Help my second hard drive dont show up
I installed my 500 gb sata harddrive in my dell 3100 dimension computer and its a second hard drive for storage, its not showing up anywhere as a new drive
  • rngmstr6976 Mar 06, 2008
    i had to go to my bios and activate my sata drives, i hope thats helpfull to somebody
  • Anonymous Mar 15, 2014
    I have a Dell Dimension 3100 which will not start up - only lights 3 and 4 showing on the display
    Scholar:
  • 80 Answers
Hi
Make sure it is connected properly.
Then go to Disk Management by typing "diskmgmt.msc" in the Run window.
Then check in Disk Management if there is any unassigned or any uninitialised partition there.
If you find one, right click on it and then select either "Format" or "Initialise".
Posted on Mar 05, 2008
Remove hard disc from dimension 3100c
David, this is the Service Manual for the Dell Dimension 3100 Desktop PC,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Click on Removing and Installing Parts.
Click on Harddrive
1) Pull the SATA power cable out of the back of the Harddrive,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
[ Note the L-shaped slot in the connector. Lines up with the L-shaped tab on the back if the Harddrive ]
2) Pull the SATA data cable out of the back of the Harddrive,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
[Top example is a SATA data cable. The bottom example is a SATA connector on the motherboard. Again note the L-shape in the connector.
The SATA power cable connector has 15 contact pins.
The SATA data cable connector has 7 ]
3) Now press the blue tabs (Clips) towards each other.
(Can also be said as -> Towards the middle of the harddrive )
4) Pull up, and out on the harddrive.
If I may ask, why are you removing it?
Post back in a Comment.
Regards,
joecoolvette
Jul 26, 2012 | Dell Dimension 3100 PC Desktop
Hi, I have destop[ dell pentium R 4 cpu 3 GHz 1.99 GB of ram and 40 GB rom . I want to now if can change the hard disk and put another of 160 GB. tanks you carlos.
A) If you have the Restoration Disk (CD), or a full installation disk of the Windows operating system, the answer is yes.
B) If you have an image backup program, such as Norton Ghost, Acronis True Image, or DriveImage XML, for example, the answer is yes.
The Windows operating system is copied over to the new harddrive.
It would be easier, and more cost effective to just install the 160GB harddrive as a Slave drive.
I don't know if your harddrive is an IDE (PATA) unit, or a SATA unit.
Here is more information on installing either an IDE harddrive, or a SATA harddrive, as a Slave drive in a desktop computer,
1) IDE {PATA} harddrive:
http://www.youtube.com/watch?v=4inX3nC6M1E
1A) http://www.youtube.com/watch?v=OMTOgt3UiB4
2) SATA harddrive:
http://www.youtube.com/watch?v=kCgFYNLzn18&NR=1
IDE, also known as PATA is the older style of technology.
SATA is the newer style.
(Parallel ATA
Serial ATA )
The beauty of SATA is not only the faster speed, but if you connect a SATA cable (Data cable) to ANY SATA connector on the motherboard, BIOS will find the device.
BIOS (Basic Input/Output System) will find the harddrive with the operating system on it, first.
Then it will recognize that you have a second SATA harddrive also.
(BIOS looks at both SATA harddrives.
When it finds the one with the operating system on it, BIOS will disregard the other SATA harddrive)
http://www.youtube.com/watch?v=ScqDZZeFK9I
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 17, 2011 | Dell Computers & Internet
Hi, I have a maxtor personal storage 3100 on which I have data that has been stored from my Dell Dimension computer that has XP. I want to transfer the information to my new DELL Studio computer with...
this message comes mostly due to the nonavailability of the drivers. so i would request you to first install the drivers of your maxtor personal storage 3100 to your DELL studio computer, then connect your maxtor storage to your DELL computer. this should fix your fix your issue.
Dec 08, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
I want to install a seond hard drive in computer
can you please open up the CPU and check one thing? Is there any Free port in this cable? One end will be connected to the motherboard and two others to (1)CD/DVD rom and (2) Hard drive.
If there is free, surely you can add one. Please then look for a place where you can place your (ATA not the sata one) harddrive.
Apr 05, 2009 | Dell Dimension 4300S (Refurbished)...
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Nothing shows up
you might made some disturbance in power system, check all power cables, then the data cable of hd,
Oct 26, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hard Drive Installation
The Dimension 2400 does not have SATA ports. Therefore, you need to purchase a SATA card to do this. Something just like this.
Jul 05, 2008 | Computers & Internet
Drive 0 not found;serial ATA,SATA-0
are you SURE you connected up the power connector in addition to the SATA connector? If so, you may have hozed your drive.
Feb 06, 2008 | Dell Dimension 3100 PC Desktop
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Computers & Internet Logo
472 people viewed this question
David Payne
David Payne
