Question about Linksys Wireless-G WRT54G Router
Dynex wireless router
I changed the settings for the security settings for the Dynex router by changing it to 128 bit encryption with a pass phrase and i want to be able to reset it so it will be a open network right now i cant get onto my wireless network.Can anyone help me please?
  • 113 Answers
Plug a Cat 5e cable from your computer into the dynex router.
Go to "Run" in the start menu and type "cmd".
On the black screen type "ipconfig"
The default gateway is your Dynex router.
Open internet explorer and type "http://192.168.0.1" or whatever your configuration was.
Log into router
Default username is: admin
Default password is: (blank)
Now reset your wireless configurations.
Posted on Mar 05, 2008
  • detailerdude Feb 10, 2011
    dmathwizard! You da man! Thanks so much! I've been trying to figure out my password and re-configure some settings for a long, long while. Thanks to you and your instructions, I finally have been able to!
    Problem Solver:
  • 8 Answers
What it sounds like you are going to have to do, is reset your router back to factory defaults. After you have done thins you will have to re setup your settings to get it back to the way you had it.
Posted on May 11, 2008
How do i find my network key for my router lynksys wirelass wrt54gs
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You should be able to see your present wireless network security key on this screen. You can also use this screen to change the key if you want.
If you want to make some changes first select the security mode you want to use.
I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless devices. After the first time they connect to the secured network they should automatically remember the security code. I hope this advice helps you out.
Nov 03, 2011 | Linksys Wireless-G WRT54GS Router...
Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Thanks for using Fixya
Aug 02, 2010 | Computers & Internet
Setting secured wireless connection
You can enable WEP on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
How do I enter the WEP encryption on my router
Configuring WEP:
1.Connect a computer to any one of the four LAN ports of the Belkin wireless router.
2.Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
3.Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
4.Click Security under Wireless menu.
5.Under Security, Select 64 bit WEP (or 128 bit WEP).
6.Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
7.Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
Jul 23, 2009 | Belkin (F5D7230-4) Router (587009)
Wep
WEP
  1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
  2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
  3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
  4. Click Security under Wireless menu
  5. Under Security, Select 64 bit WEP (or 128 bit WEP).
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
  7. Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
Configuring WPA-PSK Encryption:
  4. Click Security under Wireless menu.
  5. Under Security Mode, select WPA/WPA2-personal (PSK)
  6. Select WPA2-PSK as your Authentication
  7. Select AES as the Encryption Technique.
  8. Enter a word or group of characters in the Password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
    Note: The PSK (Pre-Shared Key) is case sensitive ("A" is different than "a")
  9. Click Apply changes to save the settings
    Jun 04, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
    I need to get my password from my belkin54 router to use for my phone internet
    Hi Berry,
    On the back of your router there is a reset button, press and hold that when power on, until all the lights are blinking simultaneously (about 30 sec).
    Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT use a wireless connection, use a cable.
    Open your web browser and type the IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
    Click Login on the top of the page to login to the router. By default the Password is left blank, clickSubmit.
    Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
    Remember to set an admin password before you close down, other vice anyone can access you router and change the setup and admin password.
    /regards
    Teis
    Jan 04, 2009 | Belkin (F5D9230-4) Wireless Router...
    How do I security enable my Belkin router?
    Apply the settings.
    /regards
    Teis
    Jan 01, 2009 | Belkin (F5D6230-3) Wireless Router
    Our neighborhood is using our internet!
    Connect a computer to any one of the four LAN ports of the router. DO NOT use a wireless connection, use a cable.
    Open your web browser and type the IP address of the router (by default, the address is http://192.168.0.1 or 192.168.1.1 or 192.168.2.1) in the address bar and press Enter.
    Apply the settings. Please write down the key – You will need it later to configure your neighbors wireless computer with the same key.
    DO NOT GIVE HIM the password for the router.
    Remember to set the admin password before you close down, other vice anyone can access you router and change the setup and admin password.
    /regards
    Teis
    Dec 29, 2008 | Linksys Wireless-G WRT54G Router
    Unsecured net work
    /regards
    Teis
    Was this solution helpful? Show your Appreciation by rating it:
    Nov 30, 2008 | Belkin (F5D7230-4) Router (587009)
    How do i password protect my Router???
    follow the steps below:
    5. Under Security, you can select 64 bit WEP (or 128 bit WEP) or WPA/WPA2-personal (PSK). Note: make sure that your wireless computers will be able to support WPA encryption since not all wireless cards/adapters will be able to. if you're not sure, WEP is the encryption to use
    Configuring WEP Encryption:
    1. 1. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
    2. 2. Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
    1. Select WPA2-PSK as your Authentication
    2. Select AES as the Encryption Technique.
    3. Enter a word or group of characters in the Password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
    4. Click Apply changes to save the settings.
    once you have enabled your wireless security, you need to reconnect your wireless computer to the wireless signal using your wireless password/network key.
    hope this'll help you and just ask me if you'll have other concern
    ciao!
    Jul 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Linksys Wireless-G WRT54G Router Logo
    992 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
