Question about Toshiba D-R2 DVD Recorder
TOSHIBA dvd PLAYER/RECORDER sd-V394
I own the V394 for A couple of years, was very satafisty untill rescent. It will play fine for A while, then freeze, sometime I'll wait for about 5 min/ and it will contuine, but freeze up again. I've clean it witht A CD Lens Cleaner many times, and inserted A New DVD disc and it do the same thing. It will not play A complete Movie.
  • Anonymous Sep 08, 2008
    Mine freezes all the time. Can't even fast forward through it. Have to advance a frame and them rewind to around where I was. It's a huge pain.
    Master:
  • 518 Answers
You could try clening the laser lens with a damp Q-Tip, also gently turn the spin motor spindle by hand... it should be free. If it's binding or tight then it's bad.
Geno
Posted on Mar 05, 2008
Was rewinding a tape, then the unit shut off. Now will not turn back on. No power at all.
www.tacp.toshiba.com/tacpassets.../SD-v394/.../SD-V394_om_e.pdf
http://www.tacp.toshiba.com/tacpassets-images/models/SD-v394/docs/SD-V394_om_e.pdf
http://manuals.electromaniacs.com/category.php?id=176
OK above is some links for your user and a service manual.. use these to troubleshoot and hopefully repair your unit. This sounds like a thing called a Mode switch, inside the VCR going faulty. If you cannot sort it yourself, you need to take it to a Toshiba authorised service center and ask for a "Quote"
May 17, 2010 | Toshiba SD-V394 DVD Player/VCR
I cant play my moovies it will say region error how come?
Some DVD players have region coding only allowing discs to play specific to that country (or region) only . If you lucky you might find region hack online to re-program your player - just type <model number> region hack into Google. The alternative is internal modification which can be expensive - buying a region-free player would be cheaper.
Jul 10, 2009 | Toshiba SD-V394 DVD Player/VCR
Remote stolen
Usually pressing the record button a few times will change recording increments on all machines. Some newer universal remotes that have codes for dual dvd/vcr machines will work not older remotes.
Oct 27, 2008 | Toshiba SD-V394 DVD Player/VCR
Toshiba sd-v291
Click on the link below then type in your model number or you can click on the second link for a direct download
http://www.tacp.toshiba.com/customersupport/
http://www.tacp.toshiba.com/tacpassets-images/models/sd-v291/docs/sd-v291_om_e.pdf
Apr 20, 2008 | Toshiba SD-V394 DVD Player/VCR
DVD tray WONT OPEN
unplug it and try it again, if that doesn't work see if theres a pin hole where you can push a paper clip in by the tray area.
Feb 26, 2008 | Toshiba SD-V394 DVD Player/VCR
How to set time and date
Turn on. Goto channel 3 or 4. Press DVD/VCR button until display says VCR. Press TV/VCR button until the display says VCR. Press SETUP button. Select SYSTEM SETUP. Select CLOCK SET. Edit time and date. Press SETUP button.
Jan 07, 2008 | Toshiba SD-V394 DVD Player/VCR
Toshiba dvd Video player & vcr SD-V396SU2
Thanks. We have replaced the unit with a JVC but will give the SP/SLP a try just to see.
Anoyed
Nov 29, 2007 | Toshiba SD-V394 DVD Player/VCR
Turning on VCR for 2nd time recording
Have you fixed your problem?
If not, just try pressing the dvd/vcr button, so the vcr becomes the primary device. Now you can press setup and go back into the vcr menu.
Nov 11, 2007 | Toshiba SD-V394 DVD Player/VCR
Toshiba D-R2 DVD Recorder Logo
113 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
