Question about Sewing Machines
Sewing Machine Zig-zag Tension
My Singer Capri had been 'got at' before I bought it second-hand.
It did not pick up the bobbin thread.
I have worked on it and now can pick up the bobbin thread but the zig-zag is wierd; there are loops on both sides of the cloth, one row on each side, as though the tension is not correct.
I would very much like to get the details for setting the bobbin-hook timing, please.
I am finding out about the mechanics of the machine when I really just wanted to make kites for the grandchildren [? & me].
Stephen
  • Sewing Machines Master
  • 12,513 Answers
You can search for sewing machine timing or take it for service.
HINT; when threading the top thread, ALWAYS RAISE the presser foot! This will allow the thread to seat completely in the tension disk.
Posted on Apr 27, 2017
    Habit-Forming:
  • 64 Answers
As you stated, the machine had been 'got at' before you purchased it. Therefore you have no way of knowing What was actually done that may be causing your current difficulty.
Tension is a tricky thing with any machine, particularly one that has been 'adjusted' without the specifications.
Your best bet is to find a person who is experienced with older-style Singers. Most of the information for these is still in the hands of people who know and have worked on Singer machines for a long time.
Posted on Apr 26, 2017
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
  • 7 Answers
SOURCE: How do i set thread tension on a 306W Singer
Top tension about 4 or 5, make sure the presser foot is up when you theread the machine, make sure you can just pull the bobbin thread through with some slight resistence, if it is too tight slacken the screw on the bobbin case a quarter of a turn at a time anti clockwise.
Posted on May 06, 2009
  • 8 Answers
SOURCE: Singer Athena 2000 won't zig zag
Try pushing the reset button underneath the machine. Mine does that too. I had it repaired a few months ago...apparently it needs a circuit board that is no longer available.
Posted on Aug 01, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
Zenqi
  • 208 Answers
SOURCE: I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Posted on Aug 21, 2009
I am trying to replace monofilm panels in a windsurfing sail, using a Singer 457 zig zag sewing machine. I cannot create a good zig zag seam when the monofilm is sandwiched between two canvas layers.
Joe, you might try a larger needle than you're using. You might also want to try a larger leather needle. You machine should take needles up to a size 18.
It sounds like the needle you're using is having a problem picking up the bobbin thread, and that might solve it.
Mar 09, 2017 | Singer Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
How to thread childs singer zig zag sewing machine
You didn't give the model name for the machine; however, if it's a Pixie or Pixie Plus, you can download the user's manual that shows you how to thread it and wind a bobbin from the Singer Sewing Machine site. The number listed above your question is not a legitimate model number; it might be a serial number.
Feb 01, 2015 | Singer Zig Zag 727198 Sewing Machine
Singer 7469 will not zigzag
it's possible that a gear or inside cam could be worn or broke, the machine needs to be serviced
Mar 08, 2012 | Singer 7469Q Computerized Sewing Machine
I just bought my first sewing machine, its a touch & sew duel zig zag sewing machine/model 758 i dont know how to thread it or the bobbin
Call Singer at 1-800-4singer and see if they will send you a manual, in the mean time google how to thread a sewing machine and there are some great videos available for free.
Apr 21, 2011 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Show me how to use singer sewing machine57815
You can download a manual from http://www.singerco.com/accessories/manuals.html, just type your model number into the search field to locate it then download the pdf file to your PC. This is a basic Zig zag machine so carefully follow the manual instructions to wind a bobbin, thread up and stitch, just make sure you follow the directions to wind a bobbin, and then put it in the right way and click the thread into the tension spring.
Dec 08, 2010 | Singer 57815 Mechanical Sewing Machine
Aug 20, 2009 | Sewing Machines
Aug 16, 2009 | Singer Quantum XL-5000 Computerized Sewing...
How do i set thread tension on a 306W Singer Zig-zag? Bottom thread all loopy.
May 05, 2009 | Singer 8280 Mechanical Sewing Machine
Sewing Machines Logo
248 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
