FixYa.com
Tags:
Denon Dn-X1500 Professional DJ Mixer System
Power conversion
posted by scottys67 on Mar 05, 2008
Hi i recently purchased a 110volt dn x 1500.They sent me a 50 watt power converter to run on australian 240 volt power.Only the denon logo light comes on when powered up.Power is going in and converter works on other 110 v products i have.Is the mixer faulty
Comment by scottys67, posted on Mar 05, 2008
Thanks for quick response Geno.Well no there isnt any voltage i can see or  hear.Like i said just the denon logo light at top right of mixer.Can you tell if other lights come on when its powered up?I beleive 50 watts is right as 2 companies have provided 50 watters.The 50's work with my 3500 cd players and they have a motor to turn the platter.Cant get a single answer from denon so i thank you for your input. Best regards Scottie.S
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Geno69
Rank:Wiz Wiz
Rating: 84%, 266 votes
If you have 110 - 120 volts AC at 60Hz, then the mixer must be bad. Unless 50 Watts isn't enough. Does the voltage drop when you plug in the Mixer to the convertor?
Geno
Rating Locked! (?) scottys67 has rated this solution as Helpful
Can you Help with these Home Theater Systems problems?
LG/LF-KP5931 DVD/CD Player...
Hi I have played around with... Answer This...
panasonic dvd home theater...
Need directions on where... Answer This...
Digital Optical input on...
Hello- I can't get the digital... Answer This...
SA-HT640
I always get an error code F61... Answer This...
Using HDX275
Hi Ravi, I hope u r using sony... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
