Question about HP PSC 2210 All-In-One InkJet Printer
Cannot open hp director
Purchased a new laptop and installed the software. laptop is a Toshiba equium. could not open the director therefore replaced disc to make sure it had been installed correctly. info came back on screen that said the software had been correctly installed.
Help!!!
Tony.
  • wetwang Mar 13, 2008
    Thanks a lot, I am now sorted. Great to have it working fully again.
    Genius:
  • 3,587 Answers
It's not unusual to get an older set of drivers with a new computer. See if new drivers from here work for you
Posted on Mar 05, 2008
I accidentally deleted my hp director icon from my computer i dont know how to restore my hp director
If you have just deleted the icon from desktop and not uninstalled then we can put a shortcut back on desktop
Click on START button
click on MY Computer
OR
Open MY Computer icon from Desktop
Open Local Disk C:\
Open Program Files
Open HP Folder
Open Bin Folder
You will find a file by name HPDIREC
Right click on the file name and Click create shortcut on desktop ( this icon will not look exactly like the HP Director icon you deleted )
Close the window and you will find the HP Direct icon on desktop
If not, you can uninstall the software from Add/remove programs under control panel and install the latest software for your printer. Click on the download button below to open HP website to download the software by selecting your operating system
Download
*Note : HP Director is not longer designed by HP. IT is replaced with a new Software called HP Solution Center
Oct 21, 2010 | HP PSC 2210 All-In-One InkJet Printer
My Equium A200-1V0 fan stopped working
The User's Guide is available on this page on the Toshiba website, under the User's Manual tab.
I have also compiled a tip for dealing with overheating issues on Laptops as that is a common issue.
You may please refer to this link for reviewing the same.
May 10, 2010 | Toshiba Satellite A100-S8111TD Notebook
Hi, just thought I'd let you know that when I got my Toshiba Equium 200-1V0 it was supplied with the User's Manual A210 Series. The manual is just basic and does not go into full depth of how to clean out heat sink etc. The problem you described regarding the shutting down is most probably that the heat sink is clogged up with dust and needs to be cleaned. Toshiba has a lot of laptops (different models) with this problem. I had the same problem with Toshiba A200-1V0 and have now got the same problem with the Toshiba A300D-20R which is only 6 months old! On the A200-1V0 I managed to hoover the bottom of the laptop where the fan is and it worked fine, but with the A300D-20R it has not worked, but fortunately it's still under guarantee so I will be sending it back to Toshiba to do it. Here is a link to download the Manuals. You will find the Manual for A200-1V0. Hope this helps. http://uk.computers.toshiba-europe.com/innovation/download_manuals.jsp?service=UK
Mar 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
Hp director does not open when i click on the icon
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
2-Without navigating to another open window, press Alt and Space bar at the same time.
The Shortcut menu displays near the top-left corner of the computer.
Figure 1: Shortcut menu
If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
3-Select Minimize from the Shortcut menu.
HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen).
If HP Director does not minimize, click Minimize again until it does.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Nov 30, 2009 | Computers & Internet
WHERE COULD I DOWNLOAD THE HP DIRECTOR SOFTWARE
Hi go to hp site find utiliity section for this printer
Sep 03, 2008 | HP Officejet 5510 All-In-One Thermal...
Hp 6110 all in one hp director not working.
try to do the following:
1. Double-click the HP Director icon to load the program into the memory. You will not see HP Director open at this step. Do not click anything else on the screen until Step 2 is completed.
2. Press the Alt key and the Space bar together, and then
select Minimize from the menu that displays in the upper left corner of the window. If necessary, click it again until HP Director minimizes.
The HP Director software now appears as an item on the Task Bar .
3. Click HP Director on the Task Bar . The software opens and displays normally.
4. Repeat Steps 1 through 3 every time the HP Director software is used.
or
  1. Go to the HP Software Download Page .
  2. In the Enter a product number text box, type the printer model, and then press Enter .
  3. Under Product search results , select the printer model.
  4. Select the operating system.
  5. Under Update , click Critical update to resolve an issue with HP Director after installing Internet Explorer 7 .
  6. Follow the instructions that display on the screen to install the update.
Cause:
In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software, does not exhibit this issue with Internet Explorer 7.
Sep 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Director won't open. I am on XP and IE7
HP Director has a flaw and is not compatible with IE7
I have a psc 1100 and I had to update my software from HP
CHECK THIS OUT
Go to HP, this link, type in your printer model #.
It still may fail to show...if it does not show HP recommends this
work around.
Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Apr 30, 2008 | Computers & Internet
HP PSC 1315
If the patch or the updates did not work on the link I sent you try this Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
Mar 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp director
It could be about this: I had same problem until I found a review somewhere - even HP technical support was totally useless - until HP FINALLY decided to up date its drivers to account for my/many people's downloading of Internet Explorer 7. As this is now done, and you cannot easily uninstall IE7 and go back to IE6: try again (1) HP Director and if not (2) I think update drivers or (3) uninstall / reinstall. Hope it helps.
Apr 04, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
51 people viewed this question
Ben Johnson
