Question about Sony PlayStation Portable (PSP) Console
PSP cover dont fit right
I recently had a problem with the speakers in my psp. so i replaced thgem they work great but now when i try to put the face on the psp the arrow keys dont stick out enough they are slightly suken in. Pleez help
    Problem Solver:
  • 6 Answers
Get a new cover or if your psp is normal size you may have the slim psp cover or the other way round.
Posted on Mar 31, 2008
I have a psp1000 it was fine until is started powering down all by itself. i put a brand new battery in it and shortly after it powers up, it powers down. What do i do now, and would it be very expensive...
Here are some instructions to help fix your problem.
Put the PSP down on a table with the LCD screen facing up.
  • 2 Plug the power cord of the PSP power supply into the PSP's power outlet. Plug the AC plug of the PSP power supply into an AC socket.
  • 3 Perform a hard reset on the PSP by pushing up on the power switch at the lower-right corner with your index finger.
  • 4 Count to 15. Release the PSP's power switch. Count to 30.
  • 5 Flick the PSP's power switch up with your index finger and release it. Repeat this procedure a second time.
  • 6 Wait as the PSP reboots, starts up and stays on.
  • 7 Remove the PSP power supply's power cord from the PSP's power outlet. Remove the PSP power supply's AC plug from the AC socket.
  • 8 Flick the power switch up with your index finger to turn off the PSP.
  • May 05, 2011 | Sony PlayStation Portable (PSP) Console
    Tip
    Replace a PSP screen quick and easy
    The guide to fixing your PSP screen the easy way!!!!!
    This Guide will give you simpleinstructions on fixing the psp screen with little to no stress. Besure to keep all your things in one place and try to do everything inone sitting or at least do it in a area where you know somebody won'tknow knock the parts to the floor as there is a lot of small screwsand thing. Try to use a small box or pan to keep screws and otherparts and keep yourself grounded but keeping parts of yourskin(unclothed)to something made of metal.
    1) Flip you PSP to its backside and besure the back cover that holds the battery is off. There are twoscrews in back of the battery. On could be covered by a sticker. Besure to peel it of slowly as it will void you warranty if it isruined.
    1. After you get these out look on the bottom side,you will see a screw that is dead center of the psp. The last two are above and below where the memory card slot is.
    2. Take the faceplate off. Now you will see a a small set of buttons on the screen. To the right of it
      is a small cable. Use a flathead screwdriver to the clasp and pull the cable out.
    3. You will now see two clamps for the screen where the button assembly for the d-pad is. The same thing for the other side where the face buttons for the psp are. Take all the clamps off by use the flathead screwdriver again. Put in in between the screen and clamps and give it a little turn.
    4. You have the screen out now. Pull it from both sides very slowly. Be very careful as there are cables still connected. Flip the screen out as we are going to take the cables off the screen now.
    5. There are two black clasps holding the screen cables on there. Lift them up(slowly!)and take the cables off. If those claps are broke there is no fix outside a new motherboard so don't break them.
    6. Put the screen into the clasps putting in all necessary cables that were went thru taking off. Sit the LCD screen snugly and and lock clasps. Return faceplate and all buttons to original positions to be sure everything will play right. Before you close it all up be sure everything is in place and fits well. Be sure to put the buttons back on and connect it to the motherboard. Turn the psp on and be sure it all works well. If it is having any pronlems go back over each step in reverse order from when we put the screen in.
    7. Once you go get the screen working put the screen back on and tighten all the screws.We are all done!!! Enjoy your PSP and I will see you online in Resistance!
    Hey guys, If anyone wants to help me get some pictures up shoot me a comment on here. My digital Camera died today and it will be awhile before I will buy a new one(maybe its good because since my PSP is still under warranty)thanks!
    on Mar 16, 2010 | Sony PlayStation Portable (PSP) Console
    Tip
    How to get PSP themes
    it is achally really easy just get a theme then in your PSP put a rolder named THEME capatalized put it in the psp folder.then simply put your downlouded theme to the theme folder.you can get themes by going to any web site with thgem EX. PSPthemes.com or you can also downloud thems by dowloudeing them in your PSP internet browser
    on Dec 02, 2009 | Sony PlayStation Portable (PSP) Console
    I have a PSP but i dont know how to download a games from PC to PSP
    You need custom Frimware, and a pandora battery and magic memory stick, i suggest buying these, but if your a handiman you gotta
    Pandora battery: (dont recomend doing youself) You have to get a normal psp battery, then you have to open it up, And cut a tiny wire on the black chip piece
    Magic Memory Stick: Watch that video After the pandora battery,
    Game itself:You have to find a site that lets you download the games
    Getting Game from pc to psp: You have to make a folder called GAME (all capitals in the psp file in your psp)
    Now, you have to get the game and put it into the GAME folder inside the Psp folder in the psp
    Get psp to connect to computer: go to your psp put a usb connecting the psp to the computer, and go to usb mode on your psp
    Have a nice day ^^
    May 09, 2010 | Sony PlayStation Portable (PSP) Console
    Can't replace plastic umd cover
    There are 3 types of PSP around, starting with model number 1000,
    this is the first PSP also known as PSP Fat.
    PSP model 2000 series, wich has a better screen and more memory on board, it is also thiner als the previous model.
    PSP Model 3000 series wich has a microphone and a better screen.
    The body parts of all PSP models are diferent, this has to do with the placings of internal hardware components.
    Remove the battery from your PSP, underneath is a sticker located with
    the model serial number, if you know the serial number, you'll know for what PSP type you need to order parts for.
    Jan 18, 2010 | Sony PlayStation Portable (PSP) Console
    PSP joystick woes...
    try tightening the face plate more where the nub is. if ts not tight itll cause an intermiddent contact and not wokr right. if this dont work, you fried something w /static from your body. try geting a new metal chassis
    Jul 18, 2008 | Sony PlayStation Portable (PSP) Slim...
    Battery Or Charging Problem.
    Have you updated your firmware recently? Check your PSP to make sure there aren't any loose connections. If you're comfortable with it, you could open it up and make sure the plug for the charger didn't come loose somewhere. It may just need a touch of solder to put it back into place.
    Jul 06, 2007 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
