ADF Paper Feed on Ricoh Aficio 1013
I made a copy using the glass function and now I cannot get paper to feed thru the ADF. I have tried unplugging the unit, cleaning, different paper, re-setting all the functions, etc.
Can you please help with a possible solution to help feed paper thru the ADF?
  • 682 Answers
1-clean rubber belts with lint free clothes immersed in pure alkohl
2-remove adf covers and confirm that nothing broken inside(gears-belts)3-every clutch and selonid are in good condition.
4-solonid lever engaged firmly to gear slevee 5-apply light grease to gears and slevee6-confirm that nothing object the actuation of adf microswitches no dust and dirt in optical switches.
Posted on Mar 05, 2008
How to change feed roller on RICOH Aficio SP C242DN ?
1. remove all the cartridges.
2. remove the waste toner bottle.
3. rear cover
4. left cover
5. paper feed clutch
6. close the top cover and front door.
7. pull out the tray.
8. stand machine with the rear side facing the table.
9. slide the paper feed shaft to the left side.
10. remove the paper feed roller.
Jul 09, 2014 | Ricoh Corp Aficio SP C231N Laser Printer
Ricoh Aficio 1515
is thera paper jam sensor wigle paper in and out unplug unit from wall 2 min ten back in hit sensor with paper hit reset on unit
Jan 22, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
Feb 02, 2018 | Ricoh Aficio 1013 All-In-One Laser Printer
Horizontal streak
Clean the scanner strip glass. This is the small strip of glass that is just to the left of the large main glass. This is the only cause for black line (s) when copying using the ADF(top feed). If prints or copies fine from the glass then it is this strip glass needing to be cleaned.
May 04, 2010 | Ricoh Aficio 450 Copier
When use adf with letter paper sise, push print botton then askme paper 5 1/2 X 8 1/2 inch´s, why do this?
is there any sensors on the adf unit, if so is the paper being feed into the adf unit, there might be a bad/defective sensor, try placing a letter size sheet on the document glass and make a copy, if it copies you have a problem with the adf, and it needs to be serviced
Feb 19, 2010 | Ricoh Aficio 2018D All-In-One Laser...
I have a ricoh spc232sf multifunction printer which is giving a error message of cannot copy and it says feeder adf what do i do?
the ADF is the upper cover where you put the document to be automatic feed by the machine, that is the part which you pull up when you want to copy on the exposure glass, on the left side of the ADF has a little door which you need to open. It is opened like a car door opener and pull it on the right side. see do have some paper inside if do not have paper close the door and lift the ADF in to up position and than set it back. with this you will rest the message.
Please answer do this is helpful for i to know do i should post some more information.
Regards
Jan 12, 2010 | Ricoh Aficio SPC232SF All-In-One Laser...
The 8 1/2 x 11 paper tray will not open - it is not jammed with paper as the print still prints, but we cannot dislodge the tray.
You need to forcibly open the tray, that's the only way. It could be the feed roller assy is gettin hung up.
Dec 23, 2009 | Ricoh Aficio 1013 All-In-One Laser Printer
Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
http://www.websitetoolbox.com/mb/copierquestions
Sep 25, 2008 | Ricoh Aficio SP-C210SF Printer
Copier will not sort documents correctly
Hi songman to sort you need to have the A4 paper in both cassettes one cassette needs to be A4 portrait(wide edge first) and the other needs to be landscape (short edge first)make sure you have the green paper size selector set correctly as well regards Dr Bob1
Apr 09, 2007 | Ricoh Aficio 1018D Copier
166 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
