Question about Refrigerators
Kenmore refrigerator is noisy
It makes a groaning, rhythmic sound and continues the entire time the unit is running
My kenmore fridge is loud everytime the compressor comes and stays on. I have developed tinitis in the year because of this noise. Solution to this problem : I will never ever buy another Kenmore refrigerator.
Posted on Nov 30, 2010
  • Terri McDonald Nov 30, 2011
    I hate, hate, hate my Kenmore all fridge. Noisy, noisy, noisy - even wakes me up at night. I will never buy another Kenmore. My daughter was visiting and my fridge cut in. She thought a lawn mower was running outside and it was my fridge.
We had our Kenmore Freezer on top delivered this morning. It hasn't stopped running yet 9 hours later. Is this normal? There is a sticker inside that say to "Allow 24 hours for adjustments."
as it was delivered this morning you should have left it upright/unpluged for 24 hours,then switched it on.switching it on staight away will not harm it but it will take its own time to settle down to the set temperature.also make sure the seals fit flat all round.and the unit sits square (use a spirit level and adjust feet if required.)may sound minor but some units run noisy if out of square.....
Sep 07, 2010 | Kenmore 64802 Top Freezer Refrigerator
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Groaning sounds when draining
HI. You may have a problem with the water pump such as a frozen pulley or a broken impeller. This actual section of the pump is not designed to be repaired. You will need to replace the entire pump device, asap. Once replaced, the unit will operate properly, and without the noise.
Nov 16, 2009 | Kenmore Washing Machines
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Kenmore freezer keeps opening
tweak the hing locations on the freezer side to make it swing closed. sounds like it is tweaked to the other way.
Jun 15, 2009 | Kenmore Refrigerators
A motor in the Ref. started to make a groan like noise.
sounds to me that the fan motor is bad,write down the model number and go to a parts store(Sunberg),and the fan motor usually is about $50.00-$60.00
Apr 21, 2009 | Refrigerators
Making lots of noise when running help? please kenmore refridgerator model 25368821790
Hi
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Please revert for further assistance and Do accept the solution if found useful.
Thanks
Rylee
Mar 18, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Groaning frig
BFULLAWAY had the answer, I believe. My ice maker does the same thing, groaning and creaking for a few seconds, stopping briefly, then starts creaking again. This is due to ice stuck inside and it will make no ice as a result. Usually I see a piece of ice protruding and knock it out. Happened recently, but I saw no ice. Took a cup of hot tap water (not boiling) and poured it into the compartments where cubes form. (Made sure ice tray was in place to catch water.) I banged on the side and a misshapened cube fell out. Creaking/groaning stopped and unit began to function normally.
Apr 28, 2007 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
450 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
