Question about Panasonic DVD-S325 DVD Player
Panasonic dvd s32 not responding
I have a panasonic dvd player. It was working on Monday, but when I went to turn it on today it did not respond. I have checked the power outlets and swapped power outlets, but nothing works.
  • 4 more comments
  • Tilan Mar 20, 2008
    At the first time dvd try does not open and It display OPEN Then CLOSE after some times it displays ERROR 03. I followed some troubleshooting method given ( to move the laser head little bit to left) which couldnt solve the problem. Now it displays the No Disc message. Pse give me a solutuion If somebody knows, Tks
    tilan_prasath@yahoo.com
  • Anonymous Mar 28, 2008
    I have the same problem with a Panasonic DVD S32. Worked fine one day and no power at all, the next. Proven sockets, leads all work, so must be the unit itself
    I have the same problem with a Panasonic DVD S32. Worked fine one day and no power at all the next time I tried to use it. I have proven leads, sockets etc. are all fine. Dead as a dodo.
  • Bhajii Jun 12, 2008
    The same problem, also checked the fuse situated inside the box, and that power was ok up to the fuse.
  • masmozaff850 Oct 05, 2008
    my device stoped its working with this problem.by checking its inbox and the board i understood that the problems id probably for the IC:MR6710 in the hot part of the board.because i didn't find the IC and its datasheet i couldn't check it completely. if anyone have its datasheet please inform me by emai that to masmozaffary@yahoo.com.
  • Becca82 Jan 19, 2009
    Thanks eveyone. It turned out to be a faulty unit in the end and got replaced by a better pioneer DVD player :)
    Problem Solver:
  • 4 Answers
In most cases problem solvs inserting resistor 200 kom 1 W between +300 V supply and 7 th pin MR6710
Posted on Nov 22, 2009
After change:
1.
MR6710
SMPS MODE CONTR. 8p,
equipment, the DVD playes working fine!
MoZo
from Hungary
Posted on Jan 19, 2009
    Sniper:
  • 99 Answers
On various panasonic dvd recorders, the voltage regulator in the power supply overheats and shuts down the unit. panasonic seems to know about this fault as they started fitting larger heatsinks to compensate for this. this is a very common fault.
Posted on Jan 07, 2010
Hi my dvd problem is in power supply.problem is in the mr6710 ic
Posted on Jun 14, 2009
Not responding
Blister, is the A/V not responding to both the receiver's buttons and remote control?
Aug 30, 2017 | Harman Kardon AVR 435 Receiver
Panasonic dvd player model dvbs32 fault dead no display no functions checked secondary diodes seem okay heated caps. no results any ideas
Are you sure that you don't mean a DVD-S32? if you do, that is a Panasonic DVD player. A DVB-S32 is a digital satellite receiver box, but it is a different brand.
In any event, the 'dead' condition points to one common denominator; the power supply has one or more short-circuit components. I doubt it would just be a simple blown fuse; it could be something far more serious, which may have affected the surface-mounted parts on the copper side of the board in this area.
The difference between taking this to a service centre to be repaired and the retail price of a brand new player could be somewhat significant, since new players are relatively cheaper to buy now.
If you really want this one fixed by a workshop. get a quote first on the likely cost(s) involved to restore it to full operation. Then you can make a decision whether or not to go further with it, or simply buy a new player.
Only consider replacing the whole player if you discover it is not economical to repair your existing model.
Mar 07, 2011 | Panasonic DVD-RV32 DVD Player
Is it possible to unlock a Panasonic DVD S32 bought in Australia to read a DVD from the UK
Here there is a free Video Help solution to your device:
http://www.videohelp.com/dvdhacks/panasonic-dvd-s325/7765
Also If you type in google:
panasonic-dvd-s325-uop-and-region-free-firmware-377-zip-8000778/
You can update the firmware to read any Area DVD
Regards,
PDG
May 11, 2010 | Panasonic DVD-S325 DVD Player
The remote for my Panasonic HT520 doesn't respond. When the CD-DVD button on the remote is pressed the lights come on on the remote, but still nothing from the player. The player works fine on it's own,...
Ok let me verify; you have an HT-520 home theatre with integrated DVD player. When you press the DVD input you can't control certain aspects of the DVD player or the DVD player does not respond at all?
Does the DVD respond at all if you put the remote into another mode (should be called Amp or Receiver)? Can your remote be programmed for different devices and mabe it was programmed to control a different DVD player?
I will search the unit in my knowledge base and let you know some exact steps to try. If you could clarify some of thoes details that would be wonderful.
Thanks,
Kevin
Jan 24, 2010 | Televison & Video
Panasonic HT520 remote not responding
Hi.Im Dani from Spain.I have the same pb.To solve this problem-a new one remote.My remote its
a panasonic universal remote control dvd system eur7722x30(i dint find it but i find this:panasonic universal remote control dvd system eur7722x40;i need to see if its compatible(hope so)
This is the link http://cgi.ebay.com/Panasonic-Universal-Remote-Control-DVD-Syste-EUR7722XD0_W0QQitemZ130350261905QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1e597b2691
Good luck
Jan 24, 2010 | Panasonic SC-HT520 System
My Panasonic DVD recorder DMR-E60 doe not respond to its remote control. IT display DVD 2!
Nov 24, 2009 | Panasonic DMR-E60 DVD Recorder
Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
Oct 17, 2009 | Panasonic DMRES15 DVD Recorder
Remote control
turn on the dvd player
press and hold the 'enter' key and the '1' key at the same time
remote will start to work again
Sep 14, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DVD-S325 DVD Player Logo
1,840 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
