Xerox Phaser 6110 claims new toner cartridge is empty
The printer is constantly claiming that it is out of red toner and requests
a new cartridge. however even after trying 2 new cartridges it is still saying
that the red is empty.
from time to time it still prints a colored page if you try immediately after turning it on.
  • thomas1bln May 13, 2008
    We have exactly the same problem with our Xerox Phaser 6110. Tried to change the yellow toner. Installed the new one, the printer did not recognize it, installed a second new one, the printer did not recognize either. The toner cartridges, as well as the printer are of course original Xerox, but do not work.
  • 37 Answers
Could be many things...depends on the exact nature of the problem. Where the machine states "Invalid Toner" either the machine itself or the toner cartridge may be the wrong "region". i.e. has been sold in the wrong country..the initial toners will work but as soon as you put new ones in they will give this message. If the machine is still displaying "out of toner" then either the toner cart itself is faulty (assuming they are original Xerox carts) or the Image Unit could be faulty (the bit they plug into). Failing that, it will be a faulty Main PCB. The Toners on these have a crum chip, so they cannot be just re-filled and some that may seem "compatable" will not work either.....
Posted on Jun 30, 2008
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Program to reset unit imaging xerox phaser 6110 please
Image units can't be reset by software. There is a chip that needs to be replaced on the cartridge if you refill it with new toner. It should be available from the same place you got the toner. (I assume you refilled it and it still says it is out of toner)
Dec 01, 2011 | Xerox Phaser 6110 Laser Printer
When the red light blinks on the printer what does it indicate-model-xerox phaser printer 6110
The blinking toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner. See "Redistributing Toner" on page 5.2
from the manual online as pdf: http://download.support.xerox.com/pub/docs/6110/userdocs/any-os/en/Guide_XP.pdf
Apr 06, 2011 | Xerox Phaser 6110 Laser Printer
Red in xerox 6110
check the waste toner (it's on the left side of drum unit when you open the front cover) cartridge or paper jam if blinking!
Dec 04, 2009 | Xerox Phaser 6110 Laser Printer
Need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Aug 08, 2009 | Xerox Phaser 3100MFP/S Laser Printer
I just replaced the toners kits but the red and yelow ones are still on red. If I try to print it says thjat yelow and magenta toner kits are nvalid
Replace the color toner cartridge with a
new one
1.Take out the toner cartridge and thoroughly shake. In doing so, you can clean the inside of the Imaging Unit
Jun 11, 2009 | Xerox Phaser 6110 Laser Printer
Noise after change color cartridges
is the toner cartridge and have a manufacturing defect or the toner cartridge scouer adaptable and look
Mar 07, 2009 | Xerox Phaser 6110 Laser Printer
1,156 people viewed this question
jasbo
jasbo
