Question about Samsung SCX 4521F All-In-One Laser Printer
Problem with lock error
I already read your instruction for lock error and tried to find the postion of lock button under scanner but I cant find this buttom , could you let me know where exactly it is ??
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Scanner Locked error shown on screen?2 possible reason, either the scanner unit is faulty or the main board is faulty.
Posted on Mar 14, 2008
Scanner locked
if you mean scanner lock error find the lock button and open it (it mostly under the scanner)
Sep 03, 2014 | Xerox Documate Office Equipment & Supplies
I recetnly had a problem with my hard drive and had to replace. We reinstalled DL and copied old directory on new directory. Now when i try to access DL I recieve an error message Error 3204 Data Base...
I can't help you directly, but I can direct you to the manufacturer's website, where you can find further Contact information for technical assistance, and under Tech Support, a link to the tech library page where you can research instruction manuals and download software, etc.
http://www.alarmlock.com/
Go to that page, then check under "Tech Support" or "Contact".
Jun 07, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
SCANNER LOCKED IS ON THE DISPLAY SCREEN I HAVE CHECKED THE GREEN BUTTON UNDER THE PAPER TRAY AND THAT IS SET TO UNLOCK. WHEN I TRY TO PRINT THE DISPLAY SCREEN SAYS SCANNER ERROR AND THE SCANNER LOCKED
Hi, what you want to do is, first; (shutdown) your Scanner, next (shutdown) the computer. Disconnect the scanner, and unplug it from the outlet. Disconnect scanner cables from the computer; Note: do not change anything on the computer. Reconnect cables to the computer. Plug scanner back into the power outlet; turn on computer, turn scanner on. This may clear the (Freeze); but the (Error) might appear again. Thanks paul7of9
Jan 05, 2010 | Xerox Phaser 6110 Laser Printer
Scanner locked
check documentation for the exact location of the lock, usually located on the flatbed.
Sep 17, 2009 | Gestetner DSm515pfd Digital Copier -...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Error 5 for ncr 7875 scale scanner
If the scanner read only two times is a problem with the communication protocol.
What protocol do you use?
Explain more about your problem with your calibration pricedure
Jul 29, 2008 | NCR 7875
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Canon MX310 Scanner Error
The scanner mechanism is locked....there should be a bar or button that slides to lock/unlock. Probably a picture of a lock.....this prevents damage while transporting the device....
May 12, 2008 | Canon MX310 Office All-In-One Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
345 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
