NO COLD WATER
HITACHI WASHER SF 6500PX, COLD WATER VALVE NOT WORKING SO SWAPPED WITH HOT WATER VALVE(WHICH WAS WORKING ON HOT WATER). IT WONT WORK ON COLD WATER INLET. WHEN I TURN MACHINE ON AND SET IT GOING, IT AGITATES AND DOESNT LET ANY WATER IN. I SWAPPED THEM BACK TO THE ORIGINAL WAY & IT WORKS ON THE HOT WATER INLET. STRANGE ?THE PROBLEM SEEMS TO BE UNDER THE CONTROL PANEL?
Still need a solution for this problem?
  • STARX Mar 09, 2008
    THANKYOU, AT THE MOMENT WE ARE RUNNING THE COLD WATER THROUGH THE HOT WATER INLET. I WILL GET VALVES TESTED AS YOU SUGGESTED.
    Sergeant:
  • 351 Answers
The problem sounds like an elecronic faullt try swapping the hoses over and also check that the resistance readings on the valves are the same.some times if they are diffrent it can damage the pcb.hope this helps
Posted on Mar 05, 2008
Cold water isn't coming on, only hot?
Not sure what ur saying have u tried changing the hot cold hoses and see what happens? u may have a bad water inlet valve or a bad water temperature switch? first make sure ur getting hot from the house outlet, u can check with a multi meter for continuity to see if either is out
Mar 15, 2015 | Admiral AW22 Top Load Washer
Hitachi sf 6500px washing machine
If this is a spelling error and your not getting HOT water, I suggest you check the wiring or wire plug connection to the 'water inlet valve' assembly. 1st-unplug the AC power. 2nd-turn off both water valves.3rd-prepare for spilled water on the floor.4th-carefully use a wide(app 1 to 2 inch)flat chisel(BIG flat blade screw driver)and pry the top assembly up.5th-it should open like a large tool box. Look down inside the back to see where the valve assembly is mounted. Now option #2 is turn the machine on its side to see if you can reach the valve assembly from the bottom with out having to open the top. Good luck on the job.
Mar 29, 2014 | Washing Machines
Frigidaire gallery front load washer does not use cold water when cold cycle is selected.
Either the cold water valve selenoid is not working or the control panal is bad. try swapping the hot and cold hoses and then call for hot water, if it fill with cold then the cold water valve is probably bad.
Apr 28, 2011 | Washing Machines
I have a Kenmore/Whirlpool Washing machine model 110.26832691 that doesn't allow hot water into the tub. I have put a new timer as well as a new temperature switch. Any answer?
Hello
Please try to swap both the connections, hot to cold and cold to hot, swapping will hopefully work. If swapping wont work then the water inlet valve also known as inlet hose assembly is bad and needs replacement. Please check the water level switch as well although I believe it is the water inlet valve causing this problem.
Kevin
Nov 11, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Only hot water works
Swap the water hoses connected to the water inlet valve and see if you then get cold water or hot water. If you just get cold and no hot then the valve is bad. If you still get just hot then the selector switch is bad.
Mar 11, 2010 | Kenmore 22422 Top Load Washer
Whirlpool LA8800XTWO washer - cold wash cycles will not fill the washer with cold water. Hot/warm wash cycles work fine. What could be the problem?
Hi.
You need to replace the inlet valve.
The valve can be tested reading ohms with a multimeter or swapping hot and cold contacts on dual valve.
Here the part: PS334646
Nov 14, 2009 | Whirlpool Washing Machines
Washer wont allow cold water
Mixing valve should lock out the hot water when on the cold water setting. Either your hoses are crossed, or the mixing valve is flipped. To see if one of these is true, try it on a hot water setting to see if cold water comes in, or try just swapping the water hoses.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
The washer will not call for cold water.
if all water supplies are clear, yes faulty switch. make sure you checked the screen on the water supply, both ends.
Jun 14, 2009 | Kenmore 24902 Top Load Washer
Water is not filling up.
turn off water
disconnect fill hose from tap
examine screen inside hose end for 'muck' blockage
clean screen
reconnect hose
test washer
if no fill
replace water solenoid valve
note: cold water valve fails first, it gets most use,
if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is no the cold one and the washer can be used, cold only, for about as long as it has operated thus far..
Oct 14, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
