Question about Maytag MAH6700AWW Neptune Front-Load Washer
Maytag Neptune MAH5500BWW Dont Wont Open
Last night I could not open the door to the washer. The washer just started and I cam e down and it had only gone 2 minutes.
The DO code was on. The door lock light is not on. I pressed the stop/pause button and waited, nothing. Unplugged it, door still didnt release. Pulled on the door and it gives a little but feels stuck at the top where the latch is. When I was pulling on the door , the FL code also came up.
Now there is a short buzzing sound when I go to start and thats it, then the DO code comes up.
Any idea to get the door open or what the problem could be?
  • Anonymous May 20, 2008
    SAME EXACT PROBLEM
  • gpapaz May 24, 2008
    exact same problem. Have not been able to find out what "DO" code specifies. Circuit board looks fine. Not sure about the door lock mechanism. There is a string of comments concerning this without resolution. Not sure why MAH6700AWW is posted product below.
  • 3 Answers
There is a cord you can pull under the soap tray.
Read here:
http://www.applianceaid.com/neptune3.html#lock
Posted on Jun 08, 2008
    President:
  • 1,294 Answers
  • 1073 Answers
SOURCE: Error Code FL
it is saying failed to lock the door need door latch switch part # 22003269
Posted on Apr 13, 2008
  • 52 Answers
SOURCE: I have a maytag neptune LED TOUCHPAD I get
FL code is Failure to Lock. You have a problem with your Door Latch/Lock Assembly
Posted on Feb 28, 2009
Illeagle
  • 525 Answers
SOURCE: My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Posted on Jul 17, 2009
SOURCE: have a neptune mah5500bww when you close door it
I Have a neptune mah5500bww washer and the water will not drain. What do I do?
Posted on Dec 31, 2009
SOURCE: Maytag Neptune MAH5500BWW washer thinks
As I have read solutions for my door not recognizing/not latching I see there could be several paths to a resolution. When I set my washer it reads the door is not shut. If I press okay it will render several clicks and shut off or just not begin a washing cycle. What is my true issue? How do I successfully repair this problem?
Posted on Mar 17, 2011
Maytag neptune mah5500bbw wont spin going through cycle
My Maytag Neptune MAH5500B or MAH5500BWW wouldn't spin either. It would go all the way through the wash cycle, agitation and all, as mentioned before, the spin cycle would start at the 9 minute mark, and get down to the 7 minutes then drop directly to 0 with no spin at all.
After hours of investigation it turned out the balance load switch was corroded. This switch is accessible through the front panel of the washer. The door must be removed and the front panel comes off, this switch is directly under the wash drum where there is a little electrical plug and switch which rests on top of stabilizer styrofoam. The connection was being made but there was green corrosion, and evidently the switch box was corroded within. When bypassed, the washer spun perfectly.
Hope this helps someone else out there - I was horrified to think that this washer would end up more landfill as it wouldn't be worthwhile to pay hundreds for a new motor control board as had been suggested was the problem.
Oct 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Door Lock
on your model all wax motor door latch's have to be replaced,go to repair clinic .com and you can order the part or go to ebay,and put in maytag neptune mah5500bww wax motor and it will come up and the guy selling the motors has pictures on how to install,let me know-mike
Jun 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Mah5500bww
there is probably a Conversion kit for this.You HAVE TO REPLACE BOTH  motor/control board .Im here to help you if need my assistance.
Mar 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH5500BWW
again what do you mean by exauaust
Jan 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
928 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
