Question about Sony Ericsson K800i Cellular Phone
Problem sending msgs
I have a problem at the moment with sending msgs. When I go to send a msg, a msg comes up to say 'Too many messages. Delete some from any folder'. Then when you advance, there is only 1 msg in either my inbox or sent items folder. Once this is deleted, I can send the msg. Then it will not allow me to send anymore as it brings up the same msg but I only have 1 msg in my sent items. I am only receiving 1 msg at any time. I use a memory stick but it does the same thing when the memory stick is removed. What is going on?
  • 29 Answers
SMS and picture messages are not stored on the memory stick.
Sony Ericsson phones have a set allotted memory space for messages and other phone functions.
You may need to delete picture messages, check if you have any saved messages (these are saved to your SIM).
Generally, the only other option would be to reset your phone.
To do a master reset, go to your Menu, then select Settings. Under the General tab, scroll down to Master reset and press select. Select Reset All and press yes.
If prompted, the default passcode is 0000.
Please note that a Master Reset will return the phone to its factory default settings (including locking a phone to the carrier if it has been unlocked). All user data and settings will be deleted. If you have any files or information you would like to save, you should either back it up to a memory stick or your computer. Your contacts can be backed up to the memory stick or your SIM card.
Posted on Mar 07, 2008
With one friend on ICQ I can receive messages but when I reply I get a red sign that says
cant send icq msgs to offline contacts for one , another could be sending too big of a msg,, and it is incompatable with aim or miranda software
Apr 27, 2012 | ICQ Instant Messenger
I can not send any message.I can call and I still got messages from my friends but i can't send any message.and i got olso credit.
Hi Koles,
Pls check following:
Is your msg saved in phone memory are very high in number, if yes, pls delete a few which are not required.
Check the msg center number if saved properly. Even if yes, try to delete it and re-enter it.
Delete msgs which are saved in drafts.
Remove your sim and insert once above steps are done.
Wait a while and hope this should work for you. Else pls try and contact your service provide to check the issue.
Take your time and rank me if I helped you.
Jun 10, 2011 | Nokia 1110i Cellular Phone
I hav d nokia E63..! & i cannot send any msgs.....it says "memory full , close some applications first...(& i hav absolutely no applications on except messaging)...... before it said that...
hi, the memory might truly be full...check your memory status and see if truly it is full....if after checking, you realized that it is full, then you will have to delete some messages and delete some applications that you use less often..but, if you check your memory status and you realize you still have space, then it means you will have to scan for virus.
cheers
Mar 16, 2011 | Nokia E63 Cell Phone
Hello i can not send picture messages is there anything u can do to help me solce this thanks
To send pic msgs you need to have MMS activated on your phone. If it is activated then there is no way that you would not be able to send pic msgs. Please contact the helpline of your service provider and ask them to activate the MMS on your number. When they do it, they will send a msg to you with the settings. Only after you save this msg that the MMS would be available to you on your phone.
Aug 24, 2010 | LG KC910 Renoir Cell Phone
My mobile says that ur message memory is full please delete your emails and messages
to solve this problem u have to create a folder in msg
1. go to msg
2.click to my folder.
3. then create a folder there
4. then select your msges by multiple select and send them to the folder you create.
5.delete unwanted msgs.
6.switch off ur phn then on.....
7.it works
Jun 24, 2010 | Motorola Mobility ROKR E8 Cellular Phone
Cannot sent text messages but can receive them
What is the error you are getting while sending the message..?? try restarting your mobile.
Nov 12, 2009 | Nokia 6300 Cellular Phone
Unable to send text messages on my new nokia 5800
All you have to do is go to your message setting on your phone:
1. Open Messaging
2. On New message sellect options at bottom
3. Open settings
4. Open Text message, you should see: Message centre, message centre in use ect..
5. Open message centres this should go to next screen then open again, this screen should have : Message centre name & Message centre number (from your network provider you need to find out what is the message centres name & number are e.g in Australia it should be SMSC1 and number is +61411990001) then just manually enter these in there.
Feb 26, 2009 | Nokia 5800 XpressMusic Smartphone
Msg transfer probleam
hi no need to delete ur msgs. jus transfer all ur messages to drafts
Jan 19, 2009 | Nokia N72 Cellular Phone
When sending a text msg, it goes to outbox, wont send
I had the same problem and I read on down and saw someone's phone was stuck in flight mode. I remembered that for some reason, my phone was in flight mode the other day, so I went in and took it off. I realized the problem had been since that time. So, I put the phone back in flight mode and was able to delete the message from my outbox. I put it back in normal mode and now I can send texts. Yes!!!!
Nov 29, 2008 | Sony Ericsson w580i Cellular Phone
Msgs - Too many msgs!!!!
Mar 05, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
184 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
