Question about Philips Magnavox 27MS343S 27" TV
Coaxle cable (from aerial on roof to TV)
I just have the end of my cable (coaxle) fall off and ave no tv now. The connection that fell off is on the end of the cord (aerial from roof) to the back of the TV. Can you help me to put it back together?
I DONT HAVE ANY TELEVISION
  • 113 Answers
Go purchase a coax male f connector, and the crimpers. Cut off 1/2 inch of rubber sleeving and fold the metal shielding back. Now cut the with part a quarter from the end but not all the way. You want the center piece to poke out. Now slide the f connector on and crimp.
Posted on Mar 05, 2008
Can't get a picture on our free to air TV set it keeps coming up no signal, we have a picture and sound on foxtel
you may find that the aerial inside your home was disconnected and used to wire up Foxtel in the roof, some technicians do that,
meaning all your Tv Outs on the wall would now be connected to Foxtel now instead of the aerial
if you can gain access to the junction of where all the Cable Coax wiring is in the roof make sure they haven't used the tv aerial cables for Foxtel ....just go check where your Aerial comes in and see it is still connected to the junction and not pulled out and a foxtel is going into it instead of the aerial
Apr 26, 2017 | Televison & Video
No dvb signal on Vierra Panasonic tv
If the tvs share the aerial but only one is working then the wiring of the non functioning socket has shorted. Perhaps the cable you used to connect the second set is damaged,try another. PERHAPS THE AERIAL SOCKET HAS BECOME DAMAGED,THIS ONLY COSTS A FEW PONDS/DOLLARS TO CHANGE. Alternatively it might be the wiring from the roof to the wall socket that is faulty.
First things first, check that the tv is working by connecting it in the other room. If it does work there you will know that theaerial socket in the second room is faulty and can begin testing.
Jun 03, 2015 | Panasonic Televison & Video
WE DISCONNECT OUR SATELITE hOW DO WE GET REGULAR TV
You must have these first.
1. Aerial antenna - buy this at your local home depot. Any aerial antenna available will be fine. Please see the sample picture.
2. Antenna wire (RG-6 cable wire) - connect one end of this wire to your aerial antenna and then the other end to your tv.
3. RG-6 connector - other end of the cable wire must have a this connector to attached it securely to your TV.
Some Aerial antenna has a cable wire packaged, this is much better than to assemble #2 and #3.
After the connection had been done, go to the menu on the tv, scroll down to antenna connection and then press auto tunning to saved all the viewable channel in your area.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jun 21, 2011 | Hisense LHD3204US 32 in. LCD HDTV
Water leak from inside the tv aerial through the pin connector
its most likely a leak in the roof following the wire down to the tv this could be a very big problem as any wood on the way to the tv has a chance to rapidly rot and create larger voids for air to get through you will want to send someone up to the roof to check where the line comes in and caulk the hell out of it
Robb
Apr 29, 2010 | Sony KDL-40S3000 40 in. LCD HDTV
Do not know why there is no way to hook up a DVD player.
most stores sell both adapters needed to hook up dvd or any type of electronic equipment buy a a/b switch so u can switch from dvd to [cable or satellite] then buy coaxle adapter which has 3 wire hook up to coaxle for tv [rca $10 ] and coaxle wire. connection wire a or b from dvd to adapter and other from a or b to cable/satellite other end of a/ b goes to tv slide switch to watch dvd and slide back for reg tv
Oct 11, 2009 | Toshiba CF19G22 19" TV
Vcr
Yes you may hook that up to the coaxle end of this unit or the RCA scart connection on the back.
The coaxle end you would need to be on channel 3 or 4 make sure you verify witch channel you vcr is under. Thanks
Aug 10, 2009 | Symphonic WF20D4 TV
Pay tv cable
you may bypass the box by using a straight connector, find the cable that lead to the TV room and connect it to the cable from the aerial antenna.
Mar 06, 2008 | Televison & Video
Coaxle cable (from aerial on roof to TV or top box)
I believe that you use the same type of connector as in the UK.
If so, this site or this video should help you.
Even if your connector is a slightly different design, the principles are the same.
Hope this helps,
Matt
Mar 05, 2008 | Audio Players & Recorders
My cable has disconnectd.. well fallen off the end of the cord. This is the cord form the aerial(on roof) to the back of the tV. I have no picture, as the connections on the end are loose. Can...
Are there 2 wires that can be seen? And is it flat looking or is it round cable with silver braided wire with white center insulator with copper looking center conductor? If it is the latter you can purchase screw on connectors at most electronics shops. Example...Radio Shack, Home depot, Lowes etc. Good luck and happy tv watching. Jay
Mar 05, 2008 | Televison & Video
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
