SUPER clogged drains
I have 2 problems: My shower drain is clogged to the extent that I have to take fast showers so it doesn't run over onto the floor. I've tried 2 different kinds of drain-o, the big bottles, and it didn't do anything. I can't take off the drain cover and use a snake or hanger, in my case, because the screws are so rusted that there is nowhere to fit the screwdriver.
The second problem is the "main drain", I guess, which is in the basement, is clogged because every time I use the dishwasher, it flows down to the basement drain and then that drain backs up and floods the basement. I found some drain cleaner that looks like broken up cement left by the landlord and used more than enough and it's still clogged!! I'm just trying to fix it myself but it looks like the only way to get this solved is by calling a plumber. Just thought I would see if there was anything else I could do before calling in a plumber. Thanks.
    Master:
  • 518 Answers
About all you could do is rent an electric snake and clear the main drain. The shower drain line (if you follow it) may also have a port to use a snake.
Geno
Posted on Mar 05, 2008
Bought the Tao shower base and now can't install it because no one has the drain assembly for it. Where can I get the drain assembly
I bought the rubber donut when I bought my shower. It slides down over the 2 inch PVC drain pipe and seals against the drain hub
The Swan Corporation •515 Olive Street, Suite 1800 St. Louis, MO 63101 p (800)325-7008 •.St Louis, MO 63101 p (800)325-7008
Talk to the about the drain it comes with their shower base. Also go to plumbing sup[ply and talk to them
Also go to hHD and look at
Sioux Chief 2 in PVC Shower Drain with Strainer 828 2PK The Home Depot
Mar 14, 2018 | Plumbing
Does body wash clogg up shower drains?
Body wash is water soluble, so if you run some hot water it should dissolve and go down the drain. The more likely cause of clogged shower drains is hair caught either in the drain or the trap downstream from the drain. Try some liquid plumber and a small diameter drain snake. If that doesn't clear it, call the plumber
Jul 22, 2015 | Home
Shower in basement is backed up. Wondering if it's because a floor drain is covered up.
sounds more like the drain line is clogged between the shower and the main stack, and shares venting and drain with your kitchen sink. Have a plumber run a drain snake down from your kitchen drain (after the 'P' trap ) to clear the line. A covered over floor drain should have no effect on the back-up.
Oct 31, 2014 | Plumbing
Clogged shower drain
Shower drains are all designed to be opened and cleaned, usually hair builds up, if there is a visible screw remove it and lift the drain cover, if you can get fingers under the cover try lifting it off to clean it. If its stiff and its made of plastic do not use metal tools to lift it. Instead pass a trouser belt under both sides and use this to pull it up, then clean it.
Dec 04, 2013 | Home
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
When I open shower door after I have finished shower. Water from inside door goes on the floor, is there a catch all for the water
If the doors where installed correctly... the lip should be on the outside so that the water cannot run out onto the floor but runs into the shower instead...
heatman101
Apr 22, 2010 | Maax Shower Drain 10000041-105
My shower drain gurgles when the washing machine drains
The drain from your washer is tied to your shower drain and it is receiving air from your shower drain. Maybe your washer drain is not vented. This should not be a major concern if you can live with the noise.
Jan 03, 2010 | Dryers
I have a septic tank, but I really don't think that it's the problem. Everytime we take a shower, wash clothes, or run water for a few minutes the house starts to stink bad. There is no drainage problem...
hi
just trying some inputs
is your septic tank designed have an outlet pipe or out put air ventalation for the air that accumulated inside your tank released outside your tank try to check it of its clog
hope its help
Jul 09, 2009 | Plumbing
Clogged Drain in Whirlpool shower/tub
what you would have to do is this measure how far in to the line you are figure out what wall pipe is in cut access hole to pipe cut pipe and clearout blockage replace pipe your best bet is to go pick up the 3 peices of plumbing first 1. pipe 2.conections
Dec 21, 2008 | Brasstech ''P'' Trap Kit - 3013
Televison & Video Logo
186 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
