Question about Kitchen Ranges
AEG COMPETENCE B1400-1 PNC 944181739
I have an AEG competence B4100-1 oven PNC 944 181 739 which has decided to stop heating up past 50c on the fan assisted program, the light is on the fan still rotates and the coventional cooking still works, could my heating element around the fan have died and is it a part I could fit myself ?
Back ground of when this happened the oven was on for 30-45 mins and this tripped the trip switch on the electrical curcuit.
Many thanks
A
  • AKASHNEE Mar 06, 2008
    OVEN DOES NOT HEAT UP EVENHOUGH THE THERMOCOUPLE HAS BEEN CHANGED.
  • Anonymous Jun 06, 2008
    Would like to know how to fit a new element to my belling DB92 fan oven
  • 3 Answers
SOURCE: oven cuts out
Most of the time it is a temp sensor in the oven. We bought a service manual at houseneeds.com and fixed ours.
Posted on Nov 30, 2008
skyblue67
  • 71 Answers
SOURCE: instructions fr AEG competence 321 V-D
Hi you can download your manual here
http://www.manualshark.org/m/aeg-competence-321-v-d-instruction-manual-u03073-product-number-code-611251913-10108/
good luck
Posted on Jul 25, 2009
  • 969 Answers
SOURCE: i get an f8 error code on my touch pad on my
http://www.applianceaid.com/fault_codes.html
Posted on Nov 12, 2009
barkencoa
  • 3463 Answers
SOURCE: Oven is AEG Competence, single oven, fan assisted,
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
Posted on Jan 06, 2010
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Posted on Feb 05, 2010
Where is the model no on our aeg white double oven competence about 8 years old
Open the door, usually engraved within the door panel. Either on the sides or Top.
Most important number is called the PNC. If not found there, look for a sticker on the Oven Cabinet upper, after opening the door.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Feb 16, 2011 | AEG Ovens
Competence 5208B, fan oven blows cold and won't heat up, ordinary (non fan) oven does get hot
Hi.
You need to replace the oven element, located at the rear of the oven compartment behind a removeable cover.
Nov 09, 2010 | AEG Ovens
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
Hope this helps.
Feb 05, 2010 | AEG Ovens
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
Thankyou.
Jan 06, 2010 | AEG Ovens
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
Oven cuts out
Nov 30, 2008 | Ovens
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
Kitchen Ranges Logo
520 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
