There is a positioning "washer" that needs to be in place. If you don't line up the blade and position the washer it will not tighten. The blade will just spin around. Some even have a washer in front and in back. Be sure you have correct diameter of arbor that matches your blade too.
the back washer may be just round and the front washer is made to fit on the fats of the shaft
at least one washer has to be fitted so that it has to turn with the shaft
now ensure that the nut to tighten up the blade is not bottoming out and being prevented from locking the blade between the two washers
Adjustment
Check the backlash in bearing shaft direction and the axle hub deviation. Maximum for backlash should be 0.0020 in. (0.05mm) and for axle hub deviation 0.020 in. (0.05mm).
Fig. Checking wheel bearings for excessive play
NOTE
The rear wheel bearings are non-adjustable. If the wheel bearing is out of specifications, replace the wheel bearing. Removal & Installation
Before servicing the vehicle, refer to the Precautions section.
Raise and safely support the vehicle.
Remove or disconnect the following:
Rear tire and wheel assemblyRear stabilizer linkRear axle shaft nutRear disc brake caliper and discSpeed sensorParking brake assembly at the wheel hubNo. 1 and 2 upper control arm assemblyNo. 1 and 2 rear suspension arm assemblyToe control linkRear axle from hub assembly using a plastic hammerNo. 2 rear wheel bearing dust deflector using a screwdriver4 bolts and rear axle hub and bearing assembly from the axle carrier assembly
To install:
Install or connect the following:
Hub on the carrier and tighten the bolts to 52 ft. lbs. (70 Nm)No. 2 rear wheel bearing dust deflector using a screwdriverRear axle into hub assemblyNo. 1 and 2 upper control arm assembly. Torque the new nut to the No. 2 rear upper control arm to 52 ft. lbs. (70 Nm). Temporarily tighten the No. 1 arm bolt.No. 1 and 2 rear suspension arm assembly. Temporarily tighten.Toe control link. Torque new nut to 52 ft. lbs. (70 Nm).Rear stabilizer link. Torque to 20 ft. lbs. (27 Nm).Parking brake assembly at the wheel hubRear speed sensorRear axle shaft nut. Torque to 214 ft. Lbs. (290 Nm) and stake the nut with a chisel and hammer.Rear brake disc and disc brake caliper
Adjust the parking brake.
Stabilize the suspension as follows :
Install the wheel(s).
Lower the vehicle and bounce it up and down several times to stabilize the rear suspension.
Raise the vehicle.
Remove the wheel.
Jack up the rear lower suspension armplacing a wood block in between. Apply a load to the suspension so that the lower suspension arm is plkaced in a horizontal position.
Fully tighten the No. 1 rear upper control arm assembly to 119 ft. lbs. (161 Nm).
Fully tighten the No. 1 rear suspension arm assembly to 70 ft. lbs. (95 Nm).
Fully tighten the No. 2 rear suspension arm assembly to 119 ft. lbs. (161 Nm).
NOTE
If it is necessary to replace the hub or bearing, replace the components as an assembly.
Rear tire and wheel assemblyIf equipped with rear disc brakes, the caliper mounting bolts. Leave the brake line connected and suspend the assembly out of the way.Brake rotor or drum4 bolts and pull off the rear axle hubO-ring
To install:
Hub on the carrier and tighten the bolts to 59 ft. lbs. (80 Nm)Rotor or drumCaliper, f equipped with rear disc brakes and tighten the bolts to 34 ft. lbs. (64 Nm)Wheel
If equipped with air suspension, move the height control switch in the trunk area to the OFF position.
Negative battery cableRear wheel(s)Height control sensor link from the lower control armAnti-lock Brake System (ABS) speed sensor and wiring harnessBrake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire.Brake rotorParking brake shoes and cableCotter pin, lock cap and the nut holding the halfshaft to the rear axleSuspension member brace by removing the 2 boltsHalfshaft bolts and washersHalfshaft from the vehicleStrut rod
Place matchmarks on the adjusting cam and body for the No. 1 control arm.
Nut and adjusting camNut on the axle carrier side of the No. 1 lower control armSeparate the control arm from the axle carrierNo. 1 lower control armStabilizer bar link from the No. 2 lower control arm.
Place matchmarks on the adjusting cam and body.
Nut and adjusting cam from the No. 2 lower control armNut and bolt holding the No. 2 lower control arm to the axle carrierNo. 2 control arm from the vehicleNut and bolt on the lower side of the strut assembly2 upper control arm set nuts and boltsAxle carrier with the upper control arm
Secure the axle carrier in a vise.
Nut holding the upper control arm to the axle carrier and remove the control armDust deflector. Use a suitable prytool.Oil seal
Fig. Removing the oil seal (inner)-LS 430
Remove the 2 bolts and nuts and shift the backing the plate towards the hub side (outside).
Axle hub
Fig. Removing the axle hub from the axle carrier-LS 430 Backing plate.Inner race (outside) from the axle hub
Fig. Removing the inner race (outside) from the axle hub-LS 430 Oil seal (outer) from the axle
Fig. Removing the oil seal (outer)-LS 430 Snapring from inside the axle housingBearing from the axle housing
To install:
New bearing to the axle housingSnapring to the axle carrier, using snapring pliersNew outer oil seal. Coat the oil seal lip with multipurpose grease.
Fig. Installing the oil seal (outer)-LS 430 Backing plate to the axle housing. Do NOT install the bolts or nuts at this time.Inner race (inside) to the axle housingAxle hub to the axle housingBacking plate in position. Tighten the bolts and nuts to 43 ft. lbs. (59 Nm).New oil seal (inner) to the axle housing. Coat the oil seal lip with multipurpose grease.
Fig. Installing the oil seal (inner)-LS 430 New dust deflector. Be sure to align the hose for the ABS speed sensor in the dust deflector and axle carrier.Upper control arm to the axle carrier by installing the nut. Tighten the nut to 80 ft. lbs. (108 Nm).Axle carrier and upper control arm to the vehicle as an assembly2 upper control arm set bolts and tighten the bolts to 121 ft. lbs. (164 Nm)Bolt and nut holding the strut to the axle carrier. Tighten to 101 ft. lbs. (137 Nm).Bolt and nut connecting the No. 2 lower control arm to the axle carrier. Tighten the bolt to 60 ft. lbs. (81 Nm).Nut and adjusting cam to hold the No. 2 lower control arm to the body. Align the adjusting cam marks and tighten the nut to 57 ft. lbs. (78 Nm).Stabilizer bar link to the No. 2 lower control arm and tighten the nut to 48 ft. lbs. (65 Nm)No. 1 lower control arm to the axle carrier and body. Install the nut to hold the No. 1 lower control arm to the axle carrier. Tighten the nut to 43 ft. lbs. (59 Nm).Nut and adjusting cam to hold the No. 1 lower control arm to the body. Align the matchmarks and tighten the nut to 57 ft. lbs. (78 Nm).Strut rod to the axle carrier and body. Install the bolt and nut to hold the strut rod to the body. Tighten to 57 ft. lbs. (78 Nm).Bolt and nut to hold the strut rod to the axle carrier. Tighten to 136 ft. lbs. (184 Nm)Parking brake shoes and cableOutboard joint side of the halfshaft and align the matchmarks on the side gear shaft and the halfshaft. Coat the threads with clean oil and install the hexagon bolts. Tighten bolts to 61 ft. lbs. (83 Nm).Suspension member brace with the 2 bolts. Tighten the 2 bolts to 37 ft. lbs. (50 Nm).Nut to hold the halfshaft to the rear axle. Tighten the nut to 213 ft. lbs. (289 Nm).Lock cap and cotter pinBrake disc to the axle hub with the matchmarks aligned. Install the 2 screws and tighten the screws to 48 inch lbs. (5 Nm).Brake caliper to the vehicle and install the 2 bolts. Tighten the bolts to 77 ft. lbs. (104 Nm).ABS speed sensor and wiring harnessHeight control sensor link with the matchmarks aligned. Tighten the nut to 48 inch lbs. (5 Nm).Rear wheel(s)Negative battery cable
Lower the vehicle and turn ON the air suspension switch.
Fig. Exploded view rear carrier assembly, hub and bearing-
WARNING
Be careful not to damage the boot and ABS sensor
Rear wheel(s)Height control sensor link from the lower control armAnti-lock Brake System (ABS) speed sensor and wiring harnessBrake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire.Brake rotorParking brake shoes and cableToe control linkSeparate upper control arm assemblyShock absorber from axle carrierSuspension arms No 1 and 2 from axle carrierRear axle from carrier
4 bolts and axle & bearing assembly. Tighten to 48 ft. lbs (65 Nm)Rear wheel bearing dust deflectorRear drive axleUpper control arm. Temporarily tightenNo 2 and No 1 suspension arms. Tighten to 52 ft. lbs. (70 Nm)Shock absorber. Temporarily tightenToe control link. Tighten to 37 ft. lbs. (50 Nm)Fully tighten upper control arm. Tighten to 52 ft. lbs. (70 Nm)Height control sensorParking brake shoes and cableSpeed sensorRear disc brake caliperFully tighten shock with new nut to 52 ft. lbs. (70 Nm)Rear tire
Inspect and adjust rear wheel alignment
Check ABS speed sensor signal
Rear wheelWheel speed sensorAxle halfshaftBrake caliper and rotorParking brake shoesParking brake cableNo. 1 lower suspension arm boltNo. 2 lower suspension arm boltToe control linkUpper ball jointAxle carrier from the vehicle
Press the hub out of the wheel bearing, then remove the backing plate.
Remove the snapring, then press the wheel bearing out of the axle carrier.
To install:
NOTE
Use a new toe control link nut for assembly.
Installation is the reverse of the removal procedure, while using the following torque values:
Backing plate bolts: 43 ft. lbs. (59 Nm)No. 1 lower suspension arm bolt: 55 ft. lbs. (75 Nm)No. 2 lower suspension arm bolt: 81 ft. lbs. (110 Nm)Toe control link nut: 36 ft. lbs. (49 Nm)Upper ball joint nut: 80 ft. lbs. (108 Nm)Brake caliper support bolts: 77 ft. lbs. (104 Nm)Rear wheel lug nuts: 76 ft. lbs. (103 Nm)
Fig. Exploded view rear Axle carrier and hub assembly-ES 330
Rear tire and wheel assemblyBrake caliper support bracketBrake rotorSkid control sensor wire4 bolts and rear hub and bearing assemblySkid control sensor
To install:
NOTE
Inspect bearing back lash and hub deviation
Skid control sensorRear axle hub and bearing assembly with 4 bolts. Tighten to 59 ft. lbs. (80 Nm)Skid control sensor wire
Rear discRear disc brake caliper assembly. Tighten to 46 ft. lbs (62 Nm)Flexible brake hoseRear tire and wheel
inspect and adjust rear wheel alignment
Stabilizer Bar
Remove the rear wheels.
Remove the 2 nuts and left stabilizer bar link. If the ball joint turns together with the nut, use a hexagon wrench (5 mm) to hold the stud. Repeat for the right side.
Remove the 8 bolts, 2 No. 1 brackets and 2 bushings. Two types of bolts are used, so make sure the correct bolts are installed.
Remove the stabilizer bar.
To install:
Install the stabilizer bar.
Install the bushing and bracket with the 2 bolts and tighten to 14 ft. lbs. (19 Nm). Install the bushing to the inner side of the bushing stopper on the stabilizer bar.
Connect the stabilizer bar links and tighten the nuts to 29 ft. lbs. (39 Nm). Repeat for the right side.
Install the rear wheels.
Inspect and adjust rear wheel alignment.
Strut & Coil Spring
CAUTION
Do NOT remove the center nut to the strut at this time. The spring on the strut is under high pressure and can cause serious injury.
No. 2 luggage compartment trim coverLeft and right deck side trim boxRear luggage compartment trim coverFront luggage compartment trim coverLeft and right side luggage compartment trim coversRear wheelRear wheel fender linerNo. 2 differential support protectorRear suspension member braceRear No. 2 lower control armMounting bolts and strut assembly
Thanks for contacting FixYa. I was just reviewing some of the old unsolved problems and wanted to make sure your question gets resolved.
Chain can be correctly tightened by loosening the axle nut so the axle floats. Then tighten the chain tensioning nuts on either side evenly so they tighten the chain. When the chain is properly tensioned you will have 3/8th - 1/2" of slack between the chain and the swing arm. Then re-torque the axle nuts and lubercate the chain. Should be ready to go.
Hole in the blade is greater than spindle on the saw, you did not put bush washer/reducer in, or if that bit is correct, you are puting holding nut wrong way in.
Do not use saw till you rectify the problem, switch off the saw, remove power cord from socket.
1. raise saw table up for maximum cut 2. retract slide-in protector to maximum 3. remove nut from spindle, following by blade (and bush if used) 4. check internalholding washer if it is correctly inserted. 5. orient correctly internal washer (it have notch or notches and will go freely only one way - check if that is the case) 6. insert blade, with reducing bush if required 7. if external washer is used put it in 8. screw in the holding nut, hand tighten and check mobility of the blade, tighten up about 1/8 to 1/4 turn with spanner, this should be sufficient to hold blade in place without any slipage. If slipage is still present, you are doing something wrong, you need then to supply me with exact model and I will describe exact part look and order in which they must go in. 9. connect to electrical outlet 10. short switch on and off 11. check blade for wandering and slipage, if none then make test cut 12. use as usual if 11 is correct
well first get the bike up on a stand or set it on a milk crate. Loosen up main axle nuts you may need another wrench on the other side to back it up. loosen any small chain adjustment nuts. pull the chain as far back as it can go all the time looking a the chain sag..you want to keep about 5/8 to 1 inch play...lock just the axle nuts down snug...now spin the tire to see that all parts of the chain maintain this amount of sag. if its too tight in one area, you have a "stretched chain", and this will now be the focal point for tightening up the chain...this tighter part must have "some" slack in it...id say give it about 1/2 inch...now tighten up the chain adjustment nuts finger tight and look at your rear sprocket and make sure it lines up perfectly straight on with the counter shaft sprocket up front. Once this is aligned, tighten the smaller nuts snug, then proceed to torque down lightly maybe 10- 20 ftlbs. now spin the tire to check your slack in the chain did it move on you? Then you have to tighten or loosen the chain adjustment nuts a little more in or out till you get it right so it can move into the correct position. Once you got it right torque down on the main axle nuts 50-60ft lbs. Now tighten evenly each chain nut with the same ammount of turns to each....tighten the last nut down hard onto the first so they wont vibrate off. Now you should lube the chain..and your ready to go. after a while of hard riding recheck everything just to make sure shes secure! Can i get a very helpful on this. thanks!
Set the bike on its center stand, then loosen the rear axle by removing cotter pin from hex nut and loosening the nut. There are two adjustment bolts, with lock nuts - one on each side of the rear axle. They are easily work with from the rear of the bike. Loosen the lock nuts and turn the adjustment bolts clockwise. this will draw the rear axle (wheel) backwards - tightening the chain. Take care to turn each side the same amount, so the rear wheel remains straight. Usually the flex in the chain should be about a quarter inch. After adjusting, tighten lock nuts to hold position of rear axle and tighten the axle nut, replace cotter pin.
