Question about OKI C5200n Laser Printer
Oki 5600 & 3400 toners
The problem is that at the original toner cartridges are no fills to put the chip in.probably there's no chip at the original ?or if it exists where is it?
  • cav utd Mar 19, 2008
    Oki 5600 just put new drums in ,fuser unit new belt new toner cartridge k message says 543 k toner cartridge sensor error 540 y toner sensor error
    how do you clear this.
I can't solve the problem, that is its is not printing at all all the lights are normal and nothing is broken in the printer. so help me solve the problem.
Posted on Feb 05, 2009
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
This error is toner not recognized
Follow the instructions for possible fix.
INSTRUCTIONS TO CHECK REFLECTOR OPERATIONS
(1) Open the poly bag, and take out the Toner-cartridge.
(2) Remove the tape to the position like the figure.
Tape
(3) Hold the Toner-cartridge horizontally, so that the Lever-sensor may go up and down
vertically.
Lever-sensor
(4) When it does not see the Lever-sensor like the figure, turn the gear in the direction of the
arrow, and it tries to see the Lever-sensor.
Gear
(5) Return the tape to former position.
(6) Put the Toner-cartridge vertically.
(7) Move Lever-sensor like the figure.
Lever-sensor
(8) Confirms the Lever-sensor is returned smoothly.
Lever-sensor
(9) Repeat (7) and (8), 3 times. The Toner-cartridge is wrong when the Lever-sensor does
not work from the position of (7) or when it does not return smoothly
Posted on Apr 07, 2008
We have put a new toner cartridge in our oki b710. it still reads 0% how do we reset?
There are some toners out there that do not have the "Chip" that makes contact with the printer itself. If you have the old cartridge then you can prize out the chip and fit it into your new cartridge. that will get it working again.
Nov 30, 2016 | OKI Office Equipment & Supplies
How do I fix the "change toner cartridge" error.
Has the cartridge got a chip? Does this chip need replacing?
Feb 11, 2015 | OKI B8300 Laser Printer
Have an error message on my oki B4600 that I cant get to reset
you should have an RFID chip in the toner try replacing the RFID chip for the toner
Jun 09, 2014 | OKI B4600 Laser Printer
How to reset oki b411dn cartridge after refilling
Producers of printers protecting oneself against the mass copying of original toners implemented the number of solutions being aimed at hampering the copying of their solutions. Towards a number of recipes for individual sub-assemblies of the cartridge intended for a laser printer applying special scaling circuits installed in the casing of the toner which are suming the number of printed sides up was the most spectacular solution and are freezing the laser contribution after the achievement of set limit of printouts. Toner do drukarki materiay eksploatacyjne Chip toner co jak
Apr 23, 2014 | Oki Electric Industry B411dn Printer
Oki c5650 toner showing empty but it is full
first open the cartridge access door and look inside the printer is there any toner dust or not? then manually inspect the optical white fiber hole is clean or not.and finally inspect is there any cartridge detection chip if yes then replace the chip your problem will be solved.
Jun 15, 2012 | OKI Office Equipment & Supplies
A message keeps flashing up 231 fatal error. Can you let me know what I need to do. 0116 240 3430 Dorothy
231 fatal error is telling you that the data from the chip on the toner cartridge is invalid or cannot be read.
This may happen for one of the following reasons:
1)The printer is unable to read the data on toner chip because of toner dust or dirt inside the printer.
Solution: Clean the printer inside, clean toner slot and drum.. See:Clean your laser printer.
2)Either the toner is not an original cartridge, it is refurbished or refilled, or the chip on the toner cartridge is defective.
Solution: replace the toner, or replace the Chip on toner cartridge.
3)The toner sensor in your OKI is defective.
Solution: Call the support number listed on the printer manual to arrange repair.
Jun 07, 2010 | OKI C5800Ldn Led Printer
OKI B4400 toner - is the chip reusable? I get toner not installed
The chip is not reusable and needs to be replaced every time. You should be able to find a chip on the internet somewhere. I own a Cartridge World printer cartridge refilling store and I do not recommend refilling your own toner cartridges or buying super cheap ones off the internet. The toner is generally such a low grade that it degrades your drum cartridge causing you to replace a $219 drum unit before you should have to.
Jan 27, 2010 | OKI B4400 Digital Mono Printer - Black
Error Message/Black toner empty
Your printer cartridge chip is damage you change Black toner cartridge
May 28, 2009 | OKI C3400N Single Pass Color Printer
Most all new color laser printers employ an RFID reader adjacent to each of the 4 tomer cartridges. There is a unique RFID chip inside (under a small blue slide cover) each toner cartridge. Whan a new toner cartridge is installed, the printer "knows" such and begins a "countdown" of the number of prints that are made which utilize the toner in each of the 4 cartridges. Once a toner cartridge has "processed" the predetermined number of copies you will get a warning that the cartridge is almost empty and must be replaced. After an additional predetermined number of copies are processed, the integral computer within the printer will shut down the printer until the cartridge is "replaced". If you simply "refill" the same or original cartridge and re-install it into the printer, the same RFID chip is in the cartridge and the computer will not reset the print "counter", allowing you to start printing. You have to obtain another couple of new or "re-filled" cartridges (of the same color or black) from an outside source. The printers' internal computer does not keep a complete running list of all of the RFID chips that have been installed and used in the printer (maybe 2 or 3) and then then it is "1st in / 1st out" of the limited RFID memory of the printer. I have been unable to obtain a "Service Manual" for the OKI C3400n printer to determine how to do a "hard reset" of the internal computer. I know there is a way which would allow the "refilling" of the toner cartridges without having to buy an additional 2 of each color.
Dec 06, 2008 | OKI C3400N Single Pass Color Printer
OKI C5200n Laser Printer Logo
1,367 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
