Question about Panasonic Lumix DMC-TZ3 Digital Camera
To view images on TV
Would like guidance on connecting and viewing
  • 47 Answers
Connect the supplied AV cable to the television on a connection that has white and yellow inputs (for monoraul audio and cvbs), then on your television remote, select the associated input. wherever you plug this cable into, check for an input label - something like INn, VIDEOn, AVn (where n is the number) and then on the remote for the television should be a buttons that says something to the effect of INPUT, INPUT SELECT, A/V, AV SELECT, DEVICE, or SOURCE, etc. depending on your model. Once you select the correct input you should see your picture on-screen using the playback or review mode of the camera - the icon that is a quadrilateral w/ rounded corners that has a right-arrow in the center.
Hope this helps. Good luck.
Posted on Mar 09, 2008
How do I view movies in 3D on the Mitsubishi WD-Y65?
WD-Y65 is NOT a 3D ready TV. You either have to change the TV to see the movie in 3D, or just watch it in 2D in you current TV.
I have the same TV as yours. Current I connect a desktop PC to the TV via DVI port, and I watch Avatar using colorcode 3D(Amber/Blue) with Stereoscopic Player from www.3dtv.at It might be a way for you to enjoy 3D without change the whole thing, but it's an entire different topic.
Jan 08, 2012 | Mitsubishi WD-Y65 65" HDTV
Please let me know how to view the images from a D3000 dslr camera thro` a LCD TV having usb port
You can't. You can use the supplied video cable to connect the camera to a TV's video in connector to play videos and view images, but not the USB port. The USB is only to connect the camera to a computer.
Oct 20, 2010 | Nikon D3000 Digital Camera
How to view photos
To view them on the camera lcd screen, press the playback button (green arrow in a green box, 2nd button down to the right of the screen) and then scroll through them one by one using the left and right buttons on the thumb pad. If you press the up and down buttons the image will advance forward and back by ten pictures each time.
To view them on a tv, turn the camera off and connect the video cable supplied with the camera to your tv input terminal (yellow). Turn the camera on set the tv to display the input feed and then use the camera playback button as before.
To view them on a computer, you'll need to upload them to the computer first. The best way is to turn the camera off and remove the memory card, and then insert it into a memory card reader connected to your computer. The computer will then prompt you to upload and display the images.
For full camera instructions from Olympus, click here.
For basic operating instructions, click here.
Please take a moment to rate my answer.
Sep 06, 2010 | Olympus FE-115 Digital Camera
Buttons unresponsive in manual mode
opne camera and clean big flex which is connected to main pcb. try out if work then fine
other wise check finder unit connection is ok and clean out.
Aug 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
No image at menu 'digital'
you connected the converter to AV1 that is the ONLY place you will recieve any signal leave the tv in av1 and run setup on the converter ONLY you should be all set
Nov 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Nosignal when i power it on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are trying to view the DVD on the Samsung TV, you need to firstly connect the DVD to the appropriate connection on the TV.
Once connected, with a Samsung TV, you need to press the SOURCE button on the TV remote control to view any external sources such as your DVD player.
The ‘NO SIGNAL’ message would indicate there is no signal, if you have not tuned your channels in, this may be the digital tuner you are viewing. Press the source button whilst a DVD is playing in the DVD and see if an image displays.
Jul 16, 2009 | Samsung Televison & Video
Attempting to view videos from Everio to TV (this camcorder is new to me)
You do noy need an AC adapter to view on your TV.
How are you connecting to the TV.
Also try on another TV and see if the problem still exists.
Let me know the outcome and I will see if I can assist more.
Jan 09, 2008 | JVC Everio GZ-MG130 Camcorder
Can I view my DiMAGE 5 images on a TV?
It is possible to view images in the camera on your television. This camera has a video-out terminal, which allows you to connect the camera to your television using the standard DiMAGE 5 Video Cable. The DiMAGE 5 can be set to either NTSC or PAL, depending on the broadcast system used.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
