Philips 42PF7320A 42 in. Plasma HDTV Logo
Posted on Jun 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black vertical line appears on plasma tv screen
I have a 3-year old [Philips flat HDTV 42" plasma digital cable ready with Pixel Plus], model number [42PF7320A/37].
There is a constant black vertical 3"-wide line in the center of the screen, that goes from the top to the bottom of the screen. Right next to this line is a multicolored vertical 1"-wide line. These lines do not go away. Everything else seems to be okay.
I would like to know what the problem could be, and how difficult it would be to fix.
Level 3:
Top Expert:
  • Philips Master 76,851 Answers
  • Posted on Jun 03, 2017
Philips Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986939
Points
237762
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
4 Related Answers
Anonymous
  • Posted on Jan 24, 2008
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Anonymous
  • 16 Answers
  • Posted on Apr 04, 2009
SOURCE: Philips 42'' Plasma TV 42PF7320A/37 red led error codes
3 flashes indicates that there is a problem in the power supply circuit. Being that you have experience with this, you might be able to fix it.
Anonymous
  • 227 Answers
  • Posted on Jul 29, 2009
SOURCE: Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Anonymous
  • Posted on May 09, 2010
SOURCE: Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
This TV has been in use for 2 years. None of the cables have been changed or removed. Apparently hit a button on the remote that blanked the picture & sound. I have a gray screen with menu options,...
Hi Jim:
You can find an owners manual on the Philips site.
There's also a quick start guide and a firmware update.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7320A/37&scy=us&slg=en
Try the above link, should take you to the site..or you can
do a google search....
owners manual Philips 42PF7320A/42
you should see this link in the list of links...maybe the top one.
42PF7320A/37 Philips flat HDTV 42PF7320A 42" plasma digital cable ...
May 25, 2007 ... Philips flat HDTV 42PF7320A 42" plasma digital cable ready with Pixel Plus ... Manuals & documentation · Leaflet · User manual · Quick start guide. + More Manuals and Documentation ...
Hope this helped.
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
2helpful
2answers
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
5helpful
Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Black horizontal line 1 pixel high
Depends on what area the line is in the bottom half or top?
2answers
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info ctechnicians.com
5helpful
2answers
Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
