Try using the compatability tool that is integrated with Windows 7. Do a right click on the Setup.exe file of Photosmart and select Troubleshoot Compatability. Then select, This program worked with an earlier version of Windows, and then select Windows XP SP2. Run the program and if it works choose the option that tells the system the program installed properly. Hope this helps
Go to HP's website (hp.com), click on Support & Drivers, do a search for "Photosmart C6280", click on "Photosmart C6280", download the drivers and software for Windows 7 (you'll need to know whether you've got the 32 or 64 bit version), then follow the install instructions.
it is likely that you havr a mix of trade and host supply of ink cartridges. Even though HP363 and HP177 are compatible cartridges it is not the issue. Refer this article.
TWAIN is a backgroung program on which the software for your scanner is based and needs it. Apparently your All-in-one installer didn't had it (or was corrupted somehow).Get it from here
this will usually happen if you're disconnecting the USB cable from the computer and putting it back on a different USB ports. try to connect it to where it was working before. this is also true for other USB devices such as scanners and webcams
