Question about Sony ® VAIO® V TV-PC Series - VGC-V620G 20" TV-PC (VGCV620G20TVPC) PC Desktop
Networking i want to configure a local area network with 96 clients running windows 98 second edition operating systems and a windows XP service pack 2 operating system as the server.. can you teach me how?
    Problem Solver:
  • 5 Answers
Configure the tcp/ip of all win98se siminteniously, make sure your client ping to the server ip and share them.
Posted on Mar 05, 2008
How can i get an ip address
Firstly, what operating system are you using?
applicable for windows xp or windows 7. press Windows Key + R
select the appropriate network connection (e.g. Local Area Connection). Right click the Local Area Connection choose Properties. For windows xp, doble click Internet Protocol. For Windows 7, double click Internet protocol IPv4. choose Obtain an IP address automatically. press OK. right click again the Local area connection then choose Status. there tou can see that your computer is negotiating for an IP address from the dhcp server. if still cannot obtain an ip address, press Windows key +Run then type "services.msc". scroll down and find DHCP client. ensure that this service is running.
Please also try to check if the network you are connected does have a DHCP server.
Jul 01, 2013 | HP Compaq nc6220 Notebook
Tip
IP ADDRESS.. 0.0.0.0 troubleshooting
<p><b>Symptom:</b><br /> loadTOCNode(1, 'symptoms'); <p>When you use the ipconfig command to renew your computer's IP address, either of the following behaviors may occur: <br /> &bull;<br /> You may receive the following error message: <br /> <p>An error occurred while renewing interface local area connection. The system cannot find the file specified.<br /> -or-<br /> &bull;<br /> The command may return the IP address and the subnet mask 0.0.0.0.<br /> <p><b>Resolution:</b><br /> loadTOCNode(1, 'resolution'); <p>To resolve this behavior, use the following methods in the order they are presented. Before you start, restart your computer. After each method, test to determine whether the issue is resolved. <br /> <p><b>Method 1. Turn Off Firewalls:</b><br /> <p> loadTOCNode(2, 'resolution'); Make sure there are no firewalls and that Windows XP Internet Connection Firewall or Windows Firewall is turned off. <br /> &bull;<br /> If you have a third-party firewall installed, disable it. <br />For information about how to disable your firewall, see the product documentation, or contact the technical support department of the manufacturer.<br /> &bull;<br /> Turn off Windows XP Internet Connection Firewall. To do so, follow these steps: <br /> 1.<br /> Click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.<br /> 2.<br /> Right-click your connection, and then click Properties.<br /> 3.<br /> Click the Advanced tab, and then click to clear the Internet Connection Firewall check box if it is selected.<br /> <p>If you use Microsoft Windows XP Service Pack 2 (SP2), follow these steps to turn Windows Firewall off: <br /> 1.<br /> Click Start, click Run, type <span>ncpa.cpl</span>, and then click OK.<br /> 2.<br /> Right-click your connection, and then click Properties.<br /> 3.<br /> Click the Advanced tab, and then click Settings. <br /> 4.<br /> On the General tab, click Off (not recommended).<br /> <p><b>Method 2. Verify That Your Network Card Is Installed Correctly:</b><br /> <p> loadTOCNode(2, 'resolution'); Verify that your network card is installed correctly. To do so, follow these steps: <br /> 1.<br /> Right-click My Computer, click Manage, and then click Device Manager under Computer Management.<br /> 2.<br /> Expand Network Adapters, and then verify that your network adapter is listed. <br /><br />If your network adapter is not listed, use the following methods in the order they are presented: <br /> a. <br /> Update or reinstall the driver.<br /> b. <br /> Move the adapter to another available slot, and then reinstall it.<br /> c. <br /> Replace your network adapter.<br /> <p><b>Method 3. Verify That the Dynamic Host Configuration Protocol (DHCP) Client Service Is Started:</b><br /> <p> loadTOCNode(2, 'resolution'); Verify that the DHCP Client service is started. To do so, follow these steps: <br /> 1.<br /> Right-click My Computer, click Manage, expand Services and Applications under Computer Management, and then click Services.<br /> 2.<br /> Verify that the DHCP Client service is running.<br /> 3.<br /> If the service is stopped, right-click DHCP Client, and then click Start.<br /><br /><b>Note:</b> If the service does not start, a dependency group or service may also be stopped.<br /> <p><b>Method 4. Modify the Registry:</b><br /> <p> loadTOCNode(2, 'resolution'); <b>Warning:</b> Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk.Make sure that the DHCP registry entry is correct. To do so, follow these steps: <br /> 1.<br /> Click Start, click Run, type <span>regedit</span>, and then click OK.<br /> 2.<br /> Locate the following registry key. <br /> <p>HKEY_LOCAL_MACHINE\System\ControlSet001\Services\DHCP<br /> 3.<br /> In the right pane, double click DependOnService, and then make sure that the Data Value value is Tcpip Afd NetBT.<br /> 4.<br /> Restart your computer, and then verify that the DHCP service is started as described in Method 3.<br /> <b>The information in this article applies to:</b><br /> &bull;<br /> Microsoft Windows XP Home Edition<br /> &bull;<br /> Microsoft Windows XP Professional<br />
on Mar 15, 2011 | Computers & Internet
Tip
Networking Issues
Problem: Network Cable Unplugged
Description: Don’t take this message literally - there are many causes besides not having a cable physically plugged into the network card. The message really means that the network card doesn’t detect a live link to another device on the other end of the cable.
Possible Solutions:
Download and install the latest network card driver program.
Check the cabling - a bad cable will prevent link detection. Substitute a cable that’s known to be good.
Check the link lights on the device on the other end of the cable, whether it’s a hub, switch, router, or a NIC in another computer. It should show a live link to the NIC. If it doesn’t, try a different port.
Auto-detecting speed and duplex mode can be unreliable. Set them manually. Most routers and switches use 100Mb, full duplex. Hubs can only use half duplex.
Problem: Renewing a DHCP lease fails, with error message “An error occurred while renewing interface <name>: The system cannot find the file specified.”
Problem: Network connection configured to obtain an IP address automatically has IP address 0.0.0.0
Solution: Make sure that the DHCP Client service is running:
Right click My Computer, and click Manage.
Double click Services and Applications.
Double click Services.
Double click DHCP Client. If the Service status is Stopped, click Start.
Set the Startup type to Automatic.
Thanks to Lightcap, who suggested this fix in a news group message.
Problem: Network Connection Has IP Address 169.254.x.x
Description: The network card is configured to obtain an IP address automatically, and it’s connected to a network with a DHCP server: hardware router, another computer running Internet Connection Sharing, cable modem, DSL modem, etc. But it gets a 169.254.x.x IP address, which indicates that it can’t communicate with the DHCP server:
Possible Solutions:
Connect the computer using a different Ethernet cable or hub/switch/router port.
Download and install the latest firmware for the hardware router.
Disable XP’s Internet Connection Firewall <../xp/ic_firewall.htm> on the local area network connection.
The card is configured to automatically sense network speed and duplex mode, but auto-sensing is failing. Configure the speed and duplex mode manually. For example, most switches and routers use 100 Mb speed and full duplex. To make the settings, right click the network connection and click Properties | Configure | Advanced.
Un-install the network card and move it to a different slot.
If you have a cable modem connection, turn off the computer, turn off the cable modem, and wait a few minutes. Turn on the cable modem, and then turn on the computer.
Error Message: An error has occurred while trying to share <filename>. The Server service is not started. The shared resource was not created at this time.
Solution:
To start the Server service:
Right click My Computer and select Manage.
Scroll down the list of services and double click Server.
Click the Start button.
Click Apply and OK.
Problem: Computer A Can Ping Computer B, but not Vice Versa
Solution: This is almost always caused by an improperly configured firewall on Computer A.
Problem: One Computer Can’t Access Some Web Sites, but Other Computers Can
Solution: Look for the Windows Hosts file on the problem computer:
Windows 95/98/Me: C:\Windows\Hosts
Windows 2000: C:\WinNT\System32\Drivers\Etc\Hosts
Windows XP: C:\Windows\System32\Drivers\Etc\Hosts
Open it with a text editor and you'll probably find lines with the names of the sites that you can't access. Delete those lines, save the file, and try again. If those are the only lines in the file, delete the file. Be sure to save it with a file name of just Hosts, with no file type. If your editor saves it as Hosts.txt, rename it to just Hosts.
The Hosts file can be created by "web accelerator" programs that store name-to-IP address translations. This might speed up access by a tiny amount, but it causes problems when a site's IP address changes.
Problem: A shared disk or folder doesn’t appear in My Network Places
Description: The disk or folder is shared correctly on another computer, but it doesn’t appear.
Solution 1: Click Add a network place and follow the prompts to add it. Browse to it through Entire Network, or specify the path name using the form \\computer\share.
Solution 2: Click View workgroup computers, then click the computer that has the shared disk or folder.
Problem: XP's Network Setup Wizard Says That No Network Card Is Installed
Solution: XP's Network Setup Wizard sometimes fails to recognize an installed and working network card. This is because the NIC's driver program doesn't respond correctly to all of the queries that the Wizard makes when it's looking for a NIC. Configure the card’s TCP/IP properties manually. Here’s how to do it for Windows 95/98/Me <../ics/icsclient.htm>, Windows 2000 <../ics/ics_win2k_client.htm>, and Windows XP <../xp_ics/clientwiz.htm>. Then set the workgroup name to MSHOME.
Problem: Windows XP takes a long time to open a shared disk or folder on a computer running Windows 95, 98, or Me
Description: This is a different problem than My Network Places taking a long time to open <slowbrowse02.htm>. This problem occurs after you double click a shared disk or folder.
Possible Solutions:
Disable searching for scheduled tasks
This Microsoft Knowledge Base article <http://support.microsoft.com/default.aspx?scid=kb;en-us; Q245800> describes a bug in Windows 2000 Professional that might also exist in Windows XP. Disable searching for scheduled tasks by deleting this registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\
CurrentVersion\Explorer\RemoteComputer\NameSpace\
{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
· Delete stored network passwords
1. Click Control Panel | User Accounts.
2. Click your user name.
3. Click Manage my network passwords.
4. Click each entry and click Remove
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
I am running Windows 98 Second Edition and am trying to upgrade my Internet Explorer. Any Ideas?
You have not mentioned the current version of your internet explorer.
The Internet Explorer 6 with service pack 1 was the last edition that can run with Windows 98/98SE/ME
IE6 with service pack2 (the service pack can be installed separately) requires Windows XP or later.
So If you are currently on IE5 you can upgrade it to IE6 and install Service pack 1 after the upgrade. You cannot go beyond IE6 SP1 with Windows 98.
Oct 26, 2010 | Microsoft Computers & Internet
We Are Using Windows 2003 Server,But We Are Not Able To Access Server From Win XP & Win 98 Clients & Also We Are Not Able To Access Clients From Win 2003 Server. Please Help.
You must be on same domain/workgroup to see it and the computers should have an account on the server.
If not you MUST have a user account you are using on the server.
You can try to connect using the IP address of the server as such:
Go to start.run then type \\Serverip\c$ it should then ask for credentials
If not then your server is not on the network properly and you should contact a consultant in your area to configure the server
Mar 16, 2010 | Microsoft Windows Server 2003 Enterprise...
Windows cannot configure this wireless network
What OS are you running? XP? Most wireless networks are now using the WPA protocol and computers with XP that are not updated at least to SP2 will not connect to these networks even though you can see them available. I would go ahead and updated to the latest SP3 (Service Pack 3). I cant really be more helpful without knowing the OS (operating system).
Mar 02, 2010 | Computers & Internet
Windows 98 crashes while I am accessing a share from a server
The OS may not be compatible for Server 2003, The best thing that you can do here is to upgrade your operating system to Windows XP or Windows Vista for full compliant on Networking.
Jul 29, 2009 | Microsoft Windows 98 Second Edition OEM...
No connectivity after.....
If you have installed Windows XP Service Pack 2 and are experiencing any of the following symptoms, this bug is affecting your system.
After installing Windows XP SP2, your network connection reports a problem with "Limited or No Connectivity"
You have trouble connecting to the Internet or your local area network after installing Windows XP Service Pack 2.
Your network connection gets stuck "Acquiring IP Address"
Oct 18, 2008 | Computers & Internet
My router stopped working
Try to create a new connection.
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at
the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network.
Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other
end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a
standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical
outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result
in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each
other across a network, such as the Internet.
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router.
The next few pages tell you, step by step, how to configure your network settings based on the type of Windows
operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network
adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.9641e30.jpg
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.a443500.jpg
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart
your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties button.ea4fa3a.jpg
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
Connection listed). Double-click the Local Area Connection. Click the Properties button.f2e300e.jpg
button. Click the OK button again to complete the PC configuration.
If you would like more information on setting up your connection, please ask me a question.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 28, 2008 | Linksys Wireless-G WRT54G Router
2 linksys200 ? configurer sur le meme reseau
in product damage.
Overview
the Router.
Connections icon.
Jun 23, 2008 | Linksys Computers & Internet
Sony &#174; VAIO&#174; V TV-PC Series - VGC-V620G 20" TV-PC (VGCV620G20TVPC) PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
