Brand new PIXMA MP520 just connected up. Having just installed the print head and the ink cartridges, now getting message when turn on the printer. >>> 6A80 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual.
I opened the printer, and pushed gently on the lever that holds/releases the print head, and this seemed to release whatever was stuck. After this the print head moved freely on turning on the printer/copier.
Posted on Mar 07, 2008
Print head not installed
You may have a defective print head.
When you lift up the lid does the head move to the center?
If so do the ink cartridges light up?
If it moves to the center and no lights you need a new head.
Mar 23, 2014 | Canon PIXMA MP520 InkJet Printer
My printer is printing lines through all of my images.
1.maybe the level of ink is too low
2. if you are refil you cartridges use head cleaning if it won't help replase them
Jun 08, 2011 | Canon PIXMA MP520 InkJet Printer
Printer will not recognize color cartridge
Try to clean the recipticle and did you buy a new brand name one, thats what I have to go with with my canon. Sometime is they leak they dry up and the head losing connection with the printer and sometime that ink burns up the head on the cartridge.
May 25, 2010 | Canon Pixma MP480 All-In-One InkJet...
Cannon MP520 when printing documents there are lines through some of the text. I have changed the ink cartridge 2 times! What should I do?
The issue is not with the ink cartridge but with the actual print heads. In most (almost all) Canon ink jet prints/multi functions the prints heads are separate from the ink cartridge.
The print head is what guides he ink onto the page, if they become dirty or clogged then you will get lines through images and text or very poor print outs.
You can clean the print heads by using the software that came with the printer and there are some other ways as well.
I tried to paste the instructions from Canons site but they were too long. Use the link below to go to Canon's knowledge base for the MP520 and search for "clean print heads" and follow the instructions that come up.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15483
Apr 14, 2010 | Canon PIXMA MP520 InkJet Printer
Getting error U043 "The following ink tank cannot be recognized. I have the correct tank. Pixma 520 ...tank # 5 PGBK
The little chips on the front of the cartridge create a trouble for people trying to refill the cartridge, as of right now, there is no way to easily reset the chips. If you refill them, they still register as empty, and therefore don't work.
If the following tips doesn’t help, you can try to install the original new ink cartridge following the instructions in the user manual. This can solve the problem.
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
For information on the compatible ink tanks, refer to the back cover of the Quick Start Guide.
Tips before Replacing Ink Tanks : Important:
- To maintain optimal printing quality, we recommend the use of specified Canon brand ink tanks.
Refilling ink is not recommended.
- Once you remove an ink tank, replace it immediately. Do not leave the machine with ink tanks removed.
- Replace empty tanks with new ones. Inserting partially used ink tanks may cause the nozzles to clog. Furthermore, with such tanks, the machine will not be able to inform you when to replace the tanks properly.
- Once an ink tank has been installed, do not remove it from the machine and leave it out in the open. This will cause the ink tank to dry out, and the machine may not operate properly when it is reinstalled. To maintain optimal printing quality, use an ink tank within six months of first use.
- Color ink may be consumed even when printing a black-and-white document or when black-and-white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the machine's performance. When an ink tank is out of ink, replace it immediately with a new one.
After replacing ink tank;
Turn off the machine, and unplug the power cord of the machine from the power supply. After five minutes or more, plug the power cord of the machine back in, and then turn on the machine.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 25, 2010 | Canon PIXMA MP520 InkJet Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
I tried to use a generic brand ink cartridge in my Canon MP520, which I couldn't get to work. I then gave up on it and installed a genuine canon cartridge, and while the printers says that the ink is full...
you do not say if your printer has it's own print heads or if they are on the cartridge.. if your printer has the print heads then the generic cartridge has probably blocked the heads nosils (cheap ink is NOT the same as the real thing and is usually sub-standard) use your maintenance section on either the printer or it's software on the computer and run head cleaning routine several times and do the occasional test print to see if it improves... hopefully you have not damaged the print head
Oct 14, 2008 | Canon Office Equipment & Supplies
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
