Question about Nokia 2310 Cellular Phone
Phone calls i put a new sim card in my old nokia 2310 coz lost new fone and now i cant get any phone calls theres no active diverts. can u hlp me pls
    Brigadier General:
  • 7,752 Answers
The phone may not be picking up the band frequency....you need to know if the phone frequency is tri-band like 800mhz/1800mhz/1900mhz.
Posted on Mar 27, 2008
How do I get My new Nokia phone to work,and not my old phone both fromm t-mobile
put the sim card { inside the back of the phone close to the battery} from the old phone to the new phone. OR if your new phone has a sim card call tmobile and have them activate the new sim card. Or you can activate it at tmobile .com.
May 21, 2014 | T-Mobile Cell Phones
With *#92702689# i can't get the 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair any of these details, in my nokia 2690 mobile, can u say plzz... sir what is the new code???
here are codes for nokia fones that you guyz may need a lot
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
*#4720# Deactivate Half Rate Codec
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
*#9999# Phones software version if *#0000# does not work
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
#pw+1234567890+1# Provider Lock Status. (use the \"*\" button to obtain the \"p,w\" and \"+\" symbols)
#pw+1234567890+2# Network Lock Status. (use the \"*\" button to obtain the \"p,w\" and \"+\" symbols)
#pw+1234567890+3# Country Lock Status. (use the \"*\" button to obtain the \"p,w\" and \"+\" symbols)
#pw+1234567890+4# SIM Card Lock Status. (use the \"*\" button to obtain the \"p,w\" and \"+\" symbols)
*#147# (vodafone) this lets you know who called you last
*#1471# Last call (Only vodofone)
*#21# Allows you to check the number that \"All Calls\" are diverted to
*#2640# Displays security code in use
*#30# Lets you see the private number
*#43# Allows you to check the \"Call Waiting\" status of your phone.
*#61# Allows you to check the number that \"On No Reply\" calls are diverted to
*#62# Allows you to check the number that \"Divert If Unreachable (no service)\" calls are diverted to
*#67# Allows you to check the number that \"On Busy Calls\" are diverted to
*#67705646# Removes operator logo on 3310 & 3330
*#73# Reset phone timers and game scores
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature \"SIM Clock Stop Allowed\", it means you will get the best standby time possible
*#7760# Manufactures code
*#7780# Restore factory settings
*#8110# Software version for the nokia 8110
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
*#94870345123456789# Deactivate the PWM-Mem
**21*number# Turn on \"All Calls\" diverting to the phone number entered
**61*number# Turn on \"No Reply\" diverting to the phone number entered
**67*number# Turn on \"On Busy\" diverting to the phone number entered
12345 This is the default security code
press and hold # Lets you switch between lines
*#3283# or *#DATE# Date of Manufacture
via:
*#682371158412125# Software Version
*#92702689# - Enter the service menu
*#7370925538# - Delete all the content of the wallet and the wallet code
Jan 06, 2011 | Nokia 2690 Cell Phone
How to deactivate active call divert
put your sim card to another phone and change the divert settings.deactivate them.then you will not get a msg.
Aug 17, 2009 | Nokia 6233 Cellular Phone
Cant use my 3150 after changing my sim card with a new no.
if ur phone is cdma network.... you cant use it with a simcard of gsm network and vice versa.....
sometimes phones are locked to a particular network.... so if you move away from that network and try to access ur phone in another network in another location it wont be accessible....
for example some samsung mobiles can be used only in middle east and not outside the place.... coz they are locked to that network....
also if the above is not ur case ....some sim cards take some time to activate....
the only option for u at this point would be to use the old sim card that u were using and when the fone actually worked.... in the same location where u had it working.... if its working.... and ur able to calls and receive them there is nothing wrong in ur phone..... you will have to contact ur service provider (network) for activating the new sim on ur mobile....
good luck
regards iversh
Aug 17, 2009 | Nokia N73 Cellular Phone
It rejects my sim card and i have lost my book so i cant solve it
your unit should be reformat, unfortunately it will remove all your saved data.
Nov 19, 2008 | Nokia 2310 Cellular Phone
Nokia 6103
insert vodafone sim and then go to setting call setting and call divert or call barrings and there you will find an option cancel all barrings and done!!!!!!!!
Jul 05, 2008 | Nokia 6103 Cellular Phone
Sim lock
you need to put back the original sim card in the phone and do a master reset.....in the phone settings.....
menu/settings/intial setup/master reset - 000000 security default code
Jan 06, 2008 | Nokia 1600 Cellular Phone
Nokia 2310 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
