Question about NAD T753 Receiver
NAD T753 5.1 Channels Receiver Problem
Unit keeps switching itself off every few minutes. Works fine when you switch it back on then it goes off again. All connections appear to be fine.
  • Anonymous Oct 04, 2008
    i had same problem , they had to resolder power supply , connectors and board . ?
  • Anonymous Mar 29, 2014
    After static electric shock when I went to turn the volume up the listening selector switched over to tuner and no sound or light (on selector). I powered the unit down & unplugged the unit for a few minutes. I powered the unit back up and sound and selector light appeared, but it would not switch to any other source.
    Master:
  • 518 Answers
It could be a heat issue, is the receiver able to get air to cool itself? Also, a bad speaker or mismatched speaker may cause this. Sometimes hooking up extra speakers may cause this. Other than that, it would be a service issue.
Geno
Posted on Mar 05, 2008
Not switching on!
A short has transpired before the fuse. Now in protect mode. See a tech.
Mar 22, 2014 | Teac AG-980 4 Channels Receiver
My Sony STR-DG920 shuts off then comes back on by itself every 4-5 minutes. It very quickly loses power then comes back online. Any ideas what might be the problem?
The problem is the Power Switch. The switch on the STRDGF920 is very problematic. When the receiver is on very lightly move around the power switch with your finger. do not use enough pressure to turn the unit off. Just very lightly slide your finger over the switch and you will see your problem happen. I have two STRDG920 units with the same problem. One is so sensitive I can blow on the switch and it will power cycle off and on. I have called Sony and they said they do not offer a replacement part power switch. I will have to figure something out.
Aug 08, 2011 | Sony STR-DG920 7.1 Channels Receiver
My NAD T743 will not switch on. I haven't used for a couple of months and it was working just fine before. Now I tried switching it on using both the power button on the amp itself and the remote, to no...
Hi, have you checked the power button in the back to see if it got pressed by accident? It's a round button located right under the speaker inputs in the back.
Apr 11, 2010 | NAD T743 Receiver
Nad C320 right channel stops working then comes back again
This sounds like the "pre-amp" section is cutting out or there is some interruption in the signal path. A few things to try:
1) With the unit off, try "working" the volume,balance and tone controls. This means, turn them up and down a number of times to clear any debris that may be in the controls themselves.
2) Work the input selector switch the same way if it is a rotary switch.
3) Try turning on/off the tape monitor switch a few times.
4) Keep track of whether this problem is sensitive to heat. Does teh channel shut down more quickly once the unit has been on for a while?
Lastly, if you can solder, look for any solder joint that appears grainy or has rings and resolder it.
Update this with your results and we'll continue on...
Thanks,
Dan
Jan 15, 2009 | NAD C320 2-Channel Amplifier
SAP turns on automatically on a few channels
maybe the switches of your tv are malfunction
Jun 01, 2008 | RCA TruFlat 27F520T 27" TV
NAD CI 9120 (12 Channel)
Check all your cables, not likely but just in case.
Try removing all but two. Left and Right. Does it still happen,
If you can identify the speaker channel try swapping the speaker if possible.
It sounds like one of the speakers has an issue, could be a short in a cross over or speaker coil. If true the speaker is drawing too much current and causes the protect circuit to trip.
Depending on the quality either replace the blown speaker driver or purchase new ones.
If the speaker is not the issue it could be an issue with a power amp. Best to take it in for service.
Mar 19, 2008 | NAD C720BEE Receiver
Orion tv32RN10D Digital problems
factory reset hold volume button on tv down all the way while holding it down hold number 1 on your remote goes to stanby turn back on..
Jan 08, 2008 | Orion HDLCDVD225 22 in. LCD TV
NAD T762 - no sound
Try reseating the prologic/output board. Second one from the right (from the front of the reciever), that fixed my no sound problems on many channels. You will have to take out a few screws to remove and reseat it, and while you are at it clean the connections.
Sep 08, 2007 | NAD T762 Receiver
Receiver shuts down and will not turn back on untill you unplug and plug back in
Nope. sorry to burst your bubble but your problem is pretty common on this unit. Its bad capacitors in the power supply and probably not worth repairing in a repair shop. since this is a solid state reciver, there are no user replaceable parts inside.
Sep 24, 2006 | Harman Kardon AVR 235 Receiver
NAD T753 Receiver Logo
553 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
