HP Officejet 5510 All-In-One Thermal Printer Logo
Posted on Mar 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trobleshooting In my desktop appers "HP photo and imaging 1.0-PSC2000 Series insert"
Anonymous
Level 2:
  • Expert 28 Answers
  • Posted on Apr 07, 2008
Anonymous
Expert
Level 2:
Answers
28
Questions
Helped
11874
Points
127
Here is a link
but frist what errors is it giving you
hp has a great online web page
so i copyied what i this you should trouble shoot and let me know cause i have my wholde company using hp all i one printers
im shure i can walk you through this
richard from chicago
2helpful
3answers
Sim card location on hp 7100 printer
NO SIM CARD USED IN PRINTERS
Center images
>> Check the paper is correctly inserted in the printer tray
>> Set guides exactly to paper size (Ex: A4 Paper Size)
>> Copy paste the image into a word document
>> Select the document press Ctrl+E in Microsoft Word
>> Try to Print.
Hp photosmart c310 phot images don't center properly on page
>> Try to Print.
How do I transfer photos with sd memory card reader to my computer ?
insert your memory card to the sd reader then insert to your computer port .. and then open any image viewer app then import. you should get picasa image viewer
How to upload photo
Transferring images from a Memory Card to a Windows Computer Follow the steps below to transfer images from a memory card to a computer running Windows. Step one: Insert the memory card Follow the steps below to insert the memory card into the HP All-in-One.
  1. Turn the memory card so that the label faces left, and the contacts are facing your HP All-in-One.
  2. Insert the memory card into the appropriate slot on the HP All-in-One.
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass-storage port on your HP All-in-One. These read-only partitions are added by the drive manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive. When the memory card is inserted correctly, the Photo light next to the memory card slots begins to blink. The message Reading... appears on the color graphics display. The status light next to the memory card slots blinks green when the card is being accessed. If a memory card is inserted incorrectly, the status light next to the memory card slots blinks amber and the color graphics display shows an error message such as Card is in backwards or Card is not fully inserted. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. Safely remove a card only when the status light next to the slots is not blinking.
Step two: Transfer images without using the HP Photosmart software After inserting the memory card into the HP All-in-One, the memory card appears as a drive on the computer. Follow the steps below to transfer the images on the memory card to the computer.
  1. Press the Photo button to display the Photo menu.
  2. Press the down arrow button (c01133817.jpg ) to select Transfer to computer .
  3. Follow the prompts on the computer to complete the transfer of images.
    NOTE: If there are photo files on the memory card that have never been transferred before, a dialog box on the computer asks whether you want to save the photo files to the computer. Click the Transfer option and all the new photos from the memory card are saved to the computer.By default, the image files are saved in month and year folders depending on when the photos were taken. The folders are created under the C:\Documents and Settings\username\My Documents\My Pictures folder.
1helpful
2answers
When i try to scan a photo my scanner says ''youneed to install or run hp software for this feature'' how do i do this?
Software included
HP Image Zone Photo & Imaging Software: HP Director, HP Photo Gallery, HP Image Editor, HP Instant Share, HP Photo Prints, HP Creative Projects, HP Quick 4 x 6 prints, HP Document Viewer, HP Send to Programs
The above software should be able to be run by inserting the cd-rom into your cd-rom or dvd-rom drive.
Once installed you'll be able to run the scanner.
1helpful
Getting photos to craigs list
In your email program, save the photos to your desktop. If you're using Outlook..right-click on photo and choose Save As and save to desktop. If you use webmail or other email program, use the save/download image command and save them to your desktop.
Go to Craig's List and when you post your ad you'll see a button for Add/Edit images at the bottom. Click on the button, navigate to your desktop and choose the image(s) you want to add.
Compaq 7620s screen black edges appeare
1. plz left click on desktop and then go to properties and after that go to Apperance .
Then do the required changes in effects tab and do the changes as required.
2. If vista/xp then go to control panel ,
select apperance and theme,
select and from select and do the relevant changes
TRANSFER PHOTOS TO DESKTOP
Assumimg that the software is installed and you are able to scan from the computer.
And also assuming that when you insert the memory card you are able to view and print them from the printer as stand alone.
Download and install the latest version of Photosmart essential from HP.com.
Then try to transfer images.
If it does not work....insert the software disk and then browse the disk..you will find a folder called Setup...inside that you will find a folder called Unload or Unloadsupport..inside that you will find unload.msi...right click on it and then left clcik on repair and then try to transfer images.
k24674
Grand Canyon Tech
Grand Canyon Tech
