Technics SX-PC25 spares
I have a Technicc SX-PC25 electric piano and the 4 pin din socket has been broken off the board. It is easily repairable if i could only find the part, which is proving extremely difficult. Does anyone know where i can purchase the psrt? Thanks
  • sparky84 Jan 04, 2009
    technics sxp22 electric piano. The plug-in lead between the foot pedals and the main piano has snapped. Where can I purchase a replacement plug-in lead please?
Noggin
  • 944 Answers
SOURCE: International Power
You have probably permanently damaged your turntable. The voltage supply in Germany is 220V AC, whereas in the US it is 110 V AC. It is just possible that all you have done is to blow a fuse in the unit, if no external fuse holders are visible then try opening up the case and looking for one near where the power cable enters the unit. If you have no luck with that then the transformer is almost certainly burnt out - this could be replaced but it is unlikely to be something you can do yourself. Please don't plug anything else that is designed for 110V into a European socket, regardless of being able to get an adaptor that will fit the socket - the voltage is different. It will almost certainly die as well and the possible risks of electric shock, fire etc. are quite significant. Hope this helps, if you want to try and get the unit repaired in Germany please ask again with details of your location and I will try and find you a reputable repair facility. If in doubt about which of your items can be plugged in in Europe then please ask as some can be switched to deal with the higher voltage, although not all. :)
Posted on Jun 25, 2007
SOURCE: QK-DVDM1 need mini din 9 pin monitor only
I also have a monitor for a qwestar dvd player. email me at onlyforward4me@yahoo.com
Posted on Oct 01, 2007
brainyass
  • 242 Answers
SOURCE: repair technician needed for Technics SX-PR900
http://www2.panasonic.com/consumer-electronics/support/Musical-Instruments/Technics-Musical-Instruments/Digital-Ensembles/model.SX-PR900B
Just put in your ZIP and it'll find the closest service center.
Posted on Nov 21, 2008
loonyface
  • 84 Answers
SOURCE: my ps3 hdmi socket is
You cant buy a new socket
but...
You can get it repaired by phoning up the playstation cutomer servises
you can get the number in you booklet that came with the Playstation itself
pls rate"
Posted on Dec 17, 2008
  • 1138 Answers
SOURCE: i need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
Posted on May 26, 2009
I have a Technics PR-305 Digital Piano. I turned on the power it worked when i played it, the next time I turned on the power it didn`t work, can the Electronic board be repaired to work again?
Your best bet would be to contact Technics customer service to locate the best repair shop in your area and to check on the availablity of parts for your specific model.
Jan 06, 2016 | Music
On a Technics SX-PR110 keyboard, why can't we get it to play in basic piano mode?
If you give me the panel picture/photo of your SX-PR110 (with high resolution),may I can help
May 02, 2015 | Music
I have a Technics PR-305 Digital Piano It was working at the End of October, but around the beginning of November 5 my Technics PR-305 Digital Piano made a loud humming sound, then it quieted down, I
Also, in addition to more info I need; look on p 91 of the online owner's manual linked below. Pay attention to Sounds and Effects, the first section therein. Follow the directions closely, esp., read pp. 26, 83, and 86 which are referenced for detailed help w/ sound issues. TECHNICS SX PR305 Manual Page 91
Nov 26, 2014 | Casio Music
Need repairs on Technics SX-PX103-M Model.
Have you had any luck with your Technics piano? I've got the same piano and Mine does not work either. No lights on the control panel, only red power light comes on. Does yours have any led lights besides the power light that come on? I've investigated and I have learned a lot from this piano. 4 main boards. Im pretty sure I've got it down to one board. Interested in selling me any boards from your Piano??
Jan 19, 2012 | Music
My pedal is not sustaining - it is plugged in at the pedal outlet, not sure what else to look for?
The first question is has it ever worked? If this is new, the connector of the pedals is a mini DIN type which is REAL hard to get seated properly. Often something blocks it from seating fully. Remove the plug and with a bright light inspect the pins... they are EASILY broken off. Aligning the connector carefully and making sure it seats is important. This piano also has a foot under the pedals to screw down against the floor but that isn't wht cause the pedals to not work.
Apr 18, 2011 | Yamaha YDP223 Digital Piano
Broken white E and F keys on my TECHNICS SX P50
SOMETIMES the keys are not really broken, but instead knocked out of their pivot arrangements. Technics is out of business and you MAY have a hard time finding replacements. I believe they were bought out by Panasonic. You will LIKELY have to get parts for this, if available, through an instrument repair shop.
I might suggest taaking it to a shop and see if they MIGHT be able to swap the keys with ones you don't use.
They SHOULD be able to disarm them so it is at least playable.
Be forewarned that SOMETIMES excess forces on the keys from dropping CAN crack the circuit board onder the keys and that can be fatal and require board replacement, if available.
Jan 27, 2010 | Music
Transfer recording from technics piano model sx-pr602-m to comput
the correct way to transfer files from the piano to a computer is via the MIDI out socket on the piano ...not the jack
you may possible need a midi to usb convertor ...which readly available and cheap
Feb 01, 2009 | Music
NO SOUND
You posted in the wrong section, you will need to repost.
May 11, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
378 people viewed this question
 Grubhead
Grubhead
