Question about Hoover SE230 Front Load Washer
Hoover SE230 Programmer rotating
My SE230 programmer just rotates all the way round by itself sometimes without the machine doing anything. At other times it all works perfectly, is this the programmer at fault?
  • miannabeel Sep 24, 2008
    I HAVE THE SAME PROBLUM WITH MY WASHING MACHINE
    12 TILLETT WAY
    LONDON
    E2 7BL
  • miannabeel May 11, 2010
    HI
    12 TILLETT WAY LONDON
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Hi there, my washing machine was doing the same as the one you have mentioned.
I bought a replacement timer from the website highlighted below. It has done the trick and every programme works properly now.
A competent DIY person can change one of these easily and will take about 30 minutes to do.
The new part looks slightly different but it carries the same part number.
The price £24.99 + £4.98 delivery.
http://www.4hoover.co.uk/cgi-bin/product.pl?PID=723224&section=46246&brand=&model=SE230&path=45786,46246
Posted on Nov 08, 2008
E2 7BL
Posted on Sep 24, 2008
GE Washer WBB2090F1WW will not fill and will not spin. Where do I start to troubleshoot as these seem like unrelated problems? Thank you for any assistance.
Both are initiated by the programmer unit? Is the water supply getting to the machine, has a tap/valve inadvertently been closed. i If water is getting to it then if the programmer is working correctly the pump should trandport the water? If water is not being introduced the machine will not rotate.
I think the issues are both associated with a faulty programmer probably
Jun 05, 2015 | Washing Machines
Why is our machine not washing as normal ?
Have you trued clearing the drain at bottom of machine? If not that, it sounds like a programmer fault.
Jul 21, 2014 | Hoover Washing Machines
Hoover se 230 works perfectly except will not perform fast spin. (nothing happend when programmer dial is turned to fast cycle position
hello any spin problems can be caused by the module control board usually sits at the back of the washer may have a load of wires coming off it hope it helps
regards
shaun
Apr 22, 2011 | Hoover SE230 Front Load Washer
My W123 machine programmer keeps going round
Unfortunately you'll have to replace the dial unit, or we can try to repair the dial gearbox. But you'll need some mechanical skills for that.
Update me about your decision and progress
Jul 22, 2009 | Washing Machines
Hi my washing machine wont stop running when the cycle ends - I have to pull the plub at the mains
Reason for taking a long time spinning is that it might have an uneven load. The wrong number of bath towels, for instance will mean it takes 3 or 4 tries at getting the spin right before it can spin them at the correct speed. An unbalanced load doesn't do the machine any good either.
After this wash has finished try it on something a lot lighter- say a duvet cover only with a couple of pillowcases. If that takes a long time too then the trouble is with the machine.
Looks like your "programmer" has stopped on the "spin cycle".
Could be a sensor has gone.
But everything points to the "little drive" in the programmer.
You could try "Manually Rotating The Selector Round a Few Times"
(This could free something off)
If a new "programmer" is needed, This could be more expensive than a new machine.
If the machine is under a year old it will still be under guarantee. If it is slightly over the year, but under 18 months old you still have a good case to go back to the manufacturer and get them to fix it.
Jul 03, 2009 | Hotpoint Washing Machines
Programms rotate without stop
Check your instructions, and see if there is a reset point or function, if there is not ,then it has a control unit malfunction, and unfortunately, this is not something you can fix yourself.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Washing Machines
Timer just spins round
yes it is the timer,i had the same thing happened to me on a hoover,i was told that the fault was when you turn the timer to a programme to do this slowly and gently and if you go pass a programme not to turn it back but to go forward again until you get to the right programme..hope this helps.all the best..ps a new timer may cost about £80 to £100.
Nov 19, 2007 | Hoover PE235 Front Load Washer
Indesit wd12s washer dryer
after all you have checked out I think it must be a programmer fault. Sorry I dont know how to check it out for sure
Oct 24, 2007 | Washing Machines
Problem
Set the programme first, & then put the on botton on.
Apr 07, 2007 | Whirlpool AWM5125/1 Front Load Washer
Hoover SE230 Front Load Washer Logo
352 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
