I have never had any problems before, but now, when I go to print preview to print 12 sheets and press print, it only prints the 12th sheet. It is set to print all active sheets so I don't understand why it is happening. Help would be greatly appreciated,
My printer is a dell photo AIO 926. I have printed the same document on a previous occasion without any problems.My printer is a dell photo AIO 926. I have printed the same document on a previous occasion without any problems.
I've just uninstalled my printer now to see if that helps, but now when I try to reinstall it through the found new hardware command it can't locate it. It states that "it cannot find the necessary software" Do I have to do it manually. HELP PLEASE!I've just uninstalled my printer now to see if that helps, but now when I try to reinstall it through the found new hardware command it can't locate it. It states that "it cannot find the necessary software" Do I have to do it manually. HELP PLEASE!
You can't post conmments that contain an email address.
You need to select under print pages print all then under copies heading type in number of pages it looks like your selecting the printer tp print just one pageYou need to select under print pages print all then under copies heading type in number of pages it looks like your selecting the printer tp print just one page
hi the best thing you can do if you have had no problems before is uninstall the software that came with the printer then reinstall from scratch this will rule out the software being the problem. Also doing this will take everything back to factory settings and you will find this will solve your problem. Let me know if you can do this hi the best thing you can do if you have had no problems before is uninstall the software that came with the printer then reinstall from scratch this will rule out the software being the problem. Also doing this will take everything back to factory settings and you will find this will solve your problem. Let me know if you can do this
Do you have the software that came with it if not give shout back and ill try locate it for you. ill look anyway incase you dont have it ok Do you have the software that came with it if not give shout back and ill try locate it for you. ill look anyway incase you dont have it ok
Here is a site that has the correct software. click here try that link it should work but if not ill check it again im sure its right and its free to download also once downloaded try printing and then let me know how you get on ok Here is a site that has the correct software. click here try that link it should work but if not ill check it again im sure its right and its free to download also once downloaded try printing and then let me know how you get on ok
I get this problem sometimes. The quick answer is to put a large 'bulldog clip' around the stack of paper, and feed in one sheet by hand. When the sheet is almost printed feed in the next sheet.
The long term solution often is to service the 'rubber' paper feeds that get covered in dust. Use a damp cloth and press against one roller at a time, rotating a bit at a time. Not as easy as it sounds!
Then use a bit of fine 'sand' paper to remove the shiny surface on the roller(s) and wipe clean again.
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
First I would look at the pages in print preview, then see how much print you can get on page 1 - print current page,
after that sheet finishes printing, remove the page and turn
over for printing on the back side. Remember printers require you to insert the pages a certain way so you will
need to check that before printing the back side. Hope this helps.
There are sometimes that a printer won't print what's in print preview especially if it's not compatible with the paper size that you have set up in your printer. Try to check the printer's properties. Press CTRL + P and go to the properties of the printer. Check the paper or page set up. It should be compatible with the paper set up in your excel sheet.
First, you probably should not stop the printer after it starts printing, it always creates problems. Second, you should clear your browser history and then you should select the range of pages to print on your print properties menu. If this does not work try reinstalling the print drivers.
what application are you printing from? also, can you do a print preview to see if there are more than one page? if that works, then your printer mechanism is not following the driver information from the print queue manager.
Perhaps you have broken out the document into two or more sections? Each section has separate settings for page margins, etc. Make sure your page breaks are only page breaks and not section breaks. Hope that helps,
Usually if you see the page in the Publisher window is already landscape, it will go landscape in the Printpreview and also in the print out. I just try to imagine what is your problem.
If I am not mistaken, this is what you did:
You have two "small" pages (maybe A5??) and you want to print it in one page of A4. Of course the A4 should be landscape.
Publisher does not have the facility to set 2 pages A5 in one A4 like in Microsoft Word.
The easiest way is just create a new page with A4, then copy the 2 pages (or you called it flyers) and paste it in that A4 landscape page.
Publisher can do print 2 pages A5 in one sheet A4 but the arrangement is as booklet. You can see the choices in File --> Page Setup --> tab "Layout" --> scroll the Publication type.
I do print 2 pages A5 in one sheet with many variations using addition software named "Clickbook".
Let me know if I m wrong in interpret your problem.
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue.
Workarounds
Workaround 1
Adjust the top margin using Page Setup.
Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
Adjust the top margin until printing is correct on the label.
Workaround 2
Manually print one sheet at a time.
Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Set your printing job in print preview you can adjust inexact spaces in four corner of sheet of papers./ do't print w/out prvieew
it will wasting ink and papers.
