Question about iLO (2 GB) MP3 Player
Won't Install I have an ilo mp3 player and when I put the installation CD and plug it in it doesn't do anything and doesn't even show that it exists but it works to listen to recorded music. I have a compatible computer and program but it doesn't do anything
  • 8,596 Answers
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Posted on Mar 19, 2008
SOURCE:
Won't turn on
You'll have to update the usb drivers on your computer and install the mp3 players drivers from the instillation cd
Nov 27, 2011 | Coby MP601 MP3 Player
Tip
ILo Mp3 Player Help is Here
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
on Sep 13, 2008 | iLO (2 GB) MP3 Player
Problem with mp3 player
iLO Mp3 Player
"Flash Error"
Jan 06, 2009 | Jwin MP3 Player
Video
Use the media converter that came with install CD - and read your manaual whileyou're at it
-Tha (Evil) Mp3 Doctor
Aug 04, 2008 | iLO MP3 Player
Can't put music on the player
you dont have to use the cd if it says you need an updated version, just plug it in and go to the c: drive and it should show up as a removable disk
Mar 22, 2008 | iLO (2 GB) MP3 Player
Ilo 1gb mp3 player
install the ilo driver cd that came with your ilo. Because you never know, not all ilo mp3 players have the same software.
Thats just my opinion, hopefully it works
Dec 30, 2007 | iLO MP3 Player
Having trouble with vista and the ilo 2 gb
This player is not compatible with Vista - they should have said something at Wal-Mart, but they don't have a clue
Dec 25, 2007 | iLO (2 GB) MP3 Player
Computer wont read mp3 player when connected
 iLO wont turn on when i connect it to my computer ,Its really BAD brand !!!
Nov 01, 2007 | iLO (2 GB) MP3 Player
Ilo mp3 player issue
Your ilo should've come with a disc. That disc should install windows media for you. You can't put music onto it without windows media.
May 05, 2007 | iLO MP3 Player
Incorrect Format Please Reformat the Player
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
  3. Download the correct Firmware
    1. Click here to download the ILO 116 Firmware
  4. Click Open to initiate the download
  5. Double click on the ILO or Siren folder icon. There will be 14 icons.
  6. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
  7. Then click Run - this will open the Install Wizard.
  8. The Install Wizard has the instructions on the screen as you go through it.
  9. Once the firmware has installed, please click the Start menu, then Programs.
  10. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
Nov 28, 2006 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
59 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Rick
Rick
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
