Question about BenQ FP757 Monitor
Secondary monitor I have had my monitor fp757 for some time to use with with my lap top. since I connected it today the screen has remained black - everything is connected, device manager says it is working correctly, display properties shows that it is on and the blue power light is on. any comments/advice please?
    Champion:
  • 220 Answers
When you first switch on Does it show Benq?If not the inverter circuit has failed.If you are technically able you can try resoldering transistors on inverter board.If your display is black all of the time transistors could have failed as also related fuse etc.
And yes please check with BenQ Normally these have a 3 year warranty.
Posted on Mar 05, 2008
Monitor blue light comes on, the picture is on for a brief second but screen goes black, how do I fix this problem please.
I have had this problem before and had to contact the manufacturer. I was able to send them back and the manufacturer sent me a replacement. If your monitor is under warranty it should not cost you anything.
Mar 15, 2011 | BenQ FP757-12 17" Flat Panel LCD Monitor
My problem started out pretty confusing. One day I turned my lap top on and the screen, after about five to ten seconds of being on, went black. I could see things loading up sort of but the screen was too...
Darkened screen as you describe indicates a failing inverter. You can test this easily by plugging the laptop into an external monitor, if this works ok, then the inverter needs replaced, If it does not work, the problem is with the graphics chip / motherboard
Jan 18, 2011 | Dell Inspiron 8000 Notebook
I have the Dell 1525. The screen is black with only the cursor appearing. Please advise
Check to see if you have the machine switched out to a stand alone monitor. This is a feature on many lap tops that lets you re-direct the signal out to a larger monitor, or if your monitor fails you can display the computer info on another screen. This feature is engaged by holding down the Fn key and tapping teither the F4, or F6 key on many lap tops. This feature can be toggled by both displaying at the same time or switched to the stand alone or the Lap top.
The other cause is that the machine has malfunctioned usually because of the CPU failure and there is nothing to boot the machine up.
Dec 30, 2010 | Dell Inspiron 1525 Notebook
I have held down Fn and F4 to restore my image to my lap top screen- many times, but the screen remains blank
If you have diverted the screen output to an external monitor or a TV, turn off the computer then disconnect the TV or monitor and turn computer back on again. The computer LCD is the default screen.
Aug 23, 2010 | Computers & Internet
When I connect my monitor to my lab top the green power light comes on then turns orange and I get "no signal" message on the monitor
you may need to tell the lap top to display from that screen the new screen has no image or signal so goes to sleep to save power.on your lap top try the (FN) key on your laptop then select a blue picture on the keyboad of to squears one black one blue this will alter the display.OR in windows look at Start>controal pannel>display
Jun 03, 2010 | Sharp LL-173C-B (Black) 17" LCD Monitor
I have a 2002 MAG INNOVISION FLAT SCREEN MODEL 780. I use this monitor as a dual monitor with my lap top. However today I still can view everything but with a pink hue. I have gone to the color controls on...
This could be a problem with the monitor's data cable. Try to check it & find if there is any bent pins on the connector.
If this is not the case, there could be a loose connection on the monitor's PCB, or a failing component. This needs to be checked by a qualified technician.
Apr 12, 2009 | Mag Innovision Computers & Internet
No signal and no picture, is it dead?
iS A LCD FLAT SCREEN EASY TO FIX. THE LIGHT FOR THE START BUTTOM LIGHTS AND THEN THE SCREEN IS BLACK
May 13, 2008 | BenQ FP757-12 17" Flat Panel LCD Monitor
Connecting lap tops to monitors...
Try connecting a mouse and keyboard to the laptop and then start it with the top closed. Not sure if this will work on your model, but it works on a lot of laptops. This should force the PC to use your external monitor as the primary one.
Mar 19, 2008 | Dell Inspiron 6400 Notebook
Color display issues with BenQ FP757 monitor
Go to menu and try Recall all.
Also possible that panel is defective.
Samir
Oct 01, 2007 | BenQ FP757 Monitor
Computers & Internet Logo
128 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
