Have a side by side kenmore elite with acceler-ice button. The acceler-ice now goes on and off by itself, sometimes radidly, sometimes once in awhile. It beeps each time it goeson/off. Can I reset?
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze Kenmore Model Numbers
if the wire is green i would suspect it to be a safety ground yo attach where the fan mount attaches to the body of the refrigerator. this is assuming the original fan only had a two wire hookup. Ed
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates.
Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change.
Is there any water or ice in the icemaker itself? Water may not be getting to icemaker
call them back out if it dont work soon thats what warrantys for :0)
