Question about Intel D102GGC2 Motherboard
Two 1 gb ram sticks not working together!
I have a motherboard called d102ggc2 with max 2 gb capacity. i recently tried upgrading from 1 gb ram to 2 gb ram by adding another 1 gb stick. The problem is that both the sticks are not working together ( it shows single channel still while i insert the two sticks into the slots)....both sticks work perfectly separately, but when inserted together, it still shows 1 gb ram and another slot is shown as not installed in the bios....what is wrong??
  • sunnyoraish Mar 06, 2008
    umm....well both the sticks are completely identical, and both were bought from the same company and have the same specs
    Do u think i can solve it by a BIOS update?
  • 38 Answers
1.plz check the bus speed of both hte rams
2.is the bus speed of second ram is same as old ram
Posted on Mar 05, 2008
  • 75 Answers
May be frequency is different of RAM,just check it
3 Suggested Answers
  • 108 Answers
SOURCE: I have a motherboard called
Sounds like the second RAM stick was placed in the wrong slot. I would suggest checking your motherboard manual to determine this. Some motherboard designs have unusual slot arrangements.
Posted on Dec 17, 2010
bronk50
  • 27725 Answers
are they of the same brand/type some motherboards only accept specific brands to work together be compatible
hope this helps
Posted on Feb 22, 2011
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
I bought new 2gb ddr2 with 800 mhz and its not working on my motherboard d102ggc2 can u plz help me with the solution
i guess you did not check the compatibility of the RAMs to your MB limitations....
the only solution is to return the RAMs and get the RAMs that is supported by your MB.....
the MB (D102GGC2) can hold only a max of 533 mhz and max of 1GB each in each slot of RAM....
so if you are trying to install one 2GB card of 800 mhz IT WIILL NOT WORK....
get TWO RAM cards of 1GB each (total 2GB) of RAM.... each of 400 mhz....
hope this helps...
Reg
Suresh
to check what your MB supports, look for the details below...
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-029352.htm
Intel® Desktop Board D102GGC2 Technical product specification circuit388.gif Product Specification
This product specification applies only to standard D102GGC2 boards with BIOS identifier GC11020M.86A. Changes to this specification will be published in the D102GGC2 Desktop Board Specification Update before being incorporated into a revision of this document.
pdf.gif D102GGC2 Technical Product Specification [PDF]
File Name: D102GGC2_TechProdSpec.pdf
Date: April 2006
This document is an update to the specifications contained in the D102GGC2 Technical Product Specification. It is intended for hardware system manufacturers and software developers of applications, operating systems, or tools. It contains specification changes, errata, specification clarifications, and documentation changes.
pdf.gif D102GGC2 Desktop Board Specification Update [PDF]
File Name: D102GGC2_SpecUpdate03.pdf
Date: November 2006
Apr 27, 2011 | Intel D102GGC2 Motherboard
I have a motherboard called d102ggc2 with max 2 GB capacity. I recently tried upgrading from 1 GB ram to 2 GB ram by adding another 1 GB stick. The problem is that both the sticks are not working together...
Dec 17, 2010 | Intel D102GGC2 Motherboard
I have intel D102g mother board. that can accomodate max 2gb RAM (DDR2) throug dual channel. however i have properly inserter two ram's one is 512mb other is 1gb. but system shows only one channel is...
To the best of my knowledge, if both RAM speeds are the same and compatible with your FSB your BIOS will reconize them and not average their capacity or favor a compatible stick over another. Sorry that I couldn't be of more help. Good luck.
Feb 24, 2010 | Intel D102GGC2 Motherboard
2 rams nt working simultaneously
Are they exactly the same brand and model? Sometimes they dont like to mix and match. Say you have the Left and right ram slot. Does each single stick work alone in the left and the right slot? Sounds like you may have a dead ram slot.. :(
Jun 04, 2009 | Intel D102GGC2 Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
No display after upgrading RAM
Are you saying that there are only 2 slots for ram or 4, if 4 then you may have a dual channel lap top, in which case you need all of the ram to match, they all have to be the same exact ram.you cant mix and match, also is the bios recent, it sounds like you may need a bios flash if the laptop isn't recent.And there may be a limitation on the amount of ram it takes, I just setup a brand new acer and it only two gig max, see if they offer a bios update
Dec 23, 2008 | Gateway M-6866 15.4" Widescreen Laptop...
Ram upgrade on Sony Viao PCVRS420
You can use even 1 stick of 2GIG of RAM or 2 X 1GIG of RAM or any combination will do for as long it will just be a max of 2GIG since that's the max support of your motherboard....
Oct 15, 2008 | Computers & Internet
Intel D102GGC2 Motherboard Logo
333 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
