Question about E-Machines eMachines Desktop PC
System hard starting
When i put on my system,,it tries booting and trip,repeat it,it does the same,atimes,after booting well,it trips,maybe after u have tried severely,it boots n works.when its working,its perfectly okay.the problem is that i dont know the reason y it doesnt boot at one touch,tripping n trippg.please will like 2 know what causes it and d solution
  • 61 Answers
How old is the system..if really old open the cabinet and clean the vents and interiors with a good airduster
Posted on Mar 05, 2008
  • 151 Answers
I cant understand your problem.If you are saying your system's on off switch is not working properly then you should check your on off switch.or define on button in bios if the facility is provided.
Heater works but trips after a minute
Hello
If u have 2 kinds of trip circuits
1) regular over current trip then there maybe a problem withthe mcb itself, so try another location that does not use that trip or higher amps trip .
2) if u have an mcb with special trip that also makes sure there is not leakage to the ground of toaster , then some toasters get the leakage after some time .
Feb 17, 2015 | Tefal Toaster Ovens
REFRIGERATOR KEEPS TRIPPING THE GFCI OUTLET
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
Nov 30, 2017 | Jenn-Air Refrigerators
Computer will not boot or anything
Does it have power? Have you tried hitting the F8 KEY repeatedly after the initial windows screen starts? Do any of the pc's lights come on (hard drive usage,lan,cap lock,num lock, etc)? If you have absolutely no power try another outlet, if your connected to a surge protector see if the surge protector reset has tripped (found on medium to expensive protectors - if you hve a inexpensive one you probably wont have a a reset on it) try to plug something else into the outlet like a lamp, if you have no power check your household circuit protector and reset the fuse, but of course be leery. If something tripped the circuit something isnt right, indicating a power surge. Storms in your area or construction nearby?
Apr 15, 2011 | HP Pavilion Slimline s3700y Desktop,...
I had my oil changed in October after the "oil
Try this procedure and let me know if this does not work;
Turn the ignition switch to the "On" position but do not start the engine.
1. Press the Trip/Reset button until "Setup Menu Hold Reset" is displayed.
2. Then press and hold down the Trip/Reset button for approximately 2 seconds until "Reset For System Check" is displayed then release the Trip/Reset button.
3. Then immediately press and hold down the Trip/Reset button again for approximately 2 more seconds until "OIL 100% RESET IF NEW" is displayed then release the Trip/Reset button.
4. Then immediately press the Trip/Reset button once to display "HOLD RESET IF NEW OIL" then release the Trip/Reset button.
5. Then immediately press and hold the Trip/Reset button again for approximately 2 seconds until "OIL LIFE SET TO 100%" is displayed.
Turn off the ignition switch, and then start the engine to verify that the reset procedure did work, and you might have to repeat the procedure if the Trip/Reset button is not pushed fast enough, or it is not held down long enough, or it is held down too long during the reset procedure, and it may take a few attempts to be successful.
Nov 11, 2010 | 2006 Ford Explorer
Computer froze shut down by power button now will not start os lets me choose repair or start normally both tried just goes black screen then reboots over and over
Turn the computer on.
Press F8, repeatedly, until you see a start-up menu.
Choose "safe mode".
If it boots, open All Programs.
Open Accessories.
Open System Tools.
Open System Restore.
Select a date/time when your computer _was_ working correct, and go "back" to that checkpoint.
If that does not help, and it boots, use the Windows XP/Vista/7 "File and Settings Transfer Wizard" to create one file, holding all your E-mail, contacts, and music files.
Copy that file to an external disk-drive.
Then, take a deep breath, and reinstall Windows.
Reinstall MS Office.
Reinstall your anti-virus software.
Reinstall Adobe Reader.
Reinstall your other program.
Finally, reload from the external disk-drive.
Apr 02, 2010 | Acer Aspire 5720 Notebook
P4/not booting up upon start
Hi try to open you chase and unistall all the additional slot cards and try to boot up, sometimes one of the slot cards fails and if that happens your machine wont start up until that slot cart is removed, thats how your machine protects it self
May 08, 2009 | Intel D865GBF Motherboard
I have a 2005 Venture and have not been able to reset the change engine oil light. After repeatedly pressing the trip/reset button for 2 minutes the message center was still flashing change engine oil and...
Notes ENGINE OIL LIFE SYSTEM
HOW TO RESET THE ENGINE OIL LIFE SYSTEM
The Engine Oil Life System calculates when to change your engine oil and filter based on vehicle use. Anytime your oil is changed, reset the system so it can calculate when the next oil change is required. If a situation occurs where you change your oil prior to a "CHANGE ENGINE OIL" message being turned on, reset the system.
  1. With the ignition key in "RUN" but the engine off, repeatedly push the trip/reset button until "OIL" is displayed on the Driver Information Center (DIC).
  2. Once "OIL" is displayed, push and hold the trip/reset button for five seconds. The number will disappear and be replaced by 100 (indicating 100% oil life remaining).
  3. Turn the key to "OFF". If the "CHANGE ENGINE OIL" message comes back on when you start your vehicle, the engine oil life system has not reset. Repeat the procedure.
If this does not work you may have a problem with your instrument cluster.
Mar 22, 2009 | 2005 Chevrolet Venture
Carrier model# 38BRBO36300. Compessor tries to start but trips out. Already changed the capacitor.
If it trips after trying to start....sounds like you need a compressor.Is this system metered by a txv?If so you may try a hard start kit.
Jul 28, 2008 | Carrier Heating & Cooling
Hotpoint aquarius1100 electrical prob.
you say tripped the switch?... are you talking about a circuit breaker???.. I was thinking maybe you have a bad breaker... If you had no problem before... maybe try in a differt plug in reciptical... if the washer has a short.. hard to find sometimes..like looking for needle in hay stack..
Sep 02, 2007 | Washing Machines
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
