Question about JVC AM FM CD DET FACE CAR STEREO
JVC Car Stereo
I'm trying to change my JVC head unit. Once connected, the unit will only switch on to eject or insert a cd. It has no power at any other time. The vehicle is a 1986 vw camper. If it is getting power whilst loading or ejecting why doesn't it switch on? Thanks for your help!
    New Friend:
How to program radio stations jcv kdr200 radio
Posted on Jan 05, 2014
Hello.
if the switched +12v IS connected and the headset only ejects or accepts cds what could the problem be then?
Posted on Jul 13, 2008
    Sergeant:
  • 300 Answers
The head unit should have two separate +12V connections: One that goes to a switched 12V power that is switched on/off via the ignition and one that is always energized at +12V. If the head unit's switched +12V lead is not connected, the unit will not turn on (except for when +12V is first applied to the "always on" lead, in which case it will immediately eject the CD). Please respond if this is not the issue. Hope this helps!
Posted on Mar 05, 2008
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
The head unit has power but will not turn on. Only turns on when the cd is ejected
it sounds like you dont have power coming in from the "switched positive in" the one the tells it that you have turned the key on
try checking to see if the fuse on that connection is good or that is plugged in to a source that has power when the key is turned on
if that doesnt help write back and tell me more about how long it has been wired and how it is wired if possible and i can try to help more
good luck!
Apr 23, 2011 | JVC AM FM CD DET FACE CAR STEREO
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Apr 05, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVC12 DISC CHANGER CH-X550 jammed
I would pull off cover, unscrew and remove top carriage of tray and remove your disc. While your at it you should take cotton swab and dip it in rubbing alcohol and clean the laser lens. Then reinstall carriage and top cover and try using it again.
Jun 22, 2009 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-G340 Power Problem
Try rewiring it. Yellow to a full time hot 12v and red to an ignition switched 12v
Feb 18, 2009 | JVC AM FM CD DET FACE CAR STEREO
Pioneer DEH-2150 : CD Ejection switches off the Stereo
hi rolls
when there is no CD in unit hold the source button to turn unit to actual on position (when you insert a CD is it self guided once you push it to a certain point or does it just self guide instantly) if you sort of push it in a bit and unit turns on its because the pioneer function says to itself i need to be on so it will play for you but once you eject the CD the unit says time to turn off the solution i recommended should solve this if not let me know and ill figure out another step
hope i was able to help
Feb 14, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Jvc kd-sh55 head unit
Have you tried pressing the "RESET" button on the stereo? I have a JVC unit in my car and the reset button is a tiny hole behind the detachable face. Take a pencil or a pen and insert the end into the tiny hole an hold for a few seconds. This will reset the stereo and you should be able to eject the CD as you normally would. If it's a mini-disc (8mm) you probably would have to take the unit apart and manually retrieve it - big hassle. Check the owner's manual to find out where the "RESET" button is if it is not behind the face. If you don't have the owner's manual, you can download one from jvc.com.. Hope this helps.
Aug 30, 2008 | JVC KD-SH55 CD Player
JVC head unit problem
Do you have a "RESET" button on your stereo? Check your owner's manual to find it. I have a JVC unit in my car and the reset button is a small hole behind the detachable face. Take the end of a pencil or a pen and insert it in the tiny hole and hold for a few seconds. This should reset the stereo so you can get the CD out. Hope this helps...
Aug 28, 2008 | Car Audio & Video
JVC AM FM CD DET FACE CAR STEREO Logo
336 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
