side of the optic eye board. I gently pushed it back on with the tip of a screwdriver. I didn't have to take the player apart, as you you can see the optic eye and the cable that attaches to it when the door is open and the DVD removed. Be careful with the ribbon cable, it is very thin.
Apr 14, 2011 | Car Audio & Video
Black screens, set checked everything but can not
The only "kill switch" I am aware of is the switch on the DVD compartment door. I don't have your exact model but, on my model, this switch is activated when the door covering the DVD is closed and deactivated when this door is opened (kills the DVD spin and reading laser). Look for a small square hole in the DVD player deck and a corresponding raised piece of plastic on the DVD door.
Oct 07, 2009 | Venturer 3.6" Portable DVD Player
VENTURER DVD PLAYER
lookind for a venturer 8.4 widescreen portable dvd player pvs 1080g
Oct 11, 2008 | Dynex DX-PDVD7 Portable DVD Player
Battery
take it back if u have the recipt
Mar 28, 2008 | Televison & Video
Venturer portable dvd
one of the monitores for my venturer pvs 192 in car dvd player has blown, could any body help with a replacement.
Jan 03, 2008 | Venturer PVS177W Portable DVD Player
Venturer pvs 1262
Duplicate post - please see the other one :)
Mar 22, 2007 | Venturer PVS177W Portable DVD Player
Ventuer pvs 1262
a new battery sounds like the solution. Here is the link to the manual; http://www.1800customersupport.com/productdocuments/PVS1262.pdf Link for troubleshooting FAQs; http://www.1800customersupport.com/products.aspx?view=36&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders this next link will give you contact details in order to source a new battery, but try them first in case they know another solution; http://www.1800customersupport.com/request.aspx Hope this helps, post again please if not :)
Televison & Video Logo
1,566 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
