Question about HP LaserJet 1018 Printer
Problem printing When printing anything black lines appear on the right hand side of the page, there are about 4 or 5 of them in a row. Why is this happening?
  • 3 more comments
  • Anonymous Mar 07, 2008
    have the same problem if I print pdf of page with the inserted photo. Please help
  • always_free Mar 20, 2008
    Have the same problem but only when theres an image on the page. If theres only text txt then there are no black lines alongthe edge.
  • Anonymous Mar 24, 2008
    When I print one black line in coming on the right side of the print out. Is it the problem with the cartridge or roller
  • Anonymous May 29, 2008
  • Anonymous Jun 21, 2008
    SAME IS THE PROBLEM BUT WITH US BLACK LINES ARE COMING ON LEFT OF THE PAGES.
1. Go to your 1018's Printing Preferences
2. Change your print resolution to 1200 dpi Fastres (Finishing tab)
3. Enable "Rotated" in paper orientation (Basics tab)
4. Go to Printer Properties (Start, Settings (Control Panel), Printers, right-click you printer and select Properties)
5. Click the Advanced tab
6. Click the "Printing defaults" button
7. Repeat steps 2-3 again
i have tried the above thing. After changing the settings it is working but with in 15 mins the same problem came. Tell me what shall i do
Posted on Jun 27, 2008
The problem can be the laser cartridge that is 12A cartridge or the fusser problem.
The first problem can be OPC drum or the blade which are in the cartridge.
The fusser problem is a little different if you touch the paper and clear some printing parts it is the fusser sleeve which is tear.
you must chang the fusser or only sleeve
ASK ANY PROBLEM IN PRINTER AT
info@naghsh.de
Posted on Jun 25, 2008
The problem is not hardware, but software based. There is a problem with the new drivers (XP and Vista) which prints black bars on the right hand side of a 8.5x11. There is no "solution" at the time but a workaround (which works with some, not everytime).
Note (1): You have to change the settings in BOTH places to make it work!
Note (2): Changing your printer resolution to 1200 dpi will use more toner, but it will be almost the same as 600 dpi + the bars.
Posted on Mar 27, 2008
The toner cartridge roller may be defective or there are outside light going inside the printer, causing the bands.
Posted on Mar 05, 2008
Fuzzy horizontal lines printing every 1 1/8"
Sounds like you've already diagnosed the problem.
Oct 11, 2012 | Tektronix PHASER 6180 All-In-One Laser...
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
Hello our Muratec F-320 will print faxes with a
lIFT THE BLACK PLASTIC COVER ON TOP OF THE TONER AND DRUM CARTRIDGES. UNDERNEATH THE COVER CLEAN THE ROW OF "EYES" RUNNING FRONT TO BACK. SHOULD FIX IT...PROBABLY HAVE SOME TONER ON THE GLASS EYES.
Jun 24, 2010 | Muratec F-300 Fax
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
177 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
