Question about Hitachi 61SDX01B 61" Rear Projection Television
Rear projection tv
How do you remove the screen on a Philips mod.#46PP930217 year 2003 rear projection tv for cleaning. need to remove screen to clean small bugs and dust mirrors.
  • David Menn Mar 06, 2008
    Is this the procedure for removing the screen on the Hitachi 61sdx01b model year 2003.
    Guru:
  • 1,894 Answers
Hello sir
how old is your TV
Posted on Mar 05, 2008
  • dewan nafees ahmed Mar 05, 2008
    look for screws in your front panel...
    if not remove all the screws in your back panel..
    it will easily remove the cover..
    now use a vacuum cleaners.. don't remove the anything else..
    if this is done then screen also can be removed easily..
    thank you
    good luck
    dont forget to rate the solutions
How do I get to the bulbs to clean them? I have a 65 inch flat screen rear projection tv which I purchased brand new about 8 years ago.
Unplug the TV.Remove the back cover.Gently wipe the three guns and the white screen.Reasssmble.By the way vacuum the chassis while you there
Oct 18, 2009 | Philips Magnavox 51MP392H Rear Projection...
How do I take the front screen off to clean the bugs out? Philips 60PP9100D-37 60" Widescreen Projection TV
First: do not take front screen off for cleaning--easy way is to remove entire black plastic shroud (you look at back of set and you will see 2 silver pegs near top edge) This set uses torks type screws---you need to remove several and the entire upper plastic in back comes off. The mirror is suspended separate from this.With the shroud removed you can clean the lens of the 3 picture tubes or any debris on the inside of the screen----do not use glass cleaner on the screen; but if you have smudges or bugs on the inside just use a very fine soft cloth(you may need to moisten it slightly) Any mark you make will show! If you find you have spider webs use a swiffer type duster to remove them.
I do this here for free so if this was helpful give me a vote here. If you have questions or need help let me know.
Aug 03, 2009 | Philips 60PP9200D Television
Red will not line up on a philips mod 46pp930217 and i can't get the color to ajust
Your convergence chips have failed and need to be replaced. You can get the parts and instructions from www.TvRepairKits.com
Apr 30, 2009 | Philips 46PP9302 46" Rear Projection...
Bugs in my tv
YES!
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Jan 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
How to clean inside of screen?
Your tv has two screens on it. The outter screen and the inner screen. The outter screen has a frame around it held on by clips. You can remove this outter screen by gently prying it from the tv. There is a small gape between the outter screen and the tv casing. When prying the outter screen be carefull not to dsanage the tv case or the outter screen frame. Take note of the location of each clips because you will need thses to put the outter screen back on. Clean with a good gentle screen cleaner, (Do Not Use Windex). Philips screen cleaning gel for plasma & LCD works very good. Install the outter screen back on the tv by making sure the clips line up and use light pressure to snap it back in place. Do Not Hit Outter Screen To Force Clips Into Place.. I do this on my tv about once every 6 months or so.
Jan 04, 2009 | RCA P61960 61" Rear Projection Television
Spider in my tv
no way to prevent....but screens will need removal and clean inside....aarons has service dept for this....good luck...
Jul 29, 2008 | RCA HD52W56 52" Rear Projection HDTV
How to clean 50 in rear projection tv
For the screen Philips make projection screen cleaner this is a spray with brush that is made for cleaning tv. The CRT's you can use some type of glass cleaner, not to waste on board.
Oct 05, 2007 | Philips 50P8341 50" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
164 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
