Vhf radio cobra mr 75 will only transmit recieve at short range ie 1km even when on high power
  • 518 Answers
If there is power output, you need to use a watt meter and verify that your antenna is good. Depending on the antenna you can also check for a shorted or open connector or cable with an ohm meter.
Hope that helps...
Posted on Mar 05, 2008
How do i correct engine noise while transmitting on a cobra MR F45-D marine radio
you'll need a filter capacitor in the power line to the radio. wiring varies according the the individual unit, but typically one side to power, the other to ground.
Nov 29, 2014 | Cobra Mr F45-d Marine Class-d Dsc...
My cobra hh35 two-way radios one will not trasnmit more than 29 yards?
Do you have it set on low power? There is a power setting in the menu that will fix that problem.
Nov 23, 2014 | Cobra MR HH330 FLT VHF Waterproof Two-Way...
Error message ft-530
is the radio in duplex (offset transmit freq)if keying takes radio out of band it would show err,select simplex ie transmit/recieve same freq
Dec 19, 2013 | Yaesu Radio Communications
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
Cobra 25 only transmit and recieve on ch 1
Hi, my name is John. Take the cover off the unit, and check for broken trace or loose solder joints around this area, ...hope this was helpful..Rate this solution on the four thumbs-up.....John
Jul 12, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Lost Sound
Your speaker has probably failed. I recommend taking your radio to a repair shop to replace the speaker. Should not be an expensive repair. I charge $75 for a speaker repair. They will also be able to go through the radio and check that everything else is ok. Feel free to contact me: if you need any help or want to send the radio to me for the repair.
May 07, 2010 | Cobra Mr F75b Marine Vhf Radio Fixed Mount...
Need an operating manual for a Cobra MR F75 VHF Marine Radio
Howdy from South Texas and Merry christmas.
Here is your link and enjoy the Holidays.
Patrick Patterson
Dec 15, 2008 | Cobra MRF55 2-Way Radio
Transmits but does not Receive
Check your microphone by swapping with another duplicate. If no differance, you will need a SWR meter (standing wave ratio) to find the culprit. It attaches in line of the coax and determinds power out and reflected power. The reading should be 25 watts foward and max of 1 reflected.
Oct 22, 2008 | Cobra Mr F75b Marine Vhf Radio Fixed Mount...
51 people viewed this question
