Question about RCA F36645 TV
T.V comes on blue screen and no volume
I was watching the set, I heard a kind of snap sound and lost audio. I turned the set off and back on. Now I get no picture,only a blue screen and still no audio. If I put in a dvd, I get the sound from the dvd but no picture. I am hooked up to broad band. Any ideas??
    Genius:
  • 1,153 Answers
Tuner problems
Posted on Mar 05, 2008
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
No volume on the cable tv setting?
Does the set have a earphone jack? if dirty or damaged it will cut the TV sound out---about the only other possible reason is a audio problem in the TV itself---if possible put ear up to speaker to see if any sound or buzz is heard.
Nov 30, 2012 | Polaroid FDM-0715 Television
Blue Light comes on but no picture
Hi, do you still have sound. Can you control your volume. It might be one of your sustainer boards. Please let me know. It could be your SDR boards too.
May 14, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Icame accross a screen with all kinds of tv
I have experienced this problem a few times with your TV. First check and make sure that the speaker toggle option is set to "on". I have seen this 3 times and ended up replacing the television main board, which restored the audio.
May 03, 2010 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Sound quality
Will not turn on get blue screen with eq band only after leaving it on for some time i get some function out of it only at low volume setting if i try to turn it up reception and sound quality breaks up
Oct 12, 2007 | Pioneer DEH-1500 CD Player
No picture
It sounds Like you Had Horz Failure In your Set,The Squealing you Heard was Probly the Horz Output Transistor,You will Probley have to take it to a Shop
Jul 17, 2007 | Insignia IS 20" TV040919 TV
Philips 27PS55S/121 sound level decreases
Yes, the dynamic range on DVD's is enough to cause the high and low passages to be somewhat annoying but, sounds more like a movie theater. This kind of dynamic range showed up first on Beta HiFi and VHS HiFi VCR's because of thier range as well. If there is a feature in your audio menus on your TV such as "audio expansion, SRS, Wide mode, etc." turn it off and let the audio be processed without expansion of any kind as that will amplify your dynamic range alot more. The lock up issue could be something Philips is aware about and if under warranty contact them. Otherwise not much you can do except manke sure the voltage going to the TV is failry stable between 110 volts and 120 volts. Sometimes dramatic drops and or increases can cause lock up or confusion to the microprocessor in the TV.
Mar 25, 2007 | Philips 27PS55S 27" TV
Blue screen will not go away
The problem is that you're trying to bypass a safety feature. Newer video head units are smart enough to know when you've just grounded the brake switch wire so you can watch it while you're driving. Try hooking it up to your parking brake wire.
Mar 03, 2007 | Dual Bravo HRC-0703 DVD Package Mobile...
Volume decrease
may be some one modified the set up. You can configure different level for different speakers.
Sep 10, 2006 | Onkyo TX-SR600 Receiver
RCA F36645 TV Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
