1. move door to locked position 2. Press self-clean pad. 3. press up or down to select clean time (it will flash 3:00) 4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set. 5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked. 6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened. ** to cancel press cancel. Hope that helps!
would need the model #, but generally, the top oven is manual clean. To clean larger oven, press clean, then up or down next to the timer to determine how long you want the self clean to run.
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING 2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION 3. PRESS THE "COOK TIME" BUTTON 4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS 5. PRESS "START" BUTTON 6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN. 7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
I have a crosley but don't know if it is the same model. 1. move door to locked position 2. Press self-clean pad. 3. press up or down to select clean time (it will flash 3:00) 4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set. 5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked. 6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened. ** to cancel press cancel. Hope that helps! RC
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Press the cleaning button and then the up arrow that regulates the temp as if you are baking I think it reads 300 and then it starts. This is for Kenmore self cleaning
