Question about Sony KV-27S15 27" TV
Standby relay clicks on and off continusly. Tv won't turn on. I check my diode and transistor who control the standby relay and it is fine. I also replaced the flyback and I still in the same situation. What do you recommend to check next?
  • gonzalez_m17 Mar 11, 2008
    Thank you very much for your advise but Can you tell me wich(number Q?) Line transistors do you want me to remove
  • gonzalez_m17 Mar 12, 2008
    Hi!
    After removing the Line transistor I measured it and reads Ok, but when I measured the board (between base and colector) reads no voltage. But standby relay keeps clicking on and off,
    Note: I'm working only with the main TV board outside, and I plug and unplug the main power cord. My TV'S control boards (for power, volume,channels) CRT, and spekers are still attached to the TV set. Do I need to put everything back togheter and try? I didn't do it because when I connect the main TV board by itself still clicking on and off anyways.
    What do you recommend to do next?
Hi there!
I do not have the specs on your TV but this is standard on all TVs. Only different numbers. The Line or Flyback transistor is located next to the Flyback Transformer, usually mounted on a Big Heatsink. When removed and measured you should read a short between Base and Emitter on the Transistor itself. This is an internal Diode on the Package. Now make sure not to short anything when switching the TV on without the Transistor and then measure your Voltage on the board where the Transistor had been removed( between Base and Collector) 145V. Good Luck,JUS004
Posted on Mar 11, 2008
    Scholar:
  • 135 Answers
Hi there!
You have an obvious error state on the unit. You may want to try and remove the Line Transistors to check for voltage first. In the region of 145V(between base and collector. If the set then stays in standby you may have a vertical error. Also check 5V rail to the processor and suspicious looking components like caps. Good Luck,JUS004
Posted on Mar 05, 2008
  • Justin Smith Mar 16, 2008
    Hi there!
    Seems like a tricky fault. Check all the caps in the power supply and any suspicious looking components and perhaps the relay itself, other than that you will have to refer to a repair technician with a circuit diagram and experience on this model. Sorry I cannot assist any further. Good Luck, JUS004
2 Suggested Answers
Mrvica
  • 167 Answers
SOURCE: When I conect my TV, Standby relay clicks on and off continusly. Tv won't turn on
Try to pull cable out! Turn on switch and power cable in and remote put away!
good luck
Posted on Feb 26, 2008
Acoustic solutions lcd37761f1080p
Hi
The electrolitic capacitors are trickery: sometimes they look like fine but its capacitance has gone. The actual test is to replace them if you have not a capacitance meter to test them. Another approach is to check the Dual Schottky diode for leakage. It looks like insulated transistor and is screwed on a heatsink.
Sully
Sep 21, 2013 | Televison & Video
Set on standby mode,no display aiwa nsz-20hr
There is a short in the power supply board, shorted regulator transistor, or diode, and capacitor, "sometimes a bulge at top" cheaper to replace than repair.
Apr 02, 2012 | Aiwa Audio Players & Recorders
Tv won't turn on- its in standby mode. the young lad had the remote before it was turned on.... could he have pressed somethin on the remote which is now preventing it from coming on?
Powering up do you hear the relay click then you may see the display flash (not necessarily), but then the TV clicks back into standby mode. If so there is a component failure.
will need diagnosis by a repair shop. Too many different components it could be for me to guess. but
the common repair kit containes1 fuse (F302), 1 diode (D304), the power resistors (R927 and R929 for the board revisions with these two resistors) and the IC301 voltage regulator IC.
Feb 21, 2018 | LG 50PJ350 50 in HD-Ready TV
The tv wont power on at all
Your TV Won't Turn On
If your TV won't turn on, you should check the power cord. Make sure that it is securely in the wall plug. Sometimes the power cord has burned out and needs to be replaced. You may also want to check the batteries in the remote to make sure that they are working properly. If otherwise
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, if otherwise, Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I hope this will help to solve the problem.....
Jul 07, 2011 | HP Pavilion MD5020N 50" DLP HDTV
Tv went off won't come back on
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, If otherwise you contact the manufacturer or a skilled qualified personnel to handle the fault..
Hoping that will help to solve the problem....
Jun 14, 2011 | Vizio L32 32 in. LCD HDTV
Won't power on
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, if other otherwise Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Take care in solving the problem,because it contain high voltage...
Jun 14, 2011 | Televison & Video
No remote control works anymore
good evening friend. you seem to be having problems in your standby circuits if no remote works on the tv, but you can operate it manually. the standby circuits always stay on that is how you are able to power up the set. go to your remote infrared circuits when this problem exists find the standby transformer and the other parts of this circuit. check for opened or shorted components. find the transformer fuse and bridge rectifiers. somtimes these can be on a seperate board. you might even find a transistor and zener diode regulation circuit in the output voltage source. be very mindful of that standby crcuit. thank you and please rate this solution
Nov 17, 2009 | Sony KP-61S75 TV
Tv keep going on standby when you turn it on
tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
Feb 07, 2009 | Goodmans 257NS 20" TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
379 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
