Sound problems Just got a new computer (windows vista), all the sound levels are turned up but I still can barely hear anything. Would using speakers that are 4 years old be the problem? as well when I play video's from you tube everyone sounds like a chipmunk talking really fast. Any help would be greatly appreciated!! Thanks
  • tamwiser Mar 05, 2008
    thanks for your help I am a total rookie and I am not even sure where all the information is to fix it, I will have to get someone over to show me as I have no idea where the master sound utility is etc...
  • 75 Answers
Turn off the master sound utility programme (not mute option,like soundman,HD audiodeck etc ),if your problem solve turn on the utility and re arrange the eqalizer,also u can check with other speaker
regards
prasanna
Posted on Mar 05, 2008
My tv has no sound
increase the volume to max level .close yourself to TV speaker and listen.if could not hear anything,just turn it off and turn on if you could not hear at least pop sound from the speaker,you will have to replace new speaker.if you are able to hear Buzz noise or very low sound ,sound circuit has to be repaired.
Jun 15, 2011 | JVC Televison & Video
I have 2 polk audio speakers that when they are connected you can barely hear the sound coming out of them with the volume turned up.
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
also you might need to unistall the sound card and its drivers restart your computer then reinstall them
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question or exclamation mark ! ? or red x right click to re-install drivers
cnetdowload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html
http://www.freeware-downloads.com/soundmax_integrated_digital_audio_driver_v.htm
SoundMax Integrated Digital Audio Driver v hope one of these helps
May 28, 2011 | Computers & Internet
No sound on dell dimension 4700c
There can be more than one reason, why the computer can't play any sounds. These are discussed below:
If you have a desktop computer, it may or may not have a separate sound card. But in case of laptops, the sound card is integrated into the motherboard and cannot be removed, so some of the solutions may not apply to laptops. Also, new laptops come with built-in speakers, so the external speakers and cabling problems may not apply here, unless you use external speakers or headphones.
So, where do you start, when you can’t hear any sounds from your computer?
Before we start with the solutions, did you try the simplest solution first? Rebooting or restarting the computer is the simplest solution and should be tried first. If you didn’t already reboot, try it now. The sounds may just work after a reboot.
Can you hear the Windows startup sounds from the computer? If you can hear the Windows startup sounds, the sound card is working fine. If you can’t hear any startup sounds, enable the System Sounds in the Control Panel, if they are disabled. If you aren’t able to enable the system sounds and they are grayed out, you may need to install the sound driver.
Are you trying to play an audio CD, and not getting any sound? If you can hear the System Sounds, but can’t hear anything from the audio CD, even though your audio player software tells that it’s playing the disc, the problem is most likely with the digital cable that goes from the CD/DVD driver to the sound card (or to the motherboard).
One side of this cable goes into the back of the CD/DVD drive and the other goes into the sound card or on to the motherboard (in case of motherboards with built-in sound).
Are the speakers connected to the proper sound port / jack, at the back of the computer? Are they powered ON? External speakers generally have a separate power adapter, which plugs into the wall socket or any other power source. Is the speaker volume control, set to a comfortable level? If not, turn it to the middle position.
If in doubt, test your speakers by connecting them to another sound device like CD/DVD player or a radio/tape player, or any sound source. If you can hear sounds from the speakers, they are fine.
Check that the speaker pin is connected to the green jack on the back of the computer. Also, check that the sound (check speaker icon in the system tray) isn’t muted. Such a simple thing, which can happen accidentally, can confuse some people when they can’t hear sounds from their computers. This can get overlooked because the speaker icon may be lost between many other icons. Click it and un-mute the sound, if it’s muted.
Note: If you can’t see the speaker icon in the system tray, you may need to enable it from the Control Panel. From the Control Panel, double-click “Sound and Audio Devices” and check the box that says “Place volume icon in the taskbar” and click OK.
Try plugging in a pair of headphones in place of the speakers, to check whether you can hear anything. Play a song or music CD or any sound file, which you may have on the computer. If you don’t have one handy, you can run a command to test your sound:
Click the Start button, and then click Run (or Search, in Windows 7 / Vista). Type the following command and then press the Enter key: dxdiag
Click on the ‘Sound’ tab to see the details of your sound card. You can also test your sound card from this tab. Note the name of the sound card and the manufacturer, on a piece of paper.
If you can’t see the name of the sound driver, or aren’t able to hear the sound by using the ‘Test DirectSound’ button, or you get an error, the problem may be with the sound driver. If the sound worked sometime ago and now it isn’t working for some reason, the simplest solution for re-installing the sound driver is to do a System Restore. Restore the system to a date that you know, when your sound worked. Check out the following links for a short tutorial on System Restore
Note: Current documents, files and e-mail are not affected by System Restore. If you get an error like “Restoration Incomplete. Your computer cannot be restored“, undo the last action by selecting “Undo my last restoration”.
Here’s a youtube video on how to restore a system with System Restore: http://www.youtube.com/watch?v=mU5yqvye57E
Here are step-by-step tutorials on System Restore:
For Windows XP:
http://www.howtogeek.com/howto/windows/using-system-restore-in-xp/
http://www.5starsupport.com/faq/xp-system-restore.htm
For Windows 7 or Vista:
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
http://www.vistax64.com/tutorials/76905-system-restore-how.html
For more information about System Restore, visit the following links:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
http://support.microsoft.com/kb/306084http://en.wikipedia.org/wiki/System_Restore
http://windows.microsoft.com/en-US/windows-vista/System-Restore-frequently-asked-questions
If System Restore didn’t help or you get a message that System Restore couldn’t be completed, try the following:
Start the Device Manager (Start -> Run -> devmgmt.msc and hit the Enter key). In Device Manager, Click the + sign next to “Sound, video and game controllers”. See that the sound driver that you noted from dxdiag above, is listed.
Doube-click this sound driver. Device Manager should give a status message that the driver is working fine. If the driver isn’t there or if it shows a yellow exclamation mark, shows under other devices, or gives any other kind of status message, reinstall the driver. In any case, it doesn’t harm to uninstall and reinstall the driver.
From this sound driver properties page, you may also click the Troubleshoot button, to open the Sound Troubleshooter in the Windows Help and Support Center.
You can also visit the following link about tips for fixing common sound problems:
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-sound-problems
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
May 03, 2010 | Dell Dimension 4700C PC Desktop
Sound is not coming from attached speakers I have window xp and ''zoltrixound'' speakers
There can be more than one reason, why the computer can’t play any sounds. These are discussed below:
Before we start with the solutions, did you try the simplest solution first? Reboot or restart the computer. The sounds may just work after a reboot.
For Windows XP: http://www.howtogeek.com/howto/windows/using-system-restore-in-xp/ http://www.5starsupport.com/faq/xp-system-restore.htm
For Windows 7 or Vista: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/ http://www.vistax64.com/tutorials/76905-system-restore-how.html
For more information about System Restore, visit the following links: http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx http://support.microsoft.com/kb/306084http://en.wikipedia.org/wiki/System_Restore http://windows.microsoft.com/en-US/windows-vista/System-Restore-frequently-asked-questions
Hope that helps,
Regards,
Raspal
May 02, 2010 | Audio Players & Recorders
I didn't able to hear sound in my computer from speakers and headphones.
For Windows XP:
Hope that helps,
Regards,
Raspal
May 02, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have a new acer comp with vista and am trying to use my old yahama tstm15 speakers and cant get no sound
are you sure that you plug wares in the right place?
GREEN:sound
BLUE: ? no ideas
PINK/RED:mic
or they are just broken..
Jul 22, 2009 | Yamaha YST-M15 Computer Speakers
MIC PLAYBACK IS NOT COMING OUT TO THE SPEAKERS
Dear sir/madam,
Go to the sound properties in tray icon, check the Mic is not muted and there is Line in button, u scroll up to high for sound in mic. check all the check box are not MUTED. ok.
thanks
good luck
Don't forget to rate the solution
Jul 23, 2008 | Microsoft Windows Vista Home Premium with...
No sound at all when you turn on speakers
after uninstall vista and install xp, I can't hear sound
Apr 28, 2008 | Creative Labs Sound Blaster Live! 5.1...
Trouble with Speaker 5.1 +Vista + Asus P5k Motherboard. No Rear Speaker sound
Hi Perseo,
If you run through a speaker test in windows, and hear playback from all 5 speakers and the subwoofer, then your system is correctly connected, and working properly.
Vista uses a layered sound system that renders sound a bit differently than what you're used to on your previous system. As a result, it will most often refuse to project stereo sources in 5-channel surround, on it's own. it will just play them as stereo, and the bass will fill in whenever it can.
One possible way you could use to get around this, is to force the system to use all 5 speakers, through the driver. If you're using a realtek onboard card anything like mine (I have a p5k-VM board myself), this can be done by opening up the HD Audio Manager, and selecting the "Speaker Fill" option, under the Speaker Configuration" tab.
another option would be to load your media player you use to play music or movies, and see if there's an option to change speaker settings within the programs.
hope this helps!
Dec 30, 2007 | Logitech X-530 Computer Speakers
114 people viewed this question
 Grubhead
Grubhead
